McCormick-Deering 1 1/2 Hp
this thread has 10 replies and has been viewed 2149 times
Old 10-30-2010, 02:10:05 PM
Jerry B Jerry B is offline
Default McCormick-Deering 1 1/2 Hp
My engine has ben starting the first crank but now it seems like it is not getting gas, How can I tell if it is the fuel pump or some thing more It is fireing good any ideas? Jerry B
Old 10-30-2010, 03:13:25 PM
John Savot John Savot is offline
Default Re: McCormick-Deering 1 1/2 Hp
Have you filled the mixer at the little plug on top?
John
The Following User Says Thank You to John Savot For This Post:
Old 10-30-2010, 05:23:18 PM
Yes I pourd gas in the mixer I even spard carb cleaner in the mixer and it always starts the frist time the spark plug is fireing Jerry B
Old 10-31-2010, 09:18:27 AM
I think I would try a new spark plug, If that isn't it go back and check all of the timing set up from the beginning.
John
Old 10-31-2010, 02:01:11 PM
On my McCormick-Deering on the fuel pump I took the spark plug out so I could crank the engine over faster and took the fuel line off the fuel pump fuel would barley come out is that what it should do. I went and order a new spark plug for it. I was looking at the plug when cranking the engine it was fireing like it should but some times it was fireing inside the plug. Jerry B
Old 10-31-2010, 03:23:19 PM
BobRR BobRR is offline
The pump doesnt pump alot. If its pumping just cranking it is fine. Sounds like it is your plug. Try cleaning it by spraying it out with carb cleaner. Some times that will get ya going. Bob
The Following User Says Thank You to BobRR For This Post:
Old 11-01-2010, 12:07:30 PM
When I took the plug out so I could crank it faster the fuel would came to the top of the fuel pump, And a few drops would get on the pump is that right. Jerry B
Old 11-03-2010, 08:16:59 PM
Is it running yet?
John
Old 11-03-2010, 10:18:30 PM
The motor kid pig guy The motor kid pig guy is offline
Are your checkballs dirty that will allow some fuel but not enough check and clean
The Following User Says Thank You to The motor kid pig guy For This Post:
Old 11-04-2010, 08:19:36 PM
Thinks I cleaned the plug with carb. cleaner and put the plug back it runs like a top think you Jerry B
The Following User Says Thank You to Jerry B For This Post:
Old 11-06-2010, 03:47:08 PM
Rick I Rick I is offline
Super! I've indeed had exactly this same problem. And like you, cleaning the plug w/carb cleaner saved the day.
McCormick-Deering Jerry B Hit & Miss Gas Engine Discussion 2 08-24-2009 06:41:37 PM
W12 McCormick Deering jeff3co Antique Farm Tractors 13 04-08-2009 04:28:55 PM
mccormick deering M David B. Hit & Miss Gas Engine Discussion 5 07-14-2006 01:28:22 PM
mccormick deering 1 1/2 hp Roy Bartlett Antique Engine Archives 6 05-10-2004 10:59:34 PM
McCormick Deering M 1 1/2 HP Steve Link Antique Engine Archives 0 01-05-2002 03:22:00 PM
