Best way to make a tortional spring?
this thread has 9 replies and has been viewed 2188 times
Old 10-31-2010, 08:09:45 AM
Ram Ram is offline
Default Best way to make a tortional spring?
Have an old Wagner repulsion induction motor with springs holding brushes in the brush assembly. One spring is broken in half.
This thing is so old, no NOS can be found and it is not cost effective to have half a dozen springs custom made from a company much less one.
I would like to try making a spring but wanted to ask for tips and suggestions first before ruining any spring wire first.
Old 10-31-2010, 08:29:53 AM
JKWidener's Avatar
JKWidener JKWidener is offline
Default Re: Best way to make a tortional spring?
Go to a motor rebuild shop, im sure another brush spring for a different kind of motor could be used.
Old 10-31-2010, 09:10:29 AM
Try this site. Very helpful on making springs.
Jim
http://home.earthlink.net/~bazillion/glossary.html
The Following User Says Thank You to Jim Tremble For This Post:
Old 10-31-2010, 03:47:07 PM
Ram Ram is offline
Jim, Thanks for the link very good info and safety tips. It sounds do-able. May have to build a small propane fired oven that won't be a big deal though.
JK I have checked so many shops it is not funny. All they can say is the spring is obsolete and they can't get one any more.
Love to find someone with an old Wagner R-I motor that the windings are shot for the springs and brush assy. I'm sure most have made it to the scrap yards by now though.
Old 10-31-2010, 04:22:28 PM
OTTO-Sawyer's Avatar
Thanks for that link Jim.
No projects going on at the moment, but it could be very handy in the future.
Old 10-31-2010, 05:22:30 PM
JoeCB JoeCB is offline
Ram, Have you considered bending a new spring out of piano wire? This wire is pre hardened/tempered and makes very good quality springs requiring no additional heat treat. Of course a lot depends on the comfiguration that you need.
A picture of the old spring would help.
Joe B
Old 10-31-2010, 06:47:06 PM
Ram Ram is offline
Joe B
That is what I want to use. Assuming "Music wire" is the same as "Piano wire".
Pictures below.
ID:	91391   Click image for larger version
Old 10-31-2010, 06:47:38 PM
Joe
All of the springs I have made required heating after completion. All were made of piano wire. It relaxes the stress of bending. 500* for 1 to 1-1/2 hours and let cool in the oven. I just use an old electric stove oven in the shop.
Also, the mandrel that you wind the spring on, has to be 1/3 smaller OR 2/3 the size of the desired ID of the spring that you are making. The new spring will unwind a bit when you are done. All of this is explained on the website.
Jim
Old 11-01-2010, 10:03:49 AM
Jim, I can understand the concept behind the 500 degree stress relief. that temp would not soften the wire as a normal carbon spring would have been tempered at a higher temp like around 750 or so.
However I question the need for any heat treatment after cold forming a piano wire spring. I have made many springs from wire as heavy as 1/8 " and never had a problem. Perhaps the 500* degree treatment would make a BETTER spring.
Joe B
As for the needed torsion spring... I would start with a proper size extension spring and uncoil to form the straight arms. Looks like this is a low stress application.. should work OK
The Following User Says Thank You to JoeCB For This Post:
Old 11-14-2010, 09:14:57 PM
Monte Stock
I'm not trying to sound like a smart a$$ but have you tried a hardware store. The kind that has all the little bins. That looks like you could modify something that would work. Let us know what you do. I run into this problem from time to time and always interested in better ways.
What make is this one? BobM Hit & Miss Gas Engine Discussion 5 02-16-2008 12:06:47 PM
What make is this? Brian Manning Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 08-30-2006 05:20:19 PM
did they make? Chuck R Machine Shop and Tool Talk 2 05-12-2006 08:07:15 PM
What make is this? Brian Manning Steam Stationary Engines, Traction Engines 7 02-14-2005 01:11:49 PM
What make??? Jim Sherman Hit & Miss Gas Engine Discussion 4 01-23-2005 11:32:46 PM
