Jarno #15 taper sleeve
this thread has 1 replies and has been viewed 2104 times
Old 11-12-2010, 08:54:29 PM
halh123 halh123 is offline
Default Jarno #15 taper sleeve
Wanted Jarno #15 spindle sleeve adapter to use MT tools on my recent acquired Reed and Prentice gear head lathe.
Old 11-12-2010, 11:17:00 PM
Default Re: Jarno #15 taper sleeve
Some of the early LeBlond lathes used a jarno taper. Maybe you can find one of those?
Richard W.
The Following User Says Thank You to Richard W. For This Post:
CCK Crankshaft Taper Brian Howard Onan Generators 0 05-03-2010 07:37:20 PM
JB crankshaft taper BGunn Onan Generators 2 10-03-2009 03:25:33 PM
United Key Taper? JBoogie Hit & Miss Gas Engine Discussion 2 09-29-2009 09:23:55 PM
No. 1 Taper Pin: What is it? Colin Rush Magnetos, Ignition Coils and Spark Plugs 6 04-21-2006 05:38:54 AM
crankshaft taper? grub54891 Hit & Miss Gas Engine Discussion 1 03-18-2006 01:17:36 PM
