Info needed for Sanborn / SMC Air Compressor
this thread has 3 replies and has been viewed 2821 times
Old 11-28-2010, 08:11:27 PM
Acableguy06 Acableguy06 is offline
Default Info needed for Sanborn / SMC Air Compressor
Does and one have any pre coleman/sanborn info? I purchased a Sanborn compressor that does not have any model info. it is about a 20-25 Gal with a 2 HP westinghouse motor and an unknown compressor only markings are stamped 021662 and 1388 or 1368. This is a Sanborn MFG Co. compressor not the newer coleman branding.
Thanks,
Old 12-01-2010, 06:09:07 AM
Steve NW Ohio Steve NW Ohio is offline
Default Re: Info needed for Sanborn / SMC Air Compressor
I have a Model 84 Sanborn [22 gal x 1 hp x 150 psi] which pretty much matches your description. Will look thru my files to see what I might have on it. Steve
The Following User Says Thank You to Steve NW Ohio For This Post:
Old 12-01-2010, 10:07:51 PM
Ram Ram is offline
Have a twin tank, twin single stage 143 pump with a Kolher 7 hp gas engine on mine. Work site style with wheel barrow handles and a couple tires. Worked great until the valve pack on the pump wore out. Reeds broke from heat/age.
Old 12-04-2010, 09:02:18 PM
Steve, Thanks that would be great!
Sears/Thomas old Air Compressor - help needed will s Machine Shop and Tool Talk 7 07-22-2010 06:53:02 AM
Curtis compressor information needed please R. Kern Hit & Miss Gas Engine Discussion 6 02-23-2010 10:55:01 PM
Schramm Air Compressor Info needed 930dreamer Small Air Cooled Gasoline Engines 2 03-14-2009 11:25:00 PM
Identity needed for small compressor?? Peter Ruffle Farm Antiques and Collectibles 1 08-21-2007 08:27:41 PM
Info Needed...PA Pump & Compressor Co. E.C. Mims Antique Engine Archives 0 02-13-2003 11:08:01 PM
