Straightening a Pipe Wrench
this thread has 9 replies and has been viewed 3612 times
Old 11-30-2010, 10:11:33 PM
Meco3hp's Avatar
Meco3hp Meco3hp is offline
Default Straightening a Pipe Wrench
Hello,
I was given a fairly new Rigid pipe wench that somebody got stupid with and bent it. Could a guy heat it up and bend it back?
Thanks!
Richard
Old 11-30-2010, 10:24:25 PM
Rick McKay Rick McKay is offline
Default Re: straightening a pipe wrench
According to Ridgid's guarantee, if the wrench bends or breaks, they will replace it. I have never tried to turn one in, so let us know how it works out.
Rick
The Following User Says Thank You to Rick McKay For This Post:
Old 11-30-2010, 11:04:49 PM
Default Re: Straightening a Pipe Wrench
My first pipe wrench was a nice 24" Rigid steel that I got cheap because it had a pretty good bend in it. After years of buying wrenches I have more pipe wrenches than I care to count, from small to 48" and still have that original 24"-er.
A couple years ago, I decided to straighten it and did quite easily by using a hydraulic press and some well positioned steel blocks to allow the re-bend to proceed the way I wanted it to.
I moved the blocks as needed and now the wrench is straight.
Bend it cold, or rather heating should probably not be needed.
The Following 2 Users Say Thank You to KidDynamo For This Post:
Old 11-30-2010, 11:06:08 PM
Monte Stock
I suspect a cheater bar. Been there done that.
The Following 2 Users Say Thank You to For This Post:
Old 12-01-2010, 12:10:11 AM
Meco3hp's Avatar
Hello,
I'm thinking cheater bar also! If it was a bigger wrench, I'd suspect a over head crane! They have 2 pipe wrenches at work that must be 6' wenches, (we build pulling rigs among other oil field products). As you can guess when repairing oil field equipment, you have to get extreme some times. On a number of occasions, I've walk through the shop only to see one of those wrenches on a part with a 10 ton over head crane pulling up on the handle!: Talk about a cheater bar! I just turn and walk back into the office. Yes, they are bent!
Rick,
I figure a bend from a cheater bar would void most warranties.
I've been wanting to build a hydraulic press for my shop. Now I got another reason to build one.
Thanks!
Richard
Old 12-01-2010, 01:42:28 AM
Eric M.'s Avatar
Eric M. Eric M. is offline
Originally Posted by Meco3hp View Post
Rick,
Maybe but maybe not. You never know until you ask. A friend of mine bought a 1/2" breaker bar from the Snap-On truck that visited his jobsite (before he retired). As you know, Snap-On has a "If it breaks, we'll replace it" guarantee. When he bought it, he asked the salesman "how many feet of cheater bar can I apply before I void the replacement guarantee?" His response? "If it breaks, we'll replace it."
The Following 3 Users Say Thank You to Eric M. For This Post:
Old 12-09-2010, 12:47:38 PM
David Hughes David Hughes is offline
I have a 3 ft Rigid pipewrench that was broken at work while breaking drill string joints, Rigid replaced it
David Hughes
The Following User Says Thank You to David Hughes For This Post:
Old 12-09-2010, 01:09:09 PM
Roland Hayes Roland Hayes is offline
I inherited an old Snap-On 1/2" drive 36" breaker bar from a relative, it had snapped in the middle of the handle shaft but had continued to be used at the shorter length just as a general purpose bar. I had it in one of my toolboxes for years until a time came where I was working in a place where a Snap-On man came around weekly to sell tools to the guys, I thought I'd see if he would exchange it for a new one, which he did immediately and without question. The Snap On lifetime guarantee means what it says, I find that very reassuring in these times.
The Following User Says Thank You to Roland Hayes For This Post:
Old 12-09-2010, 01:52:16 PM
Weezer Weezer is offline
Be careful putting that wrench in the press! I used to straighten the 4 bar links on a friends race car when they got bent. One time the bar slipped, I heard the bar and one of the blocks go past my head. Find some way to restrain that thing. Those little plexiglas guards ain't gonna do it, they're just more shrapnel for the Dr. to remove!
The Following User Says Thank You to Weezer For This Post:
Old 12-09-2010, 02:48:18 PM
OTTO-Sawyer's Avatar
After many years of running a straightening press at work along with machining, broaching, milling, spline rolling, finish grinding, etc.,...I have to offer up another word of caution when straightening anything.
If you can't get it in 'one shot', try to get it done in the second try, as the more times you bend it the more brittle it gets, and the more likely it will break on you.
You have to bend it passed straight with a slight bow in the opposite dirrection so it can spring back to straight when you relieve the pressure. If you try to sneek up on it a little at a time, the repeated bending and relieving will stress harden it to the point you may as well be trying to straighten a glass bottle. Eventually you will have shrapnel flying.
Eyeball it before you start to determine the best location for the support anvils with the ram on the high point even if it isn't pefectly centered between the anvils, then press it as quickly as you can to 1/4 to 1/2 inch passed straight depending on how bad the original bend was.
Crank straightening help Rich Hudak Hit & Miss Gas Engine Discussion 1 09-14-2010 01:47:15 PM
Working with pipe and pipe threads? Bob Krummel Hit & Miss Gas Engine Discussion 12 03-19-2010 08:59:34 PM
Old pipe fitting found on an old pipe Paul Spence Hit & Miss Gas Engine Discussion 0 01-11-2010 03:56:27 PM
Crank Straightening??? Bill Wehrman Antique Engine Archives 11 02-24-2003 11:39:30 AM
Straightening copper tubing Norm S Antique Engine Archives 14 09-19-2002 02:27:16 AM
