Paint Shop
Not an expert in the paint booth.
this thread has 2 replies and has been viewed 2338 times
Old 12-04-2010, 10:43:27 PM
ronny p 148 ronny p 148 is offline
Default Not an expert in the paint booth.
Using rattle can Osha blue Crylon Not enough light got a run on gas tank on my briggs. Not very noticeable kinda between flywheel shroud best to let dry and leave it alone I think I know its there and you know haw that is !
Ronny
Old 12-04-2010, 11:30:54 PM
marlorup marlorup is offline
Default Re: Not an expert in the paint booth.
Try some fine sand paper to smoothen out the run, and blend the area in with the surrounding area. Clean up any dust from the sand paper, and try a respray. Remember, 2 or 3 light coats are usually better than 1 heavy coat. Good luck. let us know how things turn out. Mark.
The Following User Says Thank You to marlorup For This Post:
Old 12-05-2010, 01:04:43 PM
Well I just rubbed off run with rag while wet and lightly went over it. Funny thing you experts will know why this happened. The area with the run kinda blended in as the paint cured. Not perfect but looks OK for what I'm doing. Didn't have a lot of light and this as you know is problem when doing anything. I'm satisfied.
Ronny
I need a New-Way expert. prybar Hit & Miss Gas Engine Discussion 3 10-19-2010 03:53:42 AM
Please, some expert help--4.5 Genset John Kendrick Onan Generators 1 05-23-2010 10:04:58 PM
Poor man's paint booth Jeff and Maria Smith Hit & Miss Gas Engine Discussion 9 01-13-2010 10:47:07 AM
Need help from an IHC expert Danny in KY Antique Engine Archives 6 07-22-2004 01:30:28 AM
Need Olds expert kevin Hesse Antique Engine Archives 0 11-07-2003 05:20:30 PM
