Holt T-16 40-60 (10 ton)
this thread has 10 replies and has been viewed 3007 times
Old 12-08-2010, 12:29:12 AM
A Martinson's Avatar
A Martinson A Martinson is offline
Default Holt T-16 40-60 (10 ton)
Here is our Holt with a LeTourneau blade. The blade has a tag that says "Bull Dozer" on it, which I think may well be among the first use of the words. This tractor was used in Ely Minnesota for plowing snow originally.
Its currently at a friend's shop and we're doing a little work on it. The main problem is that one steering clutch is not functioning. While its apart I'm also planning on pouring new bearings as almost all of them are out of shims. Other than that, it basically just needs a good clean up. I'm trying to figure out what color to paint it. The tractors were originally gray. I think it was painted yellow when the blade was installed, but I'm not certain.
The Following 16 Users Say Thank You to A Martinson For This Post:
Old 12-08-2010, 12:41:07 AM
Tom Madden Tom Madden is offline
Default Re: Holt T-16 40-60 (10 ton)
A Martinson, use battleship grey. Yellow would never have been used until December 7, 1931. I hope the cab pictures I sent you will assist in the reconstruction of your cab.
Old 12-08-2010, 12:42:16 AM
Yes Tom, those should help greatly! And I can't thank you enough for the information you sent.
Old 12-08-2010, 11:16:34 AM
Farmall86 Farmall86 is offline
Im excited to get that bad boy running and play with it!!
Old 12-08-2010, 07:11:47 PM
Yes, Farmall86, it'll be fun. Some people at the show might not be too fond of the lights on it, since it will allow us to make noise around the clock.
The Following User Says Thank You to A Martinson For This Post:
Old 12-08-2010, 08:26:08 PM
Terry Welch Terry Welch is offline
Ah come on it is not any fun unless you can make some noise. That is why they invented the Detroit Diesel.
Terry
Old 12-09-2010, 02:17:51 AM
Eric M.'s Avatar
Eric M. Eric M. is offline
Too bad for them
Old 12-09-2010, 11:39:54 AM
Wow, cab and street pads! What a nice original crawler! I would say paint it either color you prefer. The yellow may have been added later, but it probably spent it's working life in that color, so it has some merit for consideration. In the end, your dozer, so you do as you please!
Old 12-11-2010, 03:15:23 PM
Yes Brasherman, that is part of the reason why I'm struggling with the color, as part of originality to me is honoring its working life, not just as it left the factory.
I just found (30 seconds before I started posting this) the number 24189 stamped on the top half of the transmission, could this be the serial number? I was told that some had a serial plate below the radiator, but I found no rivet holes to show that one was ever there.
Old 12-11-2010, 06:45:27 PM
loggah loggah is offline
Some were stamped right in the casting in the front,right side looking at it if i remember correctly. I had a couple of the 10 tons and sold them 8 or 9 years ago. Don
The Following User Says Thank You to loggah For This Post:
Old 12-12-2010, 06:42:20 PM
ajs2744TC ajs2744TC is offline
I know there is a Holt like that on display along the highway north of Bemidji heading to International Falls. I also think the Glass Family owns one at rollag.
Holt 75 AultmanTaylor Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 19 06-16-2011 05:37:30 PM
Holt 45 DaveE Multi-Cylinder Stationary Gasoline Engines and Power Units 1 05-07-2009 06:00:01 PM
Holt 18 jbo.aermotor Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 01-26-2009 03:12:48 PM
Holt 25 agsem Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 10-29-2008 01:06:01 AM
Holt 10 ton? Steamrguy Hit & Miss Gas Engine Discussion 1 04-01-2005 11:18:37 PM
