Alloy 455 Material uses?
this thread has 2 replies and has been viewed 1676 times
Old 12-16-2010, 08:10:20 PM
930dreamer 930dreamer is offline
Default Alloy 455 Material uses?
I have (5) pieces of 4-1/4" X 21"-55" 455 cutoffs, what would this material be used for? Thanks
Old 12-16-2010, 10:19:43 PM
TerryJay TerryJay is offline
Default Re: Alloy 455 Material uses?
455 is a fairly soft stainless alloy used in the aircraft field,and has a high resistance to oxidation
Old 12-16-2010, 11:32:44 PM
Thank you.
Best headgasket material? Jon Mrozinski Hit & Miss Gas Engine Discussion 2 11-20-2010 09:22:28 PM
Sleeve Material Walt Beeman Hit & Miss Gas Engine Discussion 7 06-20-2009 01:40:42 AM
Wrist Pin Material? Tom Martin Hit & Miss Gas Engine Discussion 8 08-11-2008 01:44:17 PM
clutch material ?? Steamrguy Hit & Miss Gas Engine Discussion 3 12-29-2005 02:07:28 AM
wrist pin material steve illig Antique Engine Archives 5 01-04-2000 09:51:12 PM
