Paint Shop
Help on Stuart 50!
this thread has 4 replies and has been viewed 2494 times
Old 04-13-2011, 10:53:17 PM
Jim Alexander Jim Alexander is offline
Default Help on Stuart 50!
Good evening. I've recently decided to refurbish my Stuart 50, it's time for a new dress. I have it stripped down and have spent a far amount of time on the casting. I have a few areas that need to be filled. I would like to take the politically correct way of doing this. Not sure if bondo and primer is the way to go. What would the old world craftsman do in this situation? Please review the two photos and give me some advise. Thank you all so very much.
ID:	104704   Click image for larger version
Old 04-13-2011, 11:23:18 PM
QuickJ QuickJ is offline
Default Re: Help on Stuart 50!
The areas are pretty small.
I would use JB Weld which closely matches cast iron when cured.
I used it to patch a couple of 1/4" accidental holes in the table of my drill press a dozen years ago and they are almost invisible.
Jim in Minnesota.
Old 04-14-2011, 11:08:34 AM
Exclamation Re: Help on Stuart 50!
Casting flaws are part of the engine's history. No casting, no matter how well cast, is ever perfect, no matter how careful the mold maker and fhe foundry are in their workmanship. Even lost wax castings are not perfect. I would not worry about the 'flaws'. If you really want to be a perfectionist, turning the casting on edge, warming slightly, and appiying THIN layers of either bondo or JB weld, will fill them in. Preparation is the key - the repair area MUST be completely oil free, otherwise the 'repair' will seperate at some point in the future, even many years from now. If you plan to paint the casting, bondo would be a better bet, as paint tends to peel away from JB after time passes. If you want to leave the casting in its 'metal state, JB probably is the way to go.
Old 04-26-2011, 05:18:25 PM
Modelmaker Modelmaker is offline
I always use "One Shot" sign painting enamel to paint my projects. It has lots of pigment and covers well. It is fairly expensive but worth it. I use a $12.00 touch up gun from Harbor Freight to spray the engines.
Best Regards, Modelmaker1
Old 05-03-2011, 03:31:42 PM
OTTO-Sawyer's Avatar
Originally Posted by vintagesteamtoys View Post
...I have a few areas that need to be filled. I would like to take the politically correct way of doing this. Not sure if bondo and primer is the way to go. What would the old world craftsman do in this situation? ....
I would guess either silver solder, or lead (also known as "Body Solder" in the car restoration circles).
Silver solder should be available in most any plumbing section in your local home improvement center, and lead sticks (or Body Solder) can be bought from the Eastwood Tool Company and possibly other specialty stores catering to auto body supplies.
May not want lead in the toys your kids chew on, but if they chew on a model steam engine they should have their teeth pulled anyway. That may not be politically correct, but people have safely lived with lead in their surroundings for generations as long as they aren't chewing on it, although I'm guessing a lot of kids back in the day probably chewed on a few lead soldiers and lived to tell about it.
Help! Stuart 50 Jim Alexander Scale Model Engineering 16 03-31-2011 08:54:14 PM
Stuart 10v ssimntih Scale Model Engineering 3 08-29-2010 01:41:14 PM
Stuart 10v jarguello Vintage Toy Steam Engines and Motors 3 10-24-2009 03:28:40 PM
Stuart No. 1 polymer Scale Model Engineering 3 09-26-2009 11:57:50 PM
Stuart 5A Warren Hudson Steam Stationary Engines, Traction Engines 1 09-08-2002 11:17:53 PM
