Paint Shop
Seems cheap you get cheap!
this thread has 4 replies and has been viewed 3118 times
Old 04-23-2011, 11:52:24 PM
ronny p 148 ronny p 148 is offline
Default Seems cheap you get cheap!
Seems with prep and painting if you do it yourself you can run into a host of problems. Even body shops have ther problems at times. We have a shop here that there 2nd to none he did our 1949 Maxam ladder truck . He went to spray some dust off truck and paint came off in strips like sheets of paper. was problem with the paint . He had to do whole truck over. So I've used a rattle can and even that bulbed up on me the other day i let it sit and it seemed to blend in going to let it cure a week or so .
Ronny
Old 04-24-2011, 09:15:03 AM
LCJudge LCJudge is offline
Default Re: Seems cheap you get cheap!
Several years ago Chevrolet had some problems with their paint. I was at a car wash and the gent in the bay beside me stepped over to the bay I was in as I was getting ready to wash my truck. He asked if I would step over to his bay to look at his. He was using the high pressure washer on the hood of his truck and a strip about a foot wide came off the length of the hood. He said he had bought the truck new and it was about 6 months old. He said he was headed to the dealership from the car wash.
Tommy Turner
Old 04-24-2011, 09:47:47 AM
Neville Bond Neville Bond is offline
I work at a car plant in the UK, our company look after the water for the spray booths, there is a whole lot of things that can affect paint, temp , humidity, even something like aftershave or body spray can cause defects in the finish , anything containing silicon is banned from the paintshop.
Another thing that has just caused in the past is Diesel exhust fumes being drawn into the air supply when trucks have been parked up near the intakes.
---------- Post added at 08:47 AM ---------- Previous post was at 08:45 AM ----------
Sorry I went off track in the last line, it should have read problems in the past ( been out in the sun ) !
Old 04-24-2011, 02:31:05 PM
Exclamation Re: Seems cheap you get cheap!
Most of the paint on todays cars will NOT stand up to even a mild pressure washer. The clear coat used to make the gloss surface is too soft to stay in place with the pressure. My 1996 dodge stripped the clear coat with just 500 PSI. The entire truck had to be repainted. In the mid 1970s, Ford and GM also had paint problems - the paint was not compatable with the primer. The paint peeled off the hood and trunk of my parents Ford Granada, within 2 months after delivery!
Old 04-24-2011, 04:26:21 PM
Rod Fielder Rod Fielder is offline
It's not the clearcoat. It's the undercoats and wrong prep.
With the government (epa) mandating voc output, the paint manufacturers are having to re-formulate almost on a yearly basis to keep up with regulations. this is why paint and clear is 200.00 a gallon. Not enough time to do any research on compatability. Clean and sand, clean and sand, and then clean again. Don't mix company to company products. It's the best we can do.
Spraying on the cheap! dhiesel Paint Shop 2 06-14-2010 08:56:13 PM
Cheap is as cheap does... coil question R. Kern Magnetos, Ignition Coils and Spark Plugs 17 06-13-2010 02:20:12 PM
Two saws for cheap ashhash Chain Saw Collectors 10 03-17-2010 07:56:06 PM
A Cheap coil for an FH Dennis Wyatt Small Air Cooled Gasoline Engines 2 09-25-2008 10:23:49 PM
1/2 sparkplugs (cheap) Chuck Woycke Hit & Miss Gas Engine Discussion 23 08-23-2005 04:54:05 PM
