1 1/2 HP Mc Deering rod brg.
this thread has 2 replies and has been viewed 1453 times
Old 05-18-2003, 03:41:04 PM
Chuck Rich
Default 1 1/2 HP Mc Deering rod brg.
I have a 1 1/2 IHC M. Yr.1927. I need to know if the lube grooves on the connecting rod insert goes on the rod side or the cap side? I know that one of you out there has this answer. A big thanks ahead of time, Chuck
Old 05-18-2003, 05:43:15 PM
John Hammink
Default Re: 1 1/2 HP Mc Deering rod brg.
Chuck it sounded a little strange to me, I just took a look in the shed for some inserts and saw what I expected, both inserts have oil grooves. In case you have one whitout grooves, I would place the one with the grooves in the cap, cause that's the lowest point and the oil always will sit there.
"Sixm" John
Old 05-19-2003, 08:43:20 PM
Ed Deis
You are correct John. These bearings were made in a mold 1/2 at a time-or several and each has the part # and the grooves. There are a couple of different designs with the grooves and new bearings from H&M don't have the part# and a com-pletely different groove-but what the heck-they do the job. Ed
Deering TD 35 GreasyJohn Service Manual Scans 8 03-23-2019 11:42:24 AM
Mccormick Deering M 3 Hp vinceostapowich Hit & Miss Gas Engine Discussion 10 06-30-2017 04:20:30 PM
10 20 Deering Edgar Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 07-16-2013 10:17:53 AM
IHC McCormick Deering 3HP M value Rob Williams Hit & Miss Gas Engine Discussion 6 09-13-2009 11:49:20 PM
3hp M Deering. John Hammink Antique Engine Archives 0 05-13-2002 05:17:32 PM
