Smokstak Down Under
My first Anderson engine
this thread has 8 replies and has been viewed 2793 times
Old 07-02-2011, 08:29:11 AM
robert hamilton robert hamilton is offline
Default My first Anderson engine
I picked up my first Anderson engine today 2/07/11 its in ok condition i will post some pics tomorrow im wondering how much old goes in them and how to time the mag
The Following 4 Users Say Thank You to robert hamilton For This Post:
Old 07-09-2011, 08:30:31 PM
Default Re: My first Anderson engine
Here are the pics i promised so long ago i need another top piston ring it fell apart when i removed the cylinder i also need the two things that hold the spark plug and primer cup they broke as i removed them to remove the valves to be reground they where seized in
ID:	110253   Click image for larger version
ID:	110254   Click image for larger version
ID:	110255   Click image for larger version
The Following 8 Users Say Thank You to robert hamilton For This Post:
Old 07-16-2011, 03:52:39 AM
Evan Hale OConnor Evan Hale OConnor is offline
Very nice Robert, I have an Anderson just like this one its the milking type, it's a model D 1918 1919, and it has the good old T and B mag, the plugs we should have at the club, and the rings. But very good find, they run very well. Good luck.
Cheers
Ev
The Following User Says Thank You to Evan Hale OConnor For This Post:
Old 07-16-2011, 11:48:58 AM
How much oil should i put in the sump and how do i time the mag it has me baffled the throttle on the manifold is broken im going to get it brazed up i cant wait to get it running
The Following User Says Thank You to robert hamilton For This Post:
Old 07-17-2011, 06:20:21 AM
Ok right, now there are numbers on the flywheels, you get the engine on compression stroke and the numbers line up with the boar, turn the engine in running direction then bring the numbers back in line with the boar, from there move the numbers towards the carb, the points should be just on the verg of opening at that point, tighten the mag nut up, then turn the engine until the numbers line up with the cylinder, now the points should be fully open. As for oil there is an adjustbil thing on the left hand side of the engine, you fill the engine until it is just over the big end, and you can do this with the sump plate off, as long as it's over the big end you are safe. It's not like the Andersons with the sump plugs as this one is the very early model. Hope this helps, if not I can do a video for you on how to time the engine.
Cheers
Ev
Old 07-21-2011, 08:17:05 AM
I found the numbers i should be able to time it now i know how i will need the rings and plugs before i can time it i hope it runs as good as my A1 petter and my 5/1 cs diesel lister
Old 10-01-2011, 02:26:10 AM
Hi evan could you please make a vid on how to time an anderson engine please
Old 10-01-2011, 06:57:35 PM
tim2010 tim2010 is offline
Hi Robert,
I’m no expert but initially I’d suggest you take the cover off the crankcase so you can see the conrod and take the cover off the magneto so you can see the points. Adjust the magneto so that the points open when the piston is at top dead centre – you can fine tune it from there and the timing marks may then make sense.
Check - there may be timing marks on the maggy gears…?
tim
Old 10-31-2011, 06:26:23 AM
At 5:36 Pm my anderson started fir the first time in about 10 years all i need to do now is finish the fuel system here is a link to a video of it running
http://www.youtube.com/watch?v=WRxng...eature=mh_lolz
Anderson vert, air cooled engine Gary Gruel Hit & Miss Gas Engine Discussion 3 11-03-2013 08:19:37 AM
Anderson Gin Engine Dwayne Fuller Hit & Miss Gas Engine Discussion 5 11-14-2010 12:12:03 AM
1928 Anderson 3HP Stationary engine Evan Hale OConnor Hit & Miss Gas Engine Discussion 7 01-02-2010 05:38:11 AM
Anderson (Kiwi engine in Oz) Patrick M Livingstone Smokstak Down Under 23 06-28-2009 09:07:22 PM
A good engine for Craig Anderson... Jim Sherman Hit & Miss Gas Engine Discussion 8 09-29-2008 01:28:14 PM
