Paint Shop
need a little paint help
this thread has 4 replies and has been viewed 2218 times
Old 10-05-2011, 10:43:36 PM
cummins 05 cummins 05 is offline
Default need a little paint help
ok so i have used paint stripper and took all the paint off i have then wire wheeled the engine washed real well and used the dupli-color self etching primer from napa. Now my question is what black paint should i use the dupl-icolor rattle cans rustoleam cans or brush on or some tractor supply i think they have valspar now again brush on or rattle can thanks for any and all help i don't mind brushing or rattle cans also should i sand the primer at all i don't really want a super perfect car like finish since it is an old engine
---------- Post added at 09:43 PM ---------- Previous post was at 09:35 PM ----------
ps i plan to use a fine scotch brite pad on the primer to scuff it just a little thanks again
Old 10-05-2011, 10:51:20 PM
ehpower2's Avatar
ehpower2 ehpower2 is offline
Default Re: need a little paint help
i use dupi color engine enamel as it gas and oil RESISTANT and is heat resistant.
Old 10-05-2011, 10:54:51 PM
allright thats what i was thinking about using is it nessecary to clear over duplicolor engine enamel
Old 10-05-2011, 10:55:54 PM
ehpower2's Avatar
you can but i find it looks just fine as is. only time i use clear is over decals to protect
The Following User Says Thank You to ehpower2 For This Post:
Old 10-05-2011, 11:00:42 PM
ok sounds good thank you
Determining paint color from existing old paint Mike Rock Paint Shop 9 10-27-2013 03:37:38 PM
Forum Link (Paint Shop) If you are interested in OLD paint - Don't Miss This! Harry Hit & Miss Gas Engine Discussion 0 03-14-2008 09:27:47 AM
Forum Link (Paint Shop) If you are interested in OLD paint - Don't Miss This! Harry Steam Stationary Engines, Traction Engines 0 03-14-2008 09:27:47 AM
Stover CT2. to paint or not to paint guyver11469 Hit & Miss Gas Engine Discussion 3 10-20-2007 12:04:24 AM
New Gas Tank to Paint or Not to Paint!? eagleeyelee65 Hit & Miss Gas Engine Discussion 2 01-11-2007 09:40:53 AM
