Running Onan genset on Woodgas
this thread has 3 replies and has been viewed 3843 times
Old 11-26-2012, 06:20:54 PM
Default Running Onan genset on Woodgas
I have been feeding woodgas into my 65.NH on and off this summer, in an attempt to figure out how to reliably convert wood chips to electricity.
I'm getting closer, but I ain't all the way there yet.
Don't tell anybody, but I have been feeding the genset some pretty tarry carbon monoxide and hydrogen gas. But so far, the engine still runs fine.
If you have nothing else to do, you can see my log of this summer's related events at:
http://www.spaco.org/JXQ10A.htm
Pete Stanaitis
The Following User Says Thank You to Pete Spaco For This Post:
Old 11-28-2012, 02:10:27 PM
OTTO-Sawyer's Avatar
Default Re: Running Onan genset on Woodgas
Originally Posted by Pete Spaco View Post
....Don't tell anybody, but I have been feeding the genset some pretty tarry carbon monoxide and hydrogen gas. But so far, the engine still runs fine.
Pete Stanaitis
We won't tell anybody if you don't.
Keep us posted with your results, and any other details you care to share on how you set it up.
I've seen pictures and stories of cars, trucks, and tractors running on wood gas decades ago, and a few people experimenting with wood gas in modern pickup trucks with varying results. Always good to read up on more first hand experience.
It may not be for everyone, especially if they buy their wood pre-cut and dried, or go out and spend thousands on new chain saws, wood splitters, and truck or trailer to haul wood with, but for someone that already has an unlimited supply of firewood with little or no investment it can pay for itself in a very short time.
Old 11-28-2012, 06:51:39 PM
Harvey Teal Harvey Teal is offline
Pete, as you are probably discovering, the secret is in the gas filter. Once you get that worked out, life becomes easy. Best of luck with your project.
Old 11-29-2012, 11:01:49 AM
Yes, a final filter is important. I have been running the engine on gasoline for at least 10 minutes after every woodgas run to, hopefully, clean it up.
But the real goal is to get the gas temperature, just below the grate, up to at least 1000 degrees F. They tell me that this temperature will cause the tars to be burnt and/or "cracked" into non condensable gases.
The real improvement this year was to add an Arduino-based "datalogger" so I can tell how much progress I am making in this area.
Pete Stanaitis
Onan genset model #5.0 CCK stops running ater 10 or 20 min M.Linskens Onan Generators 15 04-26-2011 07:52:35 PM
Great! GenSet is running! But... BBear Onan Generators 6 08-01-2010 07:29:49 PM
Is anyone running Onan Gensets on Woodgas? Pete Spaco Onan Generators 6 12-06-2009 11:19:05 AM
Upgrading Jenbacher fm Natural gas to Woodgas tayyab Multi-Cylinder Stationary Gasoline Engines and Power Units 1 07-14-2009 06:19:26 PM
OK, The Power Is Out And Your Genset Is Up And Running, Robert in W. Mi. Generators & Electric Motors General Discussion 19 10-31-2006 07:50:05 AM
