Go Back   SmokStak > SmokStak® Shows, Swaps, Announcements > Shows and Swap Meets
Shows and Swap Meets Announcements, reviews, photos, movies and discussion about antique engine and tractor shows and swaps.
2017 North West Regional EDGE&TA Show!
this thread has 15 replies and has been viewed 2236 times
Old 01-27-2017, 12:03:30 AM
bigGURN's Avatar
bigGURN bigGURN is offline
Default 2017 North West Regional EDGE&TA Show!
We are excited to invite everyone to attend the show! If you are planning on coming, let us know below!
https://www.smokstak.com/forum/calen...&day=2017-6-16
The Following 3 Users Say Thank You to bigGURN For This Post:
Old 01-27-2017, 01:46:54 PM
OrgWayne OrgWayne is offline
Default Re: 2017 North West Regional EDGE&TA Show!
Gee I might have to drive over, around 9 hrs , but hay , looks like it would be a good show
Wayne
The Following User Says Thank You to OrgWayne For This Post:
Old 05-15-2017, 06:06:33 PM
bigGURN's Avatar
Getting close to show time!!! Today we started to put our float together for the upcoming parades that we will participate in to advertise the show... also we are doing live history for the fourth grade, so we decided to kill two birds with the proverbial one stone! We'll swap the mill out for a flat belt powered washing machine for the parades.
The Following 2 Users Say Thank You to bigGURN For This Post:
Old 05-15-2017, 07:02:27 PM
Toesmack's Avatar
Toesmack Toesmack is offline
Ken and I will both be there. Will PM you.
The Following 2 Users Say Thank You to Toesmack For This Post:
Old 05-23-2017, 10:32:28 PM
bigGURN's Avatar
More work getting ready for the show! Today we worked on Lauren's FBM 60hp Model N. The engine originally sat on a cement pedestal. As that is not real mobile, Lauren previously added a fabricated stand. Then he came up with this design that follows the shape of the OEM lower engine bases. While it is not cast iron, the steel it is made from is well aged and looks amazing!
Making the new base enables us to hide the fuel tank under the engine. Note the fuel tank filler (upper fitting) and drain (lower fitting) at the rear of the engine.
The Following User Says Thank You to bigGURN For This Post:
Old 05-23-2017, 10:40:00 PM
bigGURN's Avatar
Today we worked on routing the fuel lines. First we needed to get fuel to the pump (lower right). This required drilling a 5/8 hole through the new base to run the 3/8 brass hard line through. The hole for the line from the pump to the carb is factory (upper left).
Plumbing from the fuel tank to the pump is done with soft copper tubing as this significantly simplifies the whole process.
The carburetor is plumbed with a hardline from the pump to to the inlet side, again the hole for this line is original (upper right). The return line (lower left) is also brass that is plumbed in through the base, the 5/8 hole for it had to be added.
For the return line to the tank, we again used soft copper. As seen here the line feeding the carb is brass. This line was previously made, so we saw no reason to replace it.
As we work on other projects, I'll post "show ready" updates to this thread.
Old 05-27-2017, 11:53:26 AM
bigGURN's Avatar
Show banners are here! We'll be using these to advertise the show and get the word out!
The Following 4 Users Say Thank You to bigGURN For This Post:
Old 05-29-2017, 07:50:43 PM
bigGURN's Avatar
Worked on the Float for Twin Falls Western Days today! Western days are this weekend with the parade Saturday morning! Should be a great opportunity to advertise our show!
https://www.twinfallswesterndays.com/
Old 06-09-2017, 11:37:39 PM
bigGURN's Avatar
Lots going on to get ready for the regional!
The FBM 60hp will be there along with her sisters!
The show starts ONE WEEK from today!
Old 06-14-2017, 09:07:38 PM
bigGURN's Avatar
Two truck loads ready for tomorrow!
Old 06-14-2017, 09:27:32 PM
AKMark AKMark is offline
My truck and trailer are loaded up, we plan on leaving about 5 am, should arrive about noon.
The Following User Says Thank You to AKMark For This Post:
Old 06-18-2017, 08:27:48 PM
bigGURN's Avatar
WE had a GREAT turn out for the show! Over 150 engines and tractors with 18 different branches represented!
Old 06-18-2017, 08:28:56 PM
bigGURN's Avatar
Old 06-19-2017, 08:41:49 AM
You guys and gals did a great job. Your boys are are the finest young men I ever met
The Following 2 Users Say Thank You to AKMark For This Post:
EDGE&TA SW Regional Show Nick Huff Shows and Swap Meets 2 01-12-2014 10:40:54 PM
North west 80d miwbjs Farm Antiques and Collectibles 0 04-17-2013 09:27:03 PM
North West Antique Power Show Pics Skip Landis Hit & Miss Gas Engine Discussion 10 09-29-2010 06:07:05 AM
NORTHWEST REGIONAL SHOW DICK STAATS Antique Engine Archives 0 07-06-2004 10:36:38 AM
Northwest Regional Show Br. 74 John Ledbetter Antique Engine Archives 0 06-16-2004 08:15:20 PM
