Minneapolis 40-80 Complete Frame Off Restoration
this thread has 156 replies and has been viewed 62069 times
Old 04-23-2017, 06:19:32 PM
NDmeterman NDmeterman is offline
Default Re: Minneapolis 40-80 Complete Frame Off Restoration
Not much longer before another of your 'down the runway' videos then?
Old 04-24-2017, 09:56:36 PM
Super4 Super4 is offline
I probably have you trumped in the happiness category.
Old 04-25-2017, 02:25:31 PM
Tanner Remillard's Avatar
Tanner Remillard Tanner Remillard is offline
Love the sound of those big gears rolling over
Old 04-30-2017, 10:50:11 PM
Wendell Kelch Wendell Kelch is offline
We made noise today with the Minnie. I have some carb issues to take care of but it fired right up! This one has been a struggle but I think I can see the light at the end of the tunnel!We have a bunch of small things to get done like fuel line plumbing etc. But it is still neat to hear the first noise and see the fitst shop full of smoke! Here is a short video of the first run. Wendell
https://youtu.be/g4umh0nJMvk
Old 04-30-2017, 10:58:00 PM
texasbest texasbest is offline
Another Superb Job! Roby
Old 05-04-2017, 10:38:43 PM
We got the Minnie out to see daylight today.We are still fighting Gremlins but one by one they are going away. Here is a video of its first steps! Wendell
https://youtu.be/9bSkYMZuRu0
Old 09-26-2017, 03:31:50 PM
Casesteamer Casesteamer is offline
Any Updates Wendell?
Old 09-26-2017, 10:14:01 PM
Sorry for my tardiness! We had a new set of valve springs made and put on it and we had a push rod hanging on the manifold along with Justin helping me with the carb. I rolled the timing up where it belonged, got a bunch of fuel leaks stopped, Thightened the clutches up several times, Pulled the right bull pinion off and gave it some more clearance,Ran about 50 gal of gas threw it, Get the idea? This old girl was rough and if has been a long journey but we are getting close. We had to have the fenders special made. There are 120 rivets in each fender. and there are 4 pieces of sheet metel in each fender that has to be formed, fit and drilled to fit together. They are all done now and we are in the process of painting them. Then we have to jack it up ,slide the wheels out a little to get the fenders installed. I will put pretty pics. on most likely next week late. Here are some videos of me playing with it and working some of the gremlins out of it. The one at the bottom is the latest one where it is running on duel ignition where you can see it runs a little faster with both plugs firing .Wendell
https://youtu.be/uQAf0_NzT_M https://youtu.be/mRnlwTesybU https://youtu.be/xm3vzpR6RLg
Old 09-27-2017, 11:54:02 PM
1911LY's Avatar
1911LY 1911LY is offline
Absolutely incredible Wendell! What an awesome project.
Old 10-07-2017, 09:49:04 PM
We got the fenders on the Minnie this week.I took it for a ride around the runway and it ran sweet! We need to touch up some bolts and finish the truck oil lines and it is ready to go home! Wendell
ID:	293083   Click image for larger version
ID:	293084   Click image for larger version
ID:	293085   Click image for larger version
Old 10-07-2017, 10:06:29 PM
Another fantastic restoration Wendell.Exellent work
Old 10-08-2017, 02:40:09 AM
Briddle Briddle is offline
I was wondering how you have your ignition system set up thxs
Old 10-08-2017, 09:15:43 AM
It is running on magneto now. I have had it running on the dual ignition but we took it off to install the fenders. We have everything marked so when the owner puts the floor boards on he can just set it on the floor and hook it up. Wendell
The Following 3 Users Say Thank You to Wendell Kelch For This Post:
  #154
Old 07-21-2018, 09:04:06 PM
I’m Home!!! Thanks to Kelch’s Restoration and all the tradesmen, vendors, consultants, and moral supporters for their efforts and expertise. Somewhere Harold Ottaway is smiling.
ID:	314532   Click image for larger version
Old 07-21-2018, 10:44:20 PM
Now then, what of the cab that was shown on the first post on this thread?
Old 07-23-2018, 08:45:00 AM
maceymadness maceymadness is offline
Where is the cab?
Old 07-24-2018, 08:00:34 PM
It will be refurbished this winter.
The Following User Says Thank You to Super4 For This Post:
Stover restoration is complete! DaleP Hit & Miss Gas Engine Discussion 11 05-31-2012 11:06:18 PM
Gladden BB Restoration Complete Saukengines Small Air Cooled Gasoline Engines 4 05-01-2012 11:04:22 AM
2nd restoration complete! a jossund Hit & Miss Gas Engine Discussion 6 01-24-2012 01:44:16 PM
Restoration complete wydiver Hit & Miss Gas Engine Discussion 2 11-15-2009 05:27:54 PM
Oddball Piece Restoration Nearly Complete, Serial Tag Restoration Question bryani289swmi Small Air Cooled Gasoline Engines 2 04-15-2008 12:10:29 PM
