WK40 McCormick - How Many Are out There?
this thread has 149 replies and has been viewed 30902 times
Old 04-24-2018, 08:52:50 AM
Russ Hamm's Avatar
Default Re: WK40 Mccormick - how many are out there?
I can look but it might be tonight, maybe somebody will answer before then. I go by the red diamond truck engine torque specs.
Old 01-03-2019, 09:07:43 PM
MrBishop1 MrBishop1 is offline
Anyone know a source for a head gasket?
The Following User Says Thank You to MrBishop1 For This Post:
  #143
Old 01-15-2019, 11:31:14 AM
Olson Gaskets just sent me a whole gasket set. Wasn't advertised on their site but they had it.
The Following 3 Users Say Thank You to MrBishop1 For This Post:
  #144
Old 01-15-2019, 01:05:55 PM
Russ Hamm's Avatar
Here is one we picked up some years ago, put wheels on it and stuck it in the shed. Have since found a good gas tank and manifold, had to load it like this after the sale. Has a red diamond engine in it with distributor but has the mag mount.
I just remembered I needed to ask about starters, I recall a Minneapolis Moline and a John Deere starter will fit, any part numbers?
The Following 9 Users Say Thank You to Russ Hamm For This Post:
  #145
Old 01-15-2019, 10:35:25 PM
Russ...sometime I would like a closeup picture of how the throttle linkage got revamped as the stock tractor linkage will not work with a distributor installed.
Starters off of gas powered Oliver 77 and 88 tractors will work...also heard that the early McCormick W-9's that used the 3 bolt mounting flange will also work.
I see that yours has a Red Diamond oil filter base on it which is a nice upgrade as opposed to using the one off of the original FBB298 motor. I'm still on the search for one of these. Not all Red Diamond truck motors used the oil filter base with the filter can in the upright position. Red Diamond Power Units used the correct base but those are even harder to locate.
My W40 project is hung up on the radiator end. The radiator out of cracked block tractor leaked like a lawn sprinkler. The one out of the burnt tractor didn't leak but from what I could see of the cores almost all were plugged with rust. Still have one more to try but it's on a tractor carcass yet.
The Following User Says Thank You to Mark Schneider For This Post:
  #146
Old 01-16-2019, 11:29:33 AM
Russ Hamm's Avatar
Ill check that out Mark, its not too hard to get to but im chained to work until 6 every week day and its so darn dark lately. There are a few power units around here.
Thanks for the starter info, I have it all written down somewhere from years ago but …………….
The Following 2 Users Say Thank You to Russ Hamm For This Post:
  #147
Old 01-26-2019, 09:17:37 PM
Russ Hamm's Avatar
I took a picture its not too clear but you can see the grab handle type linkage that goes around the distributor. My other 40 was like that also but I changed the shaft after I removed the distributor and put on a magneto.
ID:	327207   Click image for larger version
The Following 4 Users Say Thank You to Russ Hamm For This Post:
  #148
Old 05-09-2019, 10:27:21 PM
Does the oil connection for the rocker valve assembly have a nut to cover the top of the oil line and force the oil into the rocker shaft?
Old 05-10-2019, 09:31:00 AM
Russ Hamm's Avatar
I know the red diamond engine gets oil through one rocker stand through a passage in the head...…….if I remember right. And the front and rear rocker tube have a sleeve in the center to connect each other for the oil flow. Havent had one apart for a long while, and never got to work on a tractor engine.
Old 05-10-2019, 10:45:30 PM
Yes it has a nut and it is similar to a pipe cap.
1. On the FBB-298 engine there is a hollow head stud located third from the back on the left side. The oil pressure that comes up through this stud is directed into the rocker arm shaft via this special rocker stand with the "eye" on the lower end.
2. #2 on this diagram is the capped head nut that applies pressure on the head gasket and seals the top of the hollow stud.
3. Description of the operation per a 40's vintage I&T shop manual.
Name:	W40 rocker arm 1.jpg
ID:	334547   Click image for larger version
Name:	W40 rocker arm 3.jpg
ID:	334548   Click image for larger version
Name:	W40 rocker arm 2.jpg
The Following 2 Users Say Thank You to Mark Schneider For This Post:
WK40 IHC Valve Settings beavis331 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 09-23-2018 03:13:42 PM
Mccormick 22-36? Tylerh Antique Farm Tractors 23 01-14-2016 03:28:28 PM
Going to look at a McCormick 10-20 Jack OH Antique Farm Tractors 1 07-22-2009 09:52:02 PM
Red 10-20 McCormick Kelly Barnett Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 04-30-2008 03:54:39 AM
parts wanted for wk40 jamie davey Antique Farm Tractors 2 07-19-2006 10:55:41 PM
