Model T Ford Blocks?
this thread has 7 replies and has been viewed 694 times
Old 06-07-2019, 05:57:52 PM
Jamie Darian Brown Jamie Darian Brown is offline
Default Model T Ford Blocks?
I have a Worthington tractor with a model T Ford engine. 1925 I think. With starter. It has a scorer cylinder from a loose wrist pin I have found a 1915 block. It’s a couple hours away from me. I live in 28325 NC. Will the 1915 block work to replace my 1925 26? Or are they diff
Old 06-07-2019, 06:23:16 PM
Jake Jacobs Jake Jacobs is offline
Default Re: Model T Ford blocks ?
What is the number stamped above the water outlet on the side of the block? 1925 block is different then the 1926 1927 block. Early block may still work.
The Following User Says Thank You to Jake Jacobs For This Post:
Old 06-07-2019, 06:35:41 PM
Bryant Bryant is offline
I don’t think it will have a place for the generator
Old 06-07-2019, 07:18:20 PM
Default Re: Model T Ford Blocks?
That 15 block is of much greater value than a 17-25 block. And no generator mounting .
The Following 2 Users Say Thank You to uglyblue66 For This Post:
Old 06-07-2019, 09:53:08 PM
Tracy T Tracy T is online now
cant help on block interchange, but you can have a sleeve put in your block and its not as expensive as one would think.
Old 06-07-2019, 09:57:03 PM
gleaner gleaner is offline
Go ahead and get the 15 block. If it is good you can sell it for about what it will cost to sleeve the 25 block.
The 15 block will work but you will have to change the generator and timing cover. Also if the 15 is complete and a true 15 then the flywheel will not be machined for a ring gear for your starter.
My advice is sell the 15 and have your block sleeved.
The Following User Says Thank You to gleaner For This Post:
Old 06-08-2019, 09:25:26 AM
The pm didn't work for some reason.Look for the website for Tarheel T's here in NC and if I aint bad mistaken a couple members have a good inventory of later blocks that you could buy reasonable for your project.
Old 06-08-2019, 10:27:04 PM
Duey C Duey C is offline
Ya, the 15 blocks are starting to get scarce. Like the guys suggest, get a newer block or fix yours.
Ford Model A, Model T Staude Golf Course Conversion and A Twin City cerwin Antique Farm Tractors 0 01-12-2017 06:49:05 PM
Ford Model B Thaumaturge Antique Farm Tractors 1 11-27-2016 06:36:15 PM
ford model tt Richard51 Magnetos, Ignition Coils and Spark Plugs 1 07-19-2015 06:49:28 PM
Model A Ford help please Mike Hole Antique Autos and Trucks 10 10-01-2012 07:29:31 PM
Ford Model A Redwing Antique Autos and Trucks 2 11-10-2007 11:07:23 AM
