De-scaling block on tractor?
this thread has 26 replies and has been viewed 1371 times
Old 08-12-2019, 02:45:57 PM
Russ Hamm's Avatar
Default Re: De-scaling block on tractor?
I ustabe crabby until I realized I wasn't Olympic material. If you cant reach the gold ring, and mediocrity isn't an option, might as well ride the bleachers.
The Following 2 Users Say Thank You to Russ Hamm For This Post:
Old 08-12-2019, 04:36:26 PM
Been working away with compressed air and picks and have a lot of that stuff out. Got the head pretty well cleaned.
Mice were in the no. 1 cylinder so that end of the head is a mess. Can't get the spark plug out yet. That bugger is almost welded in. More phun to come! Not a rush project - leave some work for the cooler fall days.
Old 08-12-2019, 08:47:35 PM
Jeremy Hartle Jeremy Hartle is offline
A continuous flow of water will do it if you can get enough flow. I've flushed a lot out just by adapting a garden hose to one of the coolant pipes and let her run. The hard part is getting the volume. You dont necessarily need lots of pressure.
The Following User Says Thank You to Jeremy Hartle For This Post:
  #24
Old 08-14-2019, 05:19:19 PM
tharper tharper is offline
Don't use muriatic acid! Its the gift that keeps on giving!
For the cylinder blocks on my big T-head Wisconsin I soaked them in a hot Lye solution to de-grease and remove as much paint, dirt etc. as possible. You want it as clean as possible!Then I used diluted Phosphoric acid for the rust.
I smeared grease in the bores and any other surfaces I wanted to protect from the acid. I fully submerged the blocks so the water passages were treated as well.
It worked wonderful and leaves a protective coat that's perfect for paint and will not rust-up immediately like muriatic acid will. In addition with muriatic you must make sure to rinse the parts off completely! And.... when you do that they immediately start rusting again.
The Following 3 Users Say Thank You to tharper For This Post:
  #25
Old 08-14-2019, 07:29:41 PM
Sunnybrook Sunnybrook is offline
I had great luck cleaning the individual water jackets on a Holt 45 last year. They were packed in the bottom and would not let water flow. The common galley in the block was also solid from sitting. I did not want to remove the cylinders to clean. I used a couple feet of small copper tubing and adapted it to a pressure washer tip and hammered the end flat with a small hole in the end. The copper could bend easy and feed down the passages of the cylinders to break up the solids.
It could poke into the small crevices and blast it out good.
The Following 7 Users Say Thank You to Sunnybrook For This Post:
  #26
Old 08-28-2019, 01:58:26 PM
barry ayres barry ayres is offline
if it was me i would think very hard about dropping out pistons and pulling liners very easy to do with the block still in chassis least you get a good look at rings and big ends whilst you are at it.
The Following User Says Thank You to barry ayres For This Post:
  #27
Old 08-28-2019, 04:36:24 PM
You might try Rydlyme - we use it at work on heat exchangers and it works well without degrading the metal...
Kevin
The Following User Says Thank You to kwfiggatt For This Post:
Block repair OldJalopy Machine Shop and Tool Talk 6 01-20-2014 08:37:18 PM
Tractor pull throws a block (probably OT) NDmeterman YouTube Old Iron Videos 3 08-11-2012 03:23:38 PM
New Guy on the Block MahleCleviteVRGaskets Smokstak Forums Meet and Greet 5 10-06-2011 07:34:58 AM
f\m block Donnie Devore Sr. Hit & Miss Gas Engine Discussion 0 08-11-2006 07:01:18 PM
(Scaling) Model Engines Smoke Antique Engine Archives 8 04-11-2004 09:21:21 AM
