Carburetors
this thread has 4 replies and has been viewed 1564 times
Old 02-09-2012, 03:27:07 PM
Steve Kreiner's Avatar
Steve Kreiner Steve Kreiner is offline
Default Carburetors
I just picked up a box of stuff from an elderly lady that was going to get rid of these. The first two pictures are of a Tillotson carb and the stamp on it reads MS54A The second is a Zenith and on the aluminun tag it reads AS 548 In the second set of numbers it reads S 1043 or 8 and what was wondering what they went on.
ID:	128299   Click image for larger version
Name:	tillotson carb 2.jpg
ID:	128300   Click image for larger version
ID:	128301   Click image for larger version
Name:	zenith carb 2.jpg
The Following User Says Thank You to Steve Kreiner For This Post:
Old 02-09-2012, 08:04:52 PM
Bob Krummel Bob Krummel is offline
Default Re: Carburators
Steve, according to a Tillotson carb list I have, MS54A is for a 1930-34 Novo Engine Co. model K.U.
The Following User Says Thank You to Bob Krummel For This Post:
Old 02-09-2012, 08:36:03 PM
Junkologist's Avatar
This is the Novo that your Tillotson would fit.
Mike
SmokStak member #146
The Following 4 Users Say Thank You to Junkologist For This Post:
Old 02-10-2012, 12:42:07 PM
mmcdonald mmcdonald is offline
Default Re: Carburetors
If the last diget is a 3 then it's for a LeRoi CR, MR, RR etc. if it's an 8 then it's a LeRoi S engine. Either one might fit variations or other engines I didn't do an extensive search.
info@mcdonaldcarb.com
The Following User Says Thank You to mmcdonald For This Post:
Old 02-10-2012, 12:57:10 PM
Whats the difference between the two CR MR and S
Tecumseh Carburetors Oberon67 Small Air Cooled Gasoline Engines 5 04-21-2010 10:16:42 PM
Tillotson Carburetors torence20 Small Air Cooled Gasoline Engines 3 11-07-2009 09:56:43 PM
Keihin Carburetors Bill Sherlock Small Air Cooled Gasoline Engines 8 06-20-2008 10:32:43 AM
Changing of carburetors Farmboy1 Hit & Miss Gas Engine Discussion 8 03-29-2008 08:48:53 AM
