Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm Antiques and Collectibles
Farm Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers and pumps.
Plastic gas tank repair
this thread has 8 replies and has been viewed 4394 times
Old 05-11-2012, 07:43:02 PM
ronny p 148 ronny p 148 is offline
Default Plastic gas tank repair
I have an ATV made in China I didn't buy it!! It's a gift for my 7 year old Granddaughter. The nipple where the gas line is split someone cut the gas line off and slit the nipple . i want to epoxy it the epoxy I have says it will not work on polyethylene or polypropylene . What can I use on it ? What can you stick in hole in nipple that I can get out after what you tell me to use as not to get repair in hole and plug it ?
Ronny
Old 05-12-2012, 08:19:36 AM
Matt Montague Matt Montague is offline
Default Re: Plastic gas tank repair
Ronny,
Can you get a bulkhead fitting into the tank and get the nut tightened up? If so this may be a longer term fix. More than likely if you can you will need to drill the hole oversize.
Just a idea.
Matt
The Following User Says Thank You to Matt Montague For This Post:
Old 05-12-2012, 10:49:41 AM
Tony Rye Tony Rye is offline
i take the bolt in type valve stem for an tire remove the core fish it down in the tank install with the rubber gasket on inside and outside tighten nut clamp hose on .been doing this for several years
The Following User Says Thank You to Tony Rye For This Post:
Old 05-12-2012, 04:30:24 PM
MD4302 MD4302 is offline
I've done this in the past.
Take the gas cap off and cut a sliver of plastic off at the top of the threads. Then use this piece as a filler and weld it with a soldiering iron.
Because it is the same material it will bond quite nicely.
The Following 3 Users Say Thank You to MD4302 For This Post:
Old 05-12-2012, 05:08:04 PM
I went to u-tube and it showed welding with soldering iron. But i think welding the split nipple would be a bugger . But if I messed it up I like the valve stem Idea. I want to try epoxy but from what I've read not many over the counter that will work on this type plastic. New tank only 14 bucks but heck of job to get plastic housing off ATV to remove it.
Ronny
---------- Post added at 04:08 PM ---------- Previous post was at 04:05 PM ----------
I like the cutting sliver off filler neck your shure plastic is same to weld with. Theres no place like here for sugestions on doing things.
Ronny
The Following User Says Thank You to ronny p 148 For This Post:
Old 05-13-2012, 08:53:11 PM
Alan Bowen Alan Bowen is offline
Have you looked at PC-7 ?
The Following User Says Thank You to Alan Bowen For This Post:
Old 05-13-2012, 09:06:03 PM
Or Seals-all
The Following User Says Thank You to Jim Tremble For This Post:
Old 05-15-2012, 05:18:08 AM
Originally Posted by ronny p 148 View Post
]I like the cutting sliver off filler neck your shure plastic is same to weld with. Theres no place like here for sugestions on doing things.
Ronny
It has worke for me in the past. One of the challenges of welding plastic is that what you use for 'filler rod' must be the exact same chemical compound as what you're welding. Salvaging a sliver off the filler tube will ensure that it's the same material.
As has been suggested use a soldering iron for your heat source.
The Following User Says Thank You to MD4302 For This Post:
Old 05-15-2012, 07:41:16 AM
Jake Jacobs Jake Jacobs is offline
Check out this website. http://www.stealth316.com/2-dp8005.htm. Any bodyshop will have the correct glue for the plastic tank. The same type of plastic is used on many auto parts. 3M make the glue.
The Following User Says Thank You to Jake Jacobs For This Post:
Fuel tank - desolder tank halves to repair? KD5BYB Small Air Cooled Gasoline Engines 8 12-04-2011 06:08:58 PM
Gas Tank Repair JD Gimpl Small Air Cooled Gasoline Engines 15 06-07-2010 02:33:08 AM
Plastic repair to scooter jopeter Machine Shop and Tool Talk 6 10-23-2009 08:25:02 AM
plastic gas tank repair CAnger Small Air Cooled Gasoline Engines 1 10-07-2006 07:12:02 PM
Gas Tank Repair? Johnny Antique Engine Archives 5 02-05-2003 01:29:30 AM
