Rumely X Carb Problem
this thread has 47 replies and has been viewed 4396 times
Old 09-12-2019, 02:21:02 AM
Donald J Donald J is offline
Default Re: Rumely X Carb Problem
You say your running off water tank. Have you plumbed the water tank to the kerosene compartment and needle valve on carb? If running fuel from water tank to water feed compartment on carb, that may be your problem as it will only draw very little liquid from this compartment unless under load. As there is very little vacuum when not pulling load. I know on the E,F and B that have the sliding throttle plate it works that way, you have to have fuel plumbed to kerosene compartment on carb not the water compartment. Thanks for listening. Hope you get it solved. DJ
The Following 4 Users Say Thank You to Donald J For This Post:
Old 09-12-2019, 07:44:30 AM
Is the camshaft ok? Are the valves acting properly? You haven’t got it parked to close to the Sawyer Massey have you? those Sawyer ghosts can get a bit moody.
The Following 2 Users Say Thank You to David Hoover For This Post:
  #43
Old 09-16-2019, 11:25:32 AM
Harold Kuret Harold Kuret is offline
Donald J,
Thanks for the reply. Yes we are plumbed to the kerosene side of the carb.
Cheers, Harold
The Following User Says Thank You to Harold Kuret For This Post:
  #44
Old 09-16-2019, 11:27:03 AM
Hi David,
It is far away from the Sawyer...it is parked next to our George White Steam Engine though,
I know colliding worlds.
The Following 2 Users Say Thank You to Harold Kuret For This Post:
  #45
Old 09-16-2019, 11:35:57 AM
Well, first Off I would like to thank everyone for taking an interest in my Rumley Situation.
I am happy to say it is running fine again.
We took the mag off an found it was only sparking when the impulse was tripping, when it ran fast, there was no spark. After much investigation the only thing we found was that the condenser wire had come off the coil. We soldered it back on and it still acted the same way. We pieced together a mag from parts and it works fine now.
We then re-assembled the old mag and it acts fine as well, So I can not explain exactly what caused the mag to turn the oil pull into a hit and miss tractor.
The only thing I can think of is the ground brush on the bottom of the mag was stuck. or some how it was grounding through the impulse detents.
It was an enjoyable day spent with the local magneto magician and although the puzzle has not been completely solved, the outcome is wonderful.
Thanks, Harold
The Following 6 Users Say Thank You to Harold Kuret For This Post:
  #46
Old 09-16-2019, 12:14:07 PM
I've heard 90 percent of all fuel problems are electrical.
The Following 4 Users Say Thank You to J.B. Castagnos For This Post:
  #47
Old 09-16-2019, 02:10:01 PM
Yayyyyyyyy!
  #48
Old 09-16-2019, 02:59:30 PM
Originally Posted by Harold Kuret View Post
Hi David,
They are particular on what they like to be parked beside and they dont like to get dirt and oil splatter from other tractors on them in particular from one of those dirty oil can Eagle tractors as they are a very clean about themselfs tractor they are a very high class machine...only certian people can make them puke oil.All jokes aside glade to hear you got everything worked out with your tractor Harold
20-40 G Rumely Oil Pull Pulley Problem Jon Rozevink Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 08-03-2016 11:13:33 PM
Rumely L model fuel problem Norm Johnston Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 17 01-22-2013 05:18:35 PM
H Rumely Main Bearing problem Gasengin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 02-17-2012 12:18:06 AM
Gas problem on 20-30 Rumely Mike McKnight Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 14 10-21-2007 11:20:13 AM
X Rumely Steering Shaft Removal Problem?? Gasengin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 07-07-2007 12:52:59 AM
