John Deere E Truck cart - how to tell if original?
this thread has 7 replies and has been viewed 2816 times
Old 09-22-2012, 12:56:34 PM
dw1973 dw1973 is offline
Default John Deere E Truck cart - how to tell if original?
How do you tell the difference between an original JD E truck cart and a reproduction?
Old 09-22-2012, 01:12:52 PM
Rich Mueller Sr's Avatar
Rich Mueller Sr Rich Mueller Sr is offline
Default Re: John Deere E Truck cart - how to tell if original?
Hey Jim White where ya at ,here is a man that knows more about John Deere,s than anyone I know!!!!!
United Gasoline Engine Registry www.augermo.com
Old 09-22-2012, 04:07:51 PM
Turbo's Avatar
Turbo Turbo is offline
If it is not rotted out and welded it is a reproduction!!
The Following 4 Users Say Thank You to Turbo For This Post:
Old 09-22-2012, 05:55:24 PM
Danny Danny is offline
Smile Re: John Deere E Truck cart - how to tell if original?
The wheels should have the part number casted on one of the spokes. (E44R) As for the front a rear axles I am not sure. As there are no numbers stamped or casted on them. Hope this helps.
The Following User Says Thank You to Danny For This Post:
Old 09-22-2012, 06:48:48 PM
Mike Monnier's Avatar
Hoarder
The front axle pivot pin, or whatever you pin call the axle steers on, is hollow on an original. The reproductions are cast solid.
The Following 3 Users Say Thank You to Mike Monnier For This Post:
Old 09-22-2012, 07:44:03 PM
Hoarder
Here's a picture I lifted from the Aumann site. Note the hollow "pin" I mentioned and that the front bolster has a part number cast into it. You can also see the number cast into the wheel.
The Following 10 Users Say Thank You to Mike Monnier For This Post:
Old 09-24-2012, 09:28:27 AM
Gary Pflum's Avatar
Gary Pflum Gary Pflum is offline
Is the "R" in the part number (E44R) left off of the repro cast wheels? Seems to me years ago I had heard that was a way to tell.
Old 09-24-2012, 12:14:10 PM
Hoarder
Reproductions generally have no numbers cast into them. I'm sure there are exceptions to the rule if somebody had one cast off of a buddy's cart.
1937 John Deere unstyled B Original wheels?? 55gasser Antique Farm Tractors 3 06-07-2012 09:25:55 AM
1945 John Deere Lindeman Crawler (not factory original) JDcrawler Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 13 04-25-2011 12:57:48 PM
Original John Deere instructions Turbo Hit & Miss Gas Engine Discussion 6 06-14-2010 11:44:25 PM
John Deere Model E - Original Paint Deere4020 Hit & Miss Gas Engine Discussion 1 08-10-2009 01:12:05 PM
John Deere truck Mike Antique Engine Archives 1 07-07-2001 11:27:47 AM
