Fairbanks Morse Single Cylinder Tractor Project
this thread has 388 replies and has been viewed 137679 times
Old 10-21-2012, 04:54:34 PM
Wendell Kelch Wendell Kelch is offline
Default Re: Fairbanks Morse Single Cylinder Tractor Project
I got back today from Helpling a friend put with his show in S.C. I figured I better get to work before I got fired! You would be suprised what one man ,one torch and one bridge crane can get done on a Sunday afternoon when there is no phone or people coming in to bother him! Wendell Kelch
ID:	147593   Click image for larger version
ID:	147594   Click image for larger version
ID:	147595   Click image for larger version
Old 10-21-2012, 04:58:29 PM
A little more wrenching and Lifting!
ID:	147597   Click image for larger version
Old 10-21-2012, 05:01:04 PM
A few more
ID:	147599   Click image for larger version
Old 10-21-2012, 05:11:57 PM
I got tired of working on it right side up so I thought I would turn it upside down and work on if for a while. Not bad for a Sunday afternoon! My guess it will take a LITTLE longer to put it back together! It is 5-O Clock in Bethel so I think I am going to call it a day! I wonder if anyone needs a sled? I think I am done with it. Wendell Kelch
ID:	147601   Click image for larger version
ID:	147602   Click image for larger version
ID:	147603   Click image for larger version
Old 10-21-2012, 10:46:00 PM
HBurk HBurk is offline
Todd,
My Granddad told me one time, "remember, don't get excited".
Old 10-22-2012, 07:31:42 PM
We finished tearing down the Fairbanks today. The Shop that is making the frame came and got it today. The next picture of this frame should be a lot prettier.
Wendell Kelch
ID:	147713   Click image for larger version
ID:	147714   Click image for larger version
ID:	147715   Click image for larger version
Old 10-22-2012, 08:09:00 PM
OTTO-Sawyer's Avatar
It'll be nice to see another one of them up and running again.
Used to have one at the Freeport Illinois show in the 1970s that was all original unrestored and still had an amazing amount of paint and pin striping on it. And it Sounded Nice !
---------- Post added at 07:09 PM ---------- Previous post was at 07:06 PM ----------
I'll try to Thank as many of the posts as I can when the button returns again, starting with the older ones, and catching up from there.
Old 10-22-2012, 09:09:45 PM
Eric Best's Avatar
Eric Best Eric Best is offline
Ok, Wendell - What is Peter's ex 45 Mogul doing at your shop??
The Following 3 Users Say Thank You to Eric Best For This Post:
  #49
Old 10-22-2012, 10:11:58 PM
My hat's off to you fellers!!
Old 10-23-2012, 09:32:57 AM
Looks like a fine start!
Old 10-23-2012, 07:14:12 PM
Brad Hauck Brad Hauck is offline
Wendell Kelch
I recognize that guy. His shop does excellent work. The toolbox he just made for our 14-28 Rumely is perfect.
Brad Hauck
Old 10-25-2012, 05:46:19 PM
We have been doing battle with the back wheels and lugs for 2 days! There are 60 lugs and 3 rivets per lug so that makes 180 rivets that needed to be blown off and the rivets beat out of the wheels and pressed out of the lugs. 2 tanks of gas and 2 boxes of caldo rods and a bunch of sweating and talking to them they are off. I need to press 9 more rivets out of the cleats and they are ready for the sand blaster. It looks like a IN THE MORNING job! Wendell Kelch
ID:	147974   Click image for larger version
ID:	147975   Click image for larger version
ID:	147976   Click image for larger version
Old 10-25-2012, 07:23:32 PM
Good work & progress, Wendell. Are those Oilpull radiator sections in top center of last picture?
Old 10-28-2012, 10:34:10 AM
Lou Buice Lou Buice is offline
Here is a link to a 1912 Fairbanks Morse tractor, serial no. 112994 threshing wheat at the annual steam and gas engine show in Vista, CA yesterday:
http://www.youtube.com/watch?v=LP3ZNhQCMfI
Old 11-01-2012, 08:28:25 PM
We got the first PRETTY parts today. We got the 60 lugs sandblasted this eve. Got the water pump apart,blasted and ready for the machine shop. The NEW front and rear axle came in today as well as the frame metal.The mixer came apart and the throttle butterfly even loosened up. The bowls are a little more rusty . That is tomorrows project. If all goes well the rear wheels will be headed to PA. to be made like new this weekend.
ID:	148427   Click image for larger version
ID:	148428   Click image for larger version
ID:	148429   Click image for larger version
Old 11-01-2012, 08:32:54 PM
The lugs had 180 rivets in them. Here is what a box of180 used rivets looks like . We put the lug in the press and every time the rivet came loose it sounded like a gun went off. They was TIGHT !
ID:	148431   Click image for larger version
Old 11-02-2012, 07:28:44 PM
Is there any history available on the tractor? What it did or where/when it was first discovered, etc.
Brad Hauck
Old 11-02-2012, 08:09:33 PM
texasbest texasbest is offline
Where did the 2 bolts come from in the 3rd picture by the visegrips?
Is that premature wear on the them
Is this a design flaw ? since this tractor was not used more than it was. You better write the company and let them know!
Old 11-02-2012, 09:19:59 PM
The 2 bolts are the connecting rod bolts. They was made that way to go threw the brass bearing block. I will let the Texas boys tell the story on where it came from and when it was found. I want the story told correct .I know the high points. If I am correct the Fairbanks never left the farm from the time it was delivered new intil it left to come and be restored. Texas stakers help me out! Wendell Kelch
The Following User Says Thank You to Wendell Kelch For This Post:
  #60
Old 11-02-2012, 09:58:32 PM
OK, that makes sense. It looked too uniform to be wear.
I'll have to pass on the history lesson for now. I do know that research is being done to try to learn more about it. The family that owned it that's still alive doesn't know anything about it except that they used to play on it as kids and apparently they are in their 50's or 60's now. A good friend of mine tried for 40 some-odd years to buy it (he poured the 5 gallons of oil in the cylinder back then.) He's promised a ride/drive on it next year... Is it a 1913 model per the engine # ? Keep up the good work!
The Following 2 Users Say Thank You to texasbest For This Post:
Fairbanks Morse 32E 80hp Single Cylinder James Hill Vintage Diesel and Oil Stationary Engines 34 10-25-2012 05:01:21 PM
Fairbanks Morse single cylinder engine value troyjohnson Vintage Diesel and Oil Stationary Engines 4 09-25-2012 06:25:47 PM
3 cylinder and 2 cylinder Fairbanks Morse Diesels Randy L Peterson Vintage Diesel and Oil Stationary Engines 0 09-14-2011 01:23:46 PM
Large Rumely single cylinder tractor Andrew Gibb Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 05-12-2011 03:08:58 AM
Fairbanks Morse Model 45 - Single Cylinder Diesel Ted Rozanski Antique Engine Archives 0 07-29-2002 01:11:32 PM
