1927 Allis 20-35 rescued from long sleep
this thread has 151 replies and has been viewed 25537 times
Old 07-12-2014, 04:13:24 PM
Default Re: 1927 Allis 20-35 rescued from long sleep
Hello all,
Time for an update...wish it was better news, but the big Allis has a cracked head. When it sits coolant will drip into a cylinder. It will start on three, blow antifreeze out the exhaust and then hit on all four. Continued running time will result in coolant making its way into the oil pan.
I cannot find the crack so it must be internal and I need to locate a head for dear old Allis to get her back in good form again. Just a bump in the road and we all get a few of those with this hobby. Any leads on a reasonably priced head would be apreciated. I was told the newer orange heads will not work...is that so?
Thanks everyone and good luck on your projects!
Tony
The Following User Says Thank You to Tony Thompson For This Post:
Old 07-12-2014, 08:40:48 PM
JW in MO JW in MO is offline
That stinks, you reckon that's why it was parked? Might know where one is, not very far from you.
The Following User Says Thank You to JW in MO For This Post:
  #143
Old 07-12-2014, 10:30:33 PM
Gene Williams Gene Williams is offline
Tony, sent you a message through engine ads. Will get you fixed up with what you need.
Gene
The Following 2 Users Say Thank You to Gene Williams For This Post:
  #144
Old 07-12-2014, 11:25:26 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
The later heads are considerably different, but I believe they will bolt up as we have a late E with one of each on it. The real early one could be even more different but I'm not sure as we don't have any 18-30 around these parts. F.J.W.
  #145
Old 07-13-2014, 02:13:00 AM
A big thanks to Mr. Williams for helping out! Here's hoping it's something that is fixable so the head can be reused to live another day.
The Following 2 Users Say Thank You to Brasherman For This Post:
  #146
Old 07-13-2014, 01:12:08 PM
Caleb Carpenter Caleb Carpenter is offline
Those heads are horrible about cracking. I have a whole pile of late heads I think are good but the exhaust stud area is just a cast tab that is broke off. Some have bolts brazed to the heads.
Frank didnt you get set of heads from us? Or was it just a set of wheels?
The Following User Says Thank You to Caleb Carpenter For This Post:
  #147
Old 07-13-2014, 01:38:36 PM
FWurth's Avatar
One Millionth Post
Caleb, yes we got a couple of bare late heads from you. The plan was to replace the odd set on the late 25-40. We also have a 20-35 that a tree fell on and broke the water out let towers on. Hopefully those can be repaired. I used to send those broken heads to Jerry to repair but since his health problems have sidelined him that's no longer an option. Maybe I simply need to take up the task and learn to weld them myself, Jerry did lecture us many times as to the procedure. If I take on a junk one to start with who knows, If it don't work oh well no loss but it should be doable. If the tab for the exhaust stud is all that is wrong with them it should be an easy repair. I know that type of head also likes to burn through in the exhaust port area as well. Jerry would always build those areas up as well and remachine them. Tony I was rereading this thread and when you were talking about the excess exhaust note while plowing I noticed that the out let is aimed at the driver. If you rotate the stack so it points to the front and in the 2 o'clock position it will make a dramatic difference and still reserve that wonderful sound. The construction equip companies did this and even sent out bulletins out to advise us to do this to avoid hearing loss! F.J.W.
  #148
Old 07-15-2014, 01:30:49 PM
m jorstad m jorstad is offline
dont forget those sleeves like to crack on the top. i have old sleeves that look good on the inside but on the out side are cracked.
The Following 2 Users Say Thank You to m jorstad For This Post:
  #149
Old 07-15-2014, 09:35:11 PM
Valid point. You might have to get the heads magnafluxed before you give up on them.
Old 11-01-2014, 08:34:18 PM
I forgot to let everyone know that a replacement head has the early short fender Allis running well again! Our very own Smokstakker Phil Johnson from Canada got me a pressure tested head...Thanks Phil One head had a crack up inside of it somewhere. A mechanic friend of mine put his flexible camera in the plug hole and we could see coolant drip from port above intake valve.
I also forgot to mention that this machine has been fitted with a big bore kit moving it from 4 3/4 to 5 inch. Running the math produces 510 ci. No wonder it barks so loud and pulls four sixteens with ease
Pictures of the finished tractor are in posts #129 & #132 on page seven.
What a grand old machine...it starts, runs & drives excellent with big power!
Tony
The Following 9 Users Say Thank You to Tony Thompson For This Post:
  #151
Old 11-02-2014, 08:50:54 AM
J Ware J Ware is offline
Well Tony, I hope I have as good as luck with the cyl. blocks of my 21-32 TC engine as you did with the big Allis engine. Coolant leaks can be troublesome and annoying to say the least, expensive. Glad you got it fixed, Jim
The Following User Says Thank You to J Ware For This Post:
  #152
Old 11-02-2014, 11:30:18 AM
Phil Johnson's Avatar
Glad to hear it's back up and running, Tony. Only too glad to help out.
The Following 2 Users Say Thank You to Phil Johnson For This Post:
Early 1919 Twin City Rescued From Long Sleep Tony Thompson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 176 06-13-2014 08:06:44 PM
Can't sleep until I get this engine! Elwood Hit & Miss Gas Engine Discussion 28 02-19-2011 10:16:29 PM
one more sleep Sawyer-Massey 11-22 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 12-25-2006 10:56:56 AM
