Steam Engines
Impact of flywheel width on dyno
this thread has 1 replies and has been viewed 1548 times
Old 05-11-2013, 10:11:09 PM
Beth V's Avatar
Beth V Beth V is offline
Default Impact of flywheel width on dyno
Here's my favorite McLaren Road Locomotive Boadicea pulling on the dyno. Several thoughts:
  • That has to be fun (NOT) to belt with such a narrow flywheel.
  • I wonder if it would pull more hp than 100 if the flywheel was wider so they could use a wider belt? ..especially as it operates at like 210 psi (if my memory serves)
  • Is the noted "100 hp" on the same scale as ours?
  • That safety valve impeded my ability to hear the engine work.
  • Does anyone know how this "dyno" compares to our dynos & prony brakes over here?
http://www.youtube.com/watch?v=Ja026iAjVvQ
Old 05-12-2013, 09:32:18 AM
Default Re: Impact of flywheel width on dyno
A wider belt will transmit more power and would help only if the belt slips as it did right at the end but I suspect it slipped on the dynomometer end as that pulley is much smaller in diameter.
A.D. Baker Impact Mill A.D. Baker Farm Antiques and Collectibles 4 03-15-2012 10:44:50 AM
Does anybody know the maximum width for an atv at the florida flywheelers show Dave L M Hit & Miss Gas Engine Discussion 9 10-23-2011 08:10:29 PM
What is your show turnout? Economic impact? mikefrommontana Steam Stationary Engines, Traction Engines 12 01-30-2011 12:57:07 AM
Wheel face width Meco3hp Hit & Miss Gas Engine Discussion 0 10-23-2009 01:57:15 PM
Good place to buy a impact screw driver Walt in Jaxn Tn. Small Air Cooled Gasoline Engines 11 04-27-2008 02:58:54 AM
