Waterloo Boy Experimental Tractor (Bathtub D) Restoration
this thread has 258 replies and has been viewed 95591 times
Old 07-20-2013, 01:21:01 AM
Question Re: Waterloo Boy Experimental Tractor (Bathtub D)Restoration
I'm looking and looking and looking but can't see what will hold the clutch engaged.......
I'm figuring the groove at the right in the sliding collar is for the shifter but what will keep it engaged?
Old 07-20-2013, 09:49:24 AM
Eric Best's Avatar
Eric Best Eric Best is offline
Default Re: Waterloo Boy Experimental Tractor (Bathtub D)Restoration
Craig - I suspect the ball toggles that are pinned to the collar go over center as their pivot point passes under the point where the toggles engage the clutch arm. They would very temporarily be too tight then relax just a bit as the collar pushes the pivot point past center. Just guessing.
The Following User Says Thank You to Eric Best For This Post:
  #63
Old 07-20-2013, 11:24:57 AM
Wendell Kelch Wendell Kelch is offline
Correct Eric! The 2 rollers roll over top each other as the collar is being pushed inward and the springs on the bands(Not Shown SORRY) will compress so give room for them to pass and will remain locked over center until it is pulled back to be disengaged. The bands, adjusters and springs have to be added and then it will make more sense. Thanks for the input ! It takes a bunch of input to get this thing right! Wendell Kelch
The Following User Says Thank You to Wendell Kelch For This Post:
  #64
Old 10-08-2013, 11:40:20 PM
30-90 Russell 30-90 Russell is offline
I found these two images messing around on the computer tonight, so I thought I would post them as they might have some relevance.
Zach
ID:	176860   Click image for larger version
The Following 6 Users Say Thank You to 30-90 Russell For This Post:
  #65
Old 10-09-2013, 10:21:03 AM
FWurth's Avatar
FWurth FWurth is online now
One Millionth Post
Their the real item but I wonder why the date listed on them is 1930? That's over a decade later than the thing was being planned. F.J.W.
Old 10-09-2013, 10:27:48 AM
Jeff Wahl's Avatar
Jeff Wahl Jeff Wahl is offline
If you look closely, it was filed in 1921, patent office can take a while!
-Jeff
wahlengines.com
The Following User Says Thank You to Jeff Wahl For This Post:
  #67
Old 12-06-2013, 04:26:07 PM
LukeSte LukeSte is offline
Wendell, I was wondering if this one is on hold to get the new big project done? that one will take up a good portion of the shop compared to this deere... good luck on both of them.
Old 12-06-2013, 09:50:52 PM
It has been back on the burner since the last Fairbanks went home. We are working on making the pattern now for the belt pulley casting. Will be posting progress SOON!! Wendell Kelch
Old 12-21-2013, 10:36:25 PM
We got the pattern back this week for the belt pulley. It looks great! It is ready to be mounted to a board and head to the foundry. Wendell Kelch
ID:	182578   Click image for larger version
ID:	182579   Click image for larger version
The Following 15 Users Say Thank You to Wendell Kelch For This Post:
  #70
Old 12-21-2013, 10:45:22 PM
We also got the pattern back for the brake drum. We got the recast front axle back a while back. It has to be remachined to fit the tractor. The owner is coming down tomorrow so we can bounce some ideas around. Am excited to be back on this project again! Wendell Kelch
ID:	182581   Click image for larger version
ID:	182582   Click image for larger version
ID:	182583   Click image for larger version
Old 01-05-2014, 08:05:37 PM
RustyRelics UK's Avatar
RustyRelics UK RustyRelics UK is offline
Hello all,
I was just browsing on youtube and came across this video, I thought you guys may not have come across it as it only had 20 views. Seen as this subject is on the topic of JD and prototypes
http://www.youtube.com/watch?v=T-b7SEbV-N4
Thanks,
Carl
The Following 2 Users Say Thank You to RustyRelics UK For This Post:
  #72
Old 01-05-2014, 10:08:12 PM
I was at don dufner's over the weekend for d parts for two different d's. I brought my iPad with and showed him the pictures and was excited to hear it is getting done. He was there when it was discovered and being excavated. He said at the show all of a sudden more people were coming over to the excavator to see what was going on, as did he. He thought the excavator sold it for a case of whiskey....None the less he is happy to hear that progress is being made.
The Following User Says Thank You to LukeSte For This Post:
  #73
Old 01-05-2014, 10:51:53 PM
Carl;
Isn't that a common wide front GP? Dad had a tricycle Gp two row row crop. An uncle had the wide front one. Neither were successful. They both sold about 25-30 years later after sitting in barns all of that time.
Old 01-05-2014, 11:41:16 PM
FWurth's Avatar
One Millionth Post
Ed, it looks like it sits closer to the ground. The front axle isn't arched for row clearance like the normal ones, Also the rear drop housings appear to have been turned a quarter turn to lower the rear closer to the ground. F.J.W.
Old 01-10-2014, 10:58:47 PM
Dan thomas Dan thomas is offline
Originally Posted by RustyRelics UK View Post
Hello all,
Thanks,
Carl
the video is from lindeman archives ,they are the ones that started making crawlers from JD tractors [d crawer,gpo crawler,bo crawler]for orchard work. that gp in the film looks like it has a 'd' front axle,but the splindle comes out of the bottom of the axle.also the steering and seat are lower than a gp standard. Dan
Old 01-10-2014, 11:31:54 PM
Could it have been a BEANER front axle? It was a lot heavier.We are working on patterns for the castings that need to be poured For The Waterloo Boy EXP. We are making headway. Will have more soon.Wendell
The Following 3 Users Say Thank You to Wendell Kelch For This Post:
  #77
Old 01-21-2014, 06:28:55 PM
We got the pictures back today for the shift fork patterns and the steering wheel and rear shifter pattern. I wanted to share them with everyone. More in a few days Wendell
ID:	185566   Click image for larger version
ID:	185567   Click image for larger version
ID:	185568   Click image for larger version
Old 02-12-2014, 10:22:02 PM
I got word today that the some of the cast iron parts have been poured that we drew up and made patterns for! Thay are getting ready to pour the steel parts soon. The machinist will be finishing up one of the clutch engaging plates this week. The belt pulley and the brake pulley is at the foundry now and will be poured within the week. We have several restorations going on at once. Will put more pictures on as soon as the parts get here. Wendell
Old 02-22-2014, 05:09:59 PM
Here are two cast iron parts for the EXP Waterloo Boy. They are the front shifter support tha the clutch drum. These are the first 2 parts that have went from drawings in our heads to cast iron parts. Next step is to machine them and bolt them onto the Tractor. Wendell
ID:	188699   Click image for larger version
Old 03-17-2014, 03:40:41 PM
We got some more castings in for the EXP today. We got the belt pulley-clutch casting and the brake drum casting. We already had the clutch drum casting so it is good to see it fits inside the belt pulley.the bely pulley weighs 120#.We got a bunch more parts cast and in shipping now. Wendell
ID:	190876   Click image for larger version
ID:	190877   Click image for larger version
ID:	190878   Click image for larger version
Not quite a BathTub Pump GreasyIron Steam Stationary Engines, Traction Engines 14 08-03-2015 03:58:50 PM
Mystery Tractor - Experimental Hart Parr? Big 4-20 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 09-25-2014 12:23:49 PM
16 HP Waterloo Restoration Paint Question Harold Kuret Steam Stationary Engines, Traction Engines 9 09-18-2014 03:07:54 PM
John Deere B Experimental Tractor? SteamTractors Antique Farm Tractors 4 12-28-2011 12:09:54 AM
Peeking out from underneath a bathtub, Cushman Cub dalmatiangirl61 Hit & Miss Gas Engine Discussion 45 11-17-2011 02:44:52 PM
