Minneapolis 40-80 Complete Frame Off Restoration
this thread has 156 replies and has been viewed 62057 times
Old 12-21-2013, 10:56:21 PM
Wendell Kelch Wendell Kelch is offline
Default Re: Minneapolis 40-80 Complete Frame Off Restoration
We got the frame steam cleaned this week and got the draw bar back from being repaired at the weld shop. The draw bar is the first thing that goes in the frame when it goes back together. The sand blaster is due here Monday to get started making it pretty. Wendell Kelch
ID:	182585   Click image for larger version
Old 12-22-2013, 10:20:30 PM
Ed Bays Ed Bays is offline
Hey Windell, I've been hearing about this project, through Vince, even before you started. What are you doing for lugs and skid rings? As you know, we need some for our 35/70...ED
Old 12-23-2013, 11:09:12 AM
LukeSte LukeSte is offline
this is a great thread already Wendell, thanks for the frequent updates. looks to be another great project and divide and conquer will make it go quickly.
Old 12-23-2013, 09:47:02 PM
Kurt Kocher Kurt Kocher is offline
When your ready for piston rings I would like to get a set for ours if you have a good source. Thanks!
Old 12-23-2013, 11:41:26 PM
We got the frame blasted today. It was a cold day here in Bethel, Ohio so it was nice and warm in the blast suit! There was not a lot of daylight left when we got done . It is in the paint shop safe and dry and ready to be prepped for its shinny coat of gray paint. Wendell Kelch
ID:	182795   Click image for larger version
ID:	182796   Click image for larger version
ID:	182797   Click image for larger version
Old 12-24-2013, 12:43:02 AM
Nebraska Kirk Nebraska Kirk is offline
WOW! Green grass and no snow! There is 6" of snow here and now it is UP to 8 degrees, 3 hours ago it was -5!
---------- Post added at 10:43 PM ---------- Previous post was at 10:41 PM ----------
I am curious, how long did it take to blast the frame and how much sand did you use?
Old 12-24-2013, 08:43:41 AM
With the set up ,blasting , putting it away and cleaning up the barrels and pallets about 7 hrs. I didn't count the empty bags but my guess 10 to 12 100# bags! This morning it is 15 degrees with 1 in of snow on the ground. You have to pick your days for outside work here and also a day the blaster is off work from his regular job so a lot of things got to come together! If everything works out we are going to blast some smaller parts Friday. Not near as big a deal for little(littlier) pieces . The big stuff has to be completed and stored inside the same day or you lose everything you did that day! Wendell Kelch
The Following 8 Users Say Thank You to Wendell Kelch For This Post:
  #28
Old 12-27-2013, 06:34:42 PM
We tackeled the transmission shaft this week. What a pain! Everything was tight but the inner clutch drum was impossible to get off. I even used some old school tricks I learned out on service calls 50 miles from nowhere when all I had was a log chain and a bottle jack to get a hub off! No Luck! I wil show you how I got it in the next post
ID:	183154   Click image for larger version
ID:	183155   Click image for larger version
ID:	183156   Click image for larger version
Old 12-27-2013, 06:45:18 PM
I got to the point where I was going to break that drum if I got any rougher with it so I decided I could make a shaft a lot easier then a drum so I got my porta band saw out and sawed the 4 in shaft in two! It took a while but better then a hack saw! I then got the gear out of the way and took it to a BIG press and 25 tons is what it took to move the shaft out of the drum! I don't think the spokes on the drum would have stood for 25 tons! We lost a shaft but saved a drum. All is well! This is one of those jobs that leaves you with a lot of sore fingers but you are glad to still have all 10! Wendell Kelch
ID:	183158   Click image for larger version
ID:	183159   Click image for larger version
ID:	183160   Click image for larger version
Old 12-28-2013, 10:43:29 PM
Brad Hauck Brad Hauck is offline
As dad and I say sometimes. Every tool in the shop was out today. Another very interesting project from the Kelch repair team.
Brad Hauck
Old 01-03-2014, 12:31:23 PM
This Minnie has a direct drive for low gear and 2 snap over center clutches and drums for reverse and high gear. So it has a early power shift where you can change directions without disengaging the main clutch. There is 8 clutch pads on the 2 drums and with all the pins and linkages there are around 50 pieces in the hi and reverse gear clutches.All needing new pins, welded up ,turned down or bored and rebushed. All the parts are scraped ,blasted and in primer. There are a lot of big and little pieces in a big tractor! Wendell Kelch
ID:	183833   Click image for larger version
ID:	183834   Click image for larger version
ID:	183835   Click image for larger version
Old 01-03-2014, 11:17:48 PM
We sandblasted transmission gears today. The crap on them was like concrete. When we started out this morning the temp. was just above ZERO! 4 hrs later when we finished it had got up to 10 degrees! with the before and after pictures you can see how much better things look cleaned up. Thank goodness for block heaters in the air compressor! We got 3 pallets blasted today. Wendell Kelch
ID:	183891   Click image for larger version
ID:	183892   Click image for larger version
ID:	183893   Click image for larger version
Old 01-04-2014, 12:23:48 AM
Norm Johnston Norm Johnston is offline
Wendell a couple of places in Australia made it to 49.2 degrees centigrade Yesterday, boy what a contrast to your temperatures.
great work again on another old girl keep up the good work.
Norm
The Following User Says Thank You to Norm Johnston For This Post:
  #34
Old 01-04-2014, 03:40:24 AM
NDmeterman NDmeterman is offline
Whoa! Norm - that works out to 120 F! That's quite a dramatic comparison to the subzero temps up here!
The Following User Says Thank You to NDmeterman For This Post:
  #35
Old 01-05-2014, 05:20:15 PM
Road building season will be here before you know it.
Brad Hauck
The Following User Says Thank You to Brad Hauck For This Post:
  #36
Old 01-05-2014, 05:27:43 PM
There is always belt work to do also. Check out the head lights on the front of the frame.
Brad Hauck
  #37
Old 01-05-2014, 07:00:17 PM
I think this Minnie must have built Interstate 75 singlehanded! She was used a lot!
The Following 5 Users Say Thank You to Wendell Kelch For This Post:
  #38
Old 01-08-2014, 06:54:14 PM
jmac35 jmac35 is offline
I feel sorry for this old girl. Good job Wendell
Old 01-09-2014, 04:34:56 PM
We started putting grey paint on Minnie parts this week. We are going to try and get a few more pallets blasted this weekend. If all goes well the frame will be painted next week. Wendell Kelch
ID:	184386   Click image for larger version
ID:	184387   Click image for larger version
ID:	184388   Click image for larger version
Old 01-09-2014, 05:26:25 PM
Ahhhh,
Something on the order of battleship gray...a simple shade of gray color that I have learned to appreciate.
Hey Wendell,
I see a lot of blasting sand on the ground around your worksite. When it is time to retire, you can dig a pond and the sandy beach will already be there waiting for you!
Tony
The Following 2 Users Say Thank You to Tony Thompson For This Post:
Stover restoration is complete! DaleP Hit & Miss Gas Engine Discussion 11 05-31-2012 11:06:18 PM
Gladden BB Restoration Complete Saukengines Small Air Cooled Gasoline Engines 4 05-01-2012 11:04:22 AM
2nd restoration complete! a jossund Hit & Miss Gas Engine Discussion 6 01-24-2012 01:44:16 PM
Restoration complete wydiver Hit & Miss Gas Engine Discussion 2 11-15-2009 05:27:54 PM
