David Bradley help
this thread has 6 replies and has been viewed 1605 times
Old 10-02-2014, 06:26:07 PM
Ron Davis's Avatar
Ron Davis Ron Davis is offline
Default David Bradley help
Hi all what are these David Bradley Tri Trac worth??
Name:	david brabely.jpg
The Following User Says Thank You to Ron Davis For This Post:
Old 10-02-2014, 08:11:53 PM
Default Re: David Bradley help
Dear Ron That is an interesting question that is hard to answer. The tractor shown looks to be in nice condition. Does it have the original clutch drive system. Many have been bastardized because of failure of the original unit and are no longer available. Does it have the original wire screen over the pulley on the left side. Original engine, correct rear tire [not a car tire] Front and rear rims should be a green color. Seat should also be a greenish color with buttons to hold it down. We [my sons and I have 3 in our collection] but only one is all original. I They are bringing some good money but haven't seen a price on one in several years. In the past [10 or so years ago] I saw prices from $500 to $ 2000 depending on originality and condition. Of course Garden tractors have gotten very popular in the past few years. We bought all of ours for less than $300 each but that was nearly 20 years ago. They are quite interesting but be careful when making sharp turns because they have a tendency to tip over. There are many implements made for them but are pretty hard to find today. Good Luck on your quest. Ed B
Old 10-02-2014, 11:26:08 PM
4BadHotrodBrent's Avatar
4BadHotrodBrent 4BadHotrodBrent is offline
Mine was bought for about $400 four years ago. All the tires were totally rotten, worn out engine, no clucth, no right hand side sheild, cracked speed changer pulley with a host of other missing or broken odds and ends. The one in the picture that you posted looks to be modified? If so, it will naturally depreciate its value. Parts are NOT easily found. So if you want one original "restored with original drive train ect." be prepared to spend some cash upward and past $3,000. Or buy one cheap, missing most of its parts and spend countless hours and money trying to put it back to "original" condition for the same price. No matter which way you do it you will definately have a very unique tractor that will stand out for sure ! Not knowing much about the tractor pictured I would say that it is for sure worth over a $1000 worth off parts if it was a little butchered and didn't run.
Mine isn't no where close to original but it is by far one of the most enjoyable I have ever owend!
http://www.smokstak.com/forum/showthread.php?t=118431
Brent
Old 10-03-2014, 05:20:30 AM
Kris Golden Kris Golden is offline
Bought this one for $50 with a $10 delivery fee because it was an hours drive away.
The Following 2 Users Say Thank You to Kris Golden For This Post:
Old 10-03-2014, 06:46:55 AM
Holy Mackerel !!! Then there's just hitting the lotto !!!!! Nice tractor Kris!
Old 10-03-2014, 07:54:15 PM
Kris $60 for a Tri Trac in that condition is unbelievable. That would have been the price 40 years ago. Ed B
Old 10-03-2014, 08:31:05 PM
Well now it was rough when I got it.
Engine was stuck, although it was easy to free up. The tires were rotted clear off, and the seat pan was rusted out. It was also missing the side panels although it did have the correct clutch and air filter. I found side panels on Ebay but they weren't cheap. $285 with shipping.
For some reason every fin was broken off the flywheel.
It also came with the 5 foot mower deck and I have since bought a sickle mower for it.
David Bradley happyfoot Garden Tractors and Mowers 12 08-20-2013 02:00:07 PM
My David Bradley edsfarm Garden Tractors and Mowers 3 02-05-2011 11:34:27 AM
David-Bradley Sonny Reese Garden Tractors and Mowers 8 08-19-2010 12:29:02 AM
David Bradley tedwitt Antique Farm Tractors 2 01-02-2009 11:45:11 PM
david bradley help please Justin Woodard Hit & Miss Gas Engine Discussion 1 10-30-2005 05:53:31 PM
