McCormick WK-40 FBB to Red Diamond RePower
this thread has 161 replies and has been viewed 31634 times
Old 12-20-2014, 04:08:37 PM
Mark Schneider Mark Schneider is online now
Default Re: McCormick WK-40 FBB to Red Diamond RePower
Eric...I spark tested the front engine hanger and it is definitely steel. However it appears that the rear engine support is cast ?!? You certainly have had your share of challenges on your RD conversion...but always remember that this is a hobby and not an addiction so if a particular project isn't enjoyable anymore let it sit until it perks your interest again. I'm sure you will get it together someday.
A little detour from the regular RePower programming here...I'm at the point where I'd like to put the shortblock in the tractor frame and I'm giving serious thought to giving this thing some kind of paint job. I"m paint and sandblaster illiterate so any advice would be appreciated here. This tractor was originally a dark gray with red wheels. Anything that is reasonably close to the original colors is OK as long as it easily obtainable and easy to work with. Undoubtedly this subject has been discussed on another thread so any links would be appreciated. Thanks
Name:	WK-40 RePower 44d.jpg
ID:	213871   Click image for larger version
Name:	WK-40 RePower 45d.jpg
Old 12-20-2014, 05:02:35 PM
Eric Best's Avatar
Eric Best Eric Best is offline
Yes, the rear hangers are castings. They can be because they aren't nearly so delicate as the front hangers.
Didn't mean to give the impression I wasn't enjoying the hobby. The challenges are a big part of why we do it. I'm thoroughly enjoying this thread so thanks for keeping it rolling. A lot of people ask me how it is to retrofit one of these engines. It's one thing to talk about it but it is so much more to actually see it happen. Many will benefit from the information you are sharing. As a side note, I have heard people over the years - some tractor collectors - say upon encountering a 40, "look, somebody just put an IH truck motor in that old 22-36!"
In a way they are right but it was IH that did it. Seeing what it takes to actually do the repower should be all it takes to disabuse them of the notion that a w40 is just a thrown together tractor.
Old 12-20-2014, 10:27:39 PM
Eric: What is the diameter of the rod & main bearings when they are standard? Also I know of two shops around here that will "sleeve" main bearing caps and saddles to build them back up to standard?
Old 12-21-2014, 05:37:39 PM
Eric Best's Avatar
John - for the FBB here are the bearing specs from a 1950s FM service book for Std. Crank diameter - FBB w/ Heavy crankshaft:
Rods 2.2470 to 2.2480
Mains 2.7005 to 2.7015
The housing bores are:
Rods 2.362 ( I think w/ 4 0.003" shims on notched side only of rod (rods using shims - not all do))
Mains 2.875 ( I think w/ 2 0.003" shims on EACH side of main cap)
If you could send me the info for the shops that "sleeve" the main saddles and caps, I would like to talk to them. Maybe my block with the spun thrust main could be saved. Of course that it is a thrust bearing will complicate matters.
Thanks,
Eric.
Old 12-21-2014, 05:42:09 PM
Hi John
I assume that the engine you are inquiring about is the FBB 298 that Eric described in post #7?
FBB....crankpin dia. 2.248"
FBB....Main brg dia. 2.700" Housing bore....2.875" non- piloted caps
I think that Eric had mentioned attempting to sleeve the damaged main brg bore on this engine in another thread. I"m thinking that with his recent acquisition of a NOS FBB block that this idea got shelved as a block with this much damage could be a real money pit.
You will find the Red Diamond engine is much more substantial in the crankshaft department.
RD....crankpin dia. 2.75"
RD....main brg dia. 3.25"
Hope this provides you with some of the info you were seeking.
Eric... I see you beat me to it!
Old 12-21-2014, 05:54:24 PM
Eric Best's Avatar
That's just one of several FBB blocks I have to try to save, unfortunately. I actually wasn't going to sleeve the saddle and cap. Frankly, I'm not quite sure how this would work. Some shops will flame spray the casting in this area then remachine it on larger diesel blocks. If it came down to it, I'd prefer to machine new main bearing shells that were oversized on the OD and shorter between the thrusts. In any event, I don't absolutely have to save the block at this point but it could come to it later on.
The RD definitely has a superior crankshaft.
Old 12-21-2014, 07:21:12 PM
gleaner gleaner is offline
I'll throw in a little note on this issue. In 1937 My Grandfather decided to replace the 1930 22-36 with a new IHC. Salesman who came out to the farm talked him into a new W-30. When Grandpa went to pick up the new tractor and stood in front of it he said "this thing is too small for us". So he then decided on the W-40 with round spoke rubber, starter and lights. I have the bill of sale hanging on the wall. A couple of years later a block man for IHC told him that the W-40 was indeed a quickly put together idea as the plan was for the W-30 to replace the 22-36 but they found it was too small for the plains. I have seen archive photos of the 6 cylinder truck engine in a 22-36 frame in development but the engine was too fast for the gearing. The result was the W-40 with that noisy reduction gear, (the weak spot of the tractor). That 1937 W-40 was used on our farm until 1958. It always was my Dad's favorite tractor.
The Following 6 Users Say Thank You to gleaner For This Post:
  #28
Old 12-21-2014, 11:23:56 PM
Eric Best's Avatar
Ed - I also have a picture from the IH archives of a W-40 chassis fitted with a 22-36 engine (likely a 300 power unit complete with K-5 carburetor and top exhaust manifold) by IH engineers when they were trying to figure out how to undo that disaster of an engine that was the FBB-298. The tractor never made it to production but it was an interesting detour.
Old 12-22-2014, 02:10:32 AM
Nebraska Kirk Nebraska Kirk is offline
I have been giving some thought to putting my RD450 into an F30 as I have one with a bad engine. I thought it would make for an interesting re-power.
Old 12-22-2014, 01:34:26 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Most of the F-30s in this part of the world were used for hot rod pulling tractors back in the late 60s. So to find a complete one is difficult. They do lend them selves to conversion fairly easily, most used the small block Chevy motor. The big issue was to get the gear ratio right as the truck and car motors run considerably faster. F.J.W.
Old 12-22-2014, 03:00:01 PM
Gleaner...Thanks for sharing some of your family history. Always interesting to hear it from someone who's been there. Since you have had the opportunity to see a W-40 in the real farming world I would appreciate your comments on the following questions I have:
1. Is there much performance difference between the 22-36 with the P-300 engine improvements and a stock W-40?
2. Were the first Red Diamond repowers farmer initiated for farming purposes or did this come about because of the tractor pulling fever of the 70's?
Old 12-22-2014, 03:35:49 PM
FWurth's Avatar
One Millionth Post
I too am looking for more info on these tractors. There were only a few of the W-40s in the area, of those 2 were repowered with the truck motor. One was to replace a shot original motor and the other one was changed to pull a larger tillage tool in the 50s. They all had belt driven hydraulic pumps added to handle the newer implements. Another question I have was about the diesel version, did they introduce it first and then the gas version? If so was the gas indeed a reaction to demand for people who were preferring gas vs diesel or was the W-30 expected to fill that market as mentioned above. The 22-36 was very popular here and we have both it and did have a W-30, the latter was no match for the 22-36. This is row crop country here and the F-20 was king till the Letter series came out. F.J.W.
The Following 2 Users Say Thank You to FWurth For This Post:
  #33
Old 12-22-2014, 06:02:46 PM
The Diesel version of the W-40 was built at the same time. I had owned WD-40 #526 and traded it to Ivan Burns for a 10hp Advance steam engine. It went to Nebraska at Ivans sale years ago.
The stock W-40 was the powerhouse of the day. But remember ground speeds were slower than we use today. Now this was before me, but my Dad loved the W-40 and would talk endlessly about it. In the 30's my Grandpa farmed 5 quarters with a W-40 and tricycle U M-M. The W-40 having lights and starter was run round the clock plowing. When it was used only during daylight hours and lunch was brought out at 4:00 there had better be 15 gallons of gas brought out too. That large gas tank lid was handy for pouring into without a funnel. The weak point was the gear reduction. Many times it was replaced during the years that it was our big tractor. I think the engine was overhauled once but that gear reduction was repaired atleast 4 times.
I do know that during silo filling our W-40 was used instead of the 21-32 at Great Grandpa's place because the W-40 pushed thru better. But after running both in the field I prefer the 21-32 Twin City over the platform of the W-40. In reguard to the repowering most I know of were done because the truck engine is larger and parts were more available. The block is beefier between the sleeves. I think it had to do with the truck engine was cheaper to buy and put in than overhauling the stock engine. Also in Western Kansas many gas burning W-40 got 3 cylinder Jimmy engines put in them. Now that is an engine you can hear running 5 miles away!
The Following 5 Users Say Thank You to gleaner For This Post:
  #34
Old 12-22-2014, 06:50:14 PM
Old-F20 Old-F20 is offline
Or take a 22-36 engine and make an 'F-40' kind of prototype
Old 12-22-2014, 07:15:31 PM
I would like to do that, but need to find a 22-36 engine yet.
Old 12-22-2014, 07:25:16 PM
RustyRelics UK's Avatar
RustyRelics UK RustyRelics UK is offline
I have always admired the W40 range, and thought about adding one to my fleet but the scarcity of parts over here in the U.K has always put me off the idea ....
Great thread by the way, I'm learning all the time, Thanks
Carl
Old 12-22-2014, 10:32:50 PM
Eric Best's Avatar
Try to cover a bit of history here as best I can. The IH experiments with diesel engines in the 22-36 chassis date back to about 1927 or 1928. The engine was not theirs, initially. Similarly, they had experimented with 6 cylinder engines in similar configuration in the late 1920s and early 1930s. Guy Fay pictures some of these early attempts in his Prototype Tractors book. The engines that would finally be used in the 40 series were not new by the time the W40 series entered production. They had been introduced in the TA-40 in 1932 and the TD-40 in 1933. IH Gas Power Engineering photographs from March of 1934 show tractors Q-2609 and Q-2610. I have to pull my photos to know which was which but one was listed as W40 with 4 3/4 x 6 1/2 4 cylinder diesel and the other was W40 with 6 cylinder 3 5/8 x 4 1/2 or words to that effect. In March 1934 IH approved a pre-production run (tractors with real serial numbers but before the assembly line was started up) of 3 diesels and 7 6-cylinder tractors. The diesels were numbered 501 - 503 and the 6 cylinder tractors numbered 504-510. In April of 1935, the WD-40 was approved for production at tractor 508 but they actually ran 504 - 507 through the production assembly line with 504 arriving in mid April of 1935. 504 was used as the first number at the start of the assembly line because 503 was the number of the last WD-40 built (a year earlier) up to that point. Here's were it gets confusing. The WA-40 was not ready yet. In May or June of 1935, preproduction WA-40 511 was built. 511 was used because, up to that point, 510 was the last WA-40 built the year before. In June or July of 1935, WA-40 522 was built. Probably pre-production WA40 512 through 521 were all built as well. By June of 1935, WD production was already well past this number. In September 1935, IH authorized production of the WA-40 beginning at tractor number 934. That's not because 523 through 934 were built but because the decision was made to synchronize serial numbers between the WD and the WA and the WDs were already to the high 800s when the decision to enter WA production was made. So, you can see there is overlap of serial numbers - but not for long. 510 exists, for example, both as a gas tractor and a diesel tractor but there is over a year between when WA-40 510 and WD-40 510 were built. It is unlikely that many preproduction WAs after 522 were built. In terms of production and pre-production, the diesel came first. With experiments (Q number tractors) it's hard to say which came first. I own WD-40 503. Diesels 501, 502, and 504 also still exist. WD and WA-40 510 both still exist. I believe preproduction WA-40 506 and 509 both still exist. The 1935 instruction books for the WA-40 and WD-40 also cover the few pre-production tractors that were released in early 1934. Unique parts for these pre-production tractors are marked with an asterisk in the book with the footnote that the parts are "used on a few tractors, only". How true.
Per Wayne Sorenson, renowned W-40 expert, a good 22-36 w/ P300 upgrades will outwork a stock W-40. Wayne and his dad farmed with used W-40s in South Dakota. Also, much farming was done with repowered W-40s long before tractor pulls were their main purpose. A typical modification related to me by Ron Johnson of Kansas was to remove the extra reduction shaft and weld the two piece transmission center shaft solid when doing the repower. This and an RD406 or 450 got you a tractor that could actually work in the field at 6MPH plus - well beyond the ground speed of the original tractor. It also eliminated the annoying whine generated by the extra shaft in the original configuration. People often ask, "If the RD450 engine was so great why didn't IH just use it in the first place?" Timing is everything. The RD-450 didn't exist when the W-40 was in production. Even the FBB-450 (a rare engine to be sure) was barely around. I believe it was also a dry sleeve engine while the smaller FBB was wet sleeve. IH liked their wet sleeves but it was the weak block casting that went along with this and the vibration of high speed engine without counterbalanced crank that caused many blocks to crack, sometimes all the way to the main saddles.
---------- Post added at 08:32 PM ---------- Previous post was at 07:46 PM ----------
The first WK-40 bore chassis number 1441 and was built around December 22, 1935. The WK would be produced for only one model year - 1936. The WA was produced for 1935 and 1936 model years with possibly a few WA and WK tractors built as very early 1937 models. From then on, the 6 cylinder tractor became known as simply the W-40. The W-40 was built from 1937 to 1940. The WD-40 was built from 1935 to 1940. The WD-40 didn't sell well and three digit serial number tractors (1935 models) were still being pushed by the branch houses with discounts as late as 1937 or 1938. A few early WD-40s rode the state fair circuit in 1935 and 1936 and were likely painted all red to get attention (an early version of the IH Demonstrator!)
I speak badly of the FBB 6 cylinder but with regular oil changes and little lugging, they could provide years of service. It's just at that time, many farmers weren't quite up on what it took to keep a high speed engine going. Putting the RD450 or similar in (what this thread is really about) makes a real nice tractor out of them.
I will be giving a couple of brief lectures on the 40 series at the IH Winter Convention in Michigan City, Indiana, this coming March and plan on sharing some photos, facts, and surmises at that time. If any of you are planning on attending the Winter Convention, I'd enjoy getting together to visit about the 40s.
The Following 13 Users Say Thank You to Eric Best For This Post:
  #38
Old 12-23-2014, 12:39:03 AM
Eric...Thanks for very informative post. Some of this recent discussion helps explain why the W-40's had a good survival rate even though they had a rather small production run. And as Eric pointed out timing probably played a big part in this. My line of thinking goes something like this:
All W-40's are built prior to WW2 and are the big tractor going into the war. The W-9's are not very easy to get during the war and those that do get them find out that that the older W-40's are still a close match in the drawbar department. IH trucks with the RED and RD motors get very popular after WW2 and into the 50's and repowering the W-40's becomes an option and keeps it's field performance competitive through the Super W-9's, the 600's and the 650's. It appears that the first serious competitor is the IH 660 and by this time the "W-40" generation is retiring and the younger generation is upgrading.......
There probably also another big factor here and that would be how much disposable farm income was available during this time. The generation that grew up in the depression was very creative to make improvements when their budgets did not allow replacements. I find these farmer modified tractors most interesting. Several of these still exist locally....the pair of TC 17-28's on steel that both pulled 4-14's up until the late 50's. Then there's the TC FT that has the high compression G Moline parts that pulled 4-14's at 5mph...motor locked up while on a feed grinder....pulled out back and left to the elements...
They are still around but sadly not as plentiful as they was once were.
Eric...Have you considered recording these lectures and posting them on Youtube?
Old 12-23-2014, 10:11:21 PM
Eric Best's Avatar
Mark - I think folks get quite enough of me in these posts! Video would be more than they could stand.
With respect to the 660 and the rest of the 60 series, they represented IH's first attempt to build another 6 cylinder farm tractor following the W-40 - roughly an 18 year hiatus. The introduction of the 560 was not without its hiccups, again, primarily related to the speed of the engine and the way it interacted with the gearing.
Old 12-23-2014, 10:20:09 PM
FWurth's Avatar
One Millionth Post
Being a long time user of the Big Red, I have often pondered why they didn't simply extend the block and add 2 more cylinders to the 4 cyl engines used in the M and it's big brother in the W-9 for their gas motors on the newer models instead of adapting the too light duty pick up truck motors. Those time proven motors were way better suited for the job. F.J.W.
Gravely repower help teachingscience Garden Tractors and Mowers 1 05-05-2014 09:50:14 AM
1969 Cub Cadet 125 Repower - Wisconsin AGND K-Tron Garden Tractors and Mowers 29 04-14-2014 03:59:02 PM
IH Silver Diamond Verses Black Diamond Engine Gary Pflum Antique Autos and Trucks 6 02-06-2013 12:19:11 PM
Older 15KW Onan -- repower or replace?? rlg999 Onan Generators 3 09-20-2011 08:28:37 PM
Hatz Cub Cadet Repower Pictures dieselfreakcjw Garden Tractors and Mowers 7 02-27-2009 01:54:30 AM
