McCormick WK-40 FBB to Red Diamond RePower
this thread has 161 replies and has been viewed 31646 times
Old 12-29-2017, 11:27:55 PM
Default Re: McCormick WK-40 FBB to Red Diamond RePower
Eric...Thanks for the wealth of info you've supplied on this project! These lights would then be different than the stock 40 lights as these are 9" drum style. Lenses and ring size are very close (but not quite) to the large Ford Model A headlamps. If I can round up the necessary hardware parts I would probably use them as the buckets aren't rusted through and the mounting brackets are correct.
I've seen that starter rod in the parts book. I take for granted that it was a similar set up to the Farmall A's and B's?
The Following User Says Thank You to Mark Schneider For This Post:
Old 12-29-2017, 11:34:59 PM
Eric Best's Avatar
Eric Best Eric Best is offline
Mark - yes, same starter mounted switch and rocker like the A and B tractors. Various folks have reproduced portions of the lighting and starting kit. I have battery box covers. Another fellow has battery box brackets (more of an open frame than a box). Still another fellow has the headlight brackets. I need to do the governor cover for the generator mounting.
The Following 3 Users Say Thank You to Eric Best For This Post:
Gravely repower help teachingscience Garden Tractors and Mowers 1 05-05-2014 09:50:14 AM
1969 Cub Cadet 125 Repower - Wisconsin AGND K-Tron Garden Tractors and Mowers 29 04-14-2014 03:59:02 PM
IH Silver Diamond Verses Black Diamond Engine Gary Pflum Antique Autos and Trucks 6 02-06-2013 12:19:11 PM
Older 15KW Onan -- repower or replace?? rlg999 Onan Generators 3 09-20-2011 08:28:37 PM
Hatz Cub Cadet Repower Pictures dieselfreakcjw Garden Tractors and Mowers 7 02-27-2009 01:54:30 AM
