Rumely 12-20 Restoration
this thread has 140 replies and has been viewed 27525 times
Old 02-10-2015, 12:39:12 AM
LukeSte LukeSte is offline
Default Re: Rumely 12-20 Restoration
Ok. pulled the pistons. huh, something missing.... ring missing on eash piston. Ring gap north of .050 inch. doesnt show in the pic that well but the wear on rings very uneven. cylinder bores look good other than a crosshatch.
ID:	218175   Click image for larger version
ID:	218176   Click image for larger version
The Following User Says Thank You to LukeSte For This Post:
Old 02-10-2015, 12:41:41 AM
Anyone here remember or have experience as to what I will need here for gasket material or packing and size?? plan to drop the tranny now too to get all gaskets done.
ID:	218178   Click image for larger version
  #23
Old 02-10-2015, 09:06:49 AM
fyn409 fyn409 is offline
Others with more experience can chime in, but I remember reading that he un-even wear is pretty normal on these size/type of rings.
-Ryan
Old 02-10-2015, 10:17:45 AM
Ellis Wellman Ellis Wellman is offline
The rings were made with an eccentric bore so that the thick part would provide a stiffer "hinge" action for the split ends.Ergo,greater and more even ring force against the cylinder bore.Not a defect--a plan.
Good for Rumely and their supplier.
The Following 2 Users Say Thank You to Ellis Wellman For This Post:
  #25
Old 02-10-2015, 05:38:02 PM
Ross Clarke's Avatar
Ross Clarke Ross Clarke is offline
Do you know about when this tractor came out of Ontario?
The Following User Says Thank You to Ross Clarke For This Post:
  #26
Old 02-10-2015, 09:48:18 PM
I believe between 2-3 years ago
Old 02-11-2015, 08:11:56 AM
Bubbles Bubbles is offline
Did it come out of the Orillia area of Ontario?
I believe that tractor was originally owned by a family with the last name of Clark down around Port Hope/ Belleville area.
The Following 2 Users Say Thank You to Bubbles For This Post:
  #28
Old 02-13-2015, 05:27:46 PM
First pretty parts for the k. tucked away for a long cold nap. otto engines, a site sponsor, has thr new rings on the shelf....unti tomorrow when they will be mailed out. feels like progress.
ID:	218445   Click image for larger version
  #29
Old 02-13-2015, 05:53:16 PM
Also when measuring rings I noticed I had one stuck ring and one busted ring.... Glad I pulled them out.
  #30
Old 02-13-2015, 07:25:04 PM
Yes bubbles I do believe or orillia correct. Shed some more history if u can.
  #31
Old 02-16-2015, 12:08:22 PM
first round of pretty green parts. they threw me a fit in the painting process because of the nasty pitting, the sharp edges kept showing through. so I reduced the reducer to keep the paint thicker, more time between coats, and more coats of paint. could have made a lot of these parts new, just a lot of flat stock and with a shear and punch, would go fast, but certainly should keep the original parts where I can. hopefully this week I can get the engine all back together less the head, that piece is gonna need so work
ID:	218693   Click image for larger version
The Following 4 Users Say Thank You to LukeSte For This Post:
  #32
Old 02-16-2015, 03:29:57 PM
Rod Gaffrey Rod Gaffrey is offline
Do you have plans to dismantle the entire transmission?
Old 02-16-2015, 08:31:20 PM
The initial plan is to drop the trans and flip it over. take the cover off and have a look. when I drained the oil I saw nothing suspicious. if it looks fine, I will put in gaskets,seals,packing etc and put it back in the frame. if it needs to go apart it will. nothing suspicous though. I may not take off pinion gears because they wont be replaced anyway.
Old 02-17-2015, 01:01:28 AM
two pistons, too many problems, but all resolved....the lubricator had to have been run empty at some time. lots of rough areas to work over. I started with a file but that quickly grew boring. grinder with flap brush I was afraid would be too rough. so I used the one in the picture. if you ever need to clean up a plow bottom, this is the thing to have. they dont remove metal, unless you really lay into it in a stationary spot.... the pictures represent before and after.
ID:	218802   Click image for larger version
ID:	218803   Click image for larger version
The Following 6 Users Say Thank You to LukeSte For This Post:
  #35
Old 02-17-2015, 01:04:40 AM
When cleaning carbon off the top of the piston with the grinder and the same pad, I come upon this farmer fix. looks to be fine....maybe a bit scary but we will go with it.
  #36
Old 02-17-2015, 01:10:07 AM
Each rod had these numbers. think it was 15 12. the other 15 13. small shallow stamped in. guessing sequential numbers were weighted or balanced in pairs??
ID:	218809   Click image for larger version
Old 02-17-2015, 01:17:39 AM
Final results. also had a loose bolt on a wrist pin. drilled bottom land for oil rings. all lands got a screwdriver and hammer to get carbon out. whew. ready for rings....
ID:	218815   Click image for larger version
Old 02-17-2015, 02:56:13 AM
Alastair Geddes. Alastair Geddes. is offline
Might be good idea to check the piston to bore clearance at several spots and pistons wear on several locations.
The Following User Says Thank You to Alastair Geddes. For This Post:
  #39
Old 02-17-2015, 07:27:05 AM
JSWithers JSWithers is offline
It might be a good idea to smooth off the high spots on the brazing as they can become hot spots for preignition.
Old 02-17-2015, 09:52:51 AM
yep, going to check bore clearance tonight, just simply got too late last night to go any further. hope its ok, think it should be..
Restoration of Rumely # 6153 Jerred Ruble Steam Stationary Engines, Traction Engines 25 10-22-2013 09:47:29 AM
WDM 16-30 Model H Rumely Restoration Western Development Museum Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 10-31-2012 10:24:08 PM
Rumely 30-60E-restoration help required.... jim burlingham Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 11-27-2011 11:54:37 PM
Rumely Oil Pull restoration questions... jim burlingham Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 10-15-2010 06:58:06 AM
Rumely 25-40X Restoration, need parts Exmax Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 08-07-2010 06:11:34 PM
