Atlas lathe
this thread has 2 replies and has been viewed 1359 times
Old 05-16-2015, 09:34:00 PM
Jerry B Jerry B is offline
Default Atlas lathe
on my lathe the main shaft where the chuck goes on the two oil cups the one by the chuck you can fill it up and the oil don't go down, do you think the race has turned
Old 05-17-2015, 06:16:56 AM
Default Re: Atlas lathe
As a possible test, try a lighter oil like 3in1. (Not meant for real lubrication, so don't bother telling me it isn't good oil!) The thinner viscosity may wick in a tighter fit; indicating NO BLOCKAGE. It might be just a nice tight fit that doesn't seep much. If the 3 in 1 seeps in just go back to recomended oil.
For perhaps a better test you might put a mechanics stethescope on the bearing and give it a listen. I'm sure a spun bearing wouldn't run quiet.
As an FYI, if you don't have them already you can download manuals for Atlas from: http://www.lathes.co.uk/atlas/index.html
Doc
Old 05-17-2015, 07:00:09 AM
Dale Barnett's Avatar
Dale Barnett Dale Barnett is offline
Just unscrew the oil cup and look.
Could be oil crud build up in the cup also.
The Following User Says Thank You to Dale Barnett For This Post:
Atlas Lathe Jerry B Machine Shop and Tool Talk 11 02-15-2015 03:38:44 PM
Atlas/Crafstman Lathe GeneratorGus Hit & Miss Gas Engine Discussion 10 01-21-2012 03:14:58 PM
Need help with a 1932 Atlas lathe Rapidrob Machine Shop and Tool Talk 4 12-31-2010 12:06:20 AM
Atlas Lathe Year? Jeff Smith Machine Shop and Tool Talk 4 10-16-2005 08:05:46 PM
Atlas lathe parts-thanks. lester bowman Antique Engine Archives 2 10-24-2004 12:07:22 PM
