Rumely Oil Pull L 15-25 Parts and Advice Wanted
this thread has 174 replies and has been viewed 20811 times
Old 01-26-2016, 09:12:59 PM
CBarth66 CBarth66 is offline
Photo Re: Rumely Oil Pull L 15-25 Parts and Advice Wanted
Another thing I was wondering about was the round piece with the hole in it and the line that goes to the carb. Does that go over the hole where the throttle rod hooks in the carb? What is supposed to go in that hole? Are there any round belt pulley covers out there to be found? What kind of spring is supposed to be on the oiler rocker arm? Just trying to get a start on getting as many parts as I can while I am working on it. That elbow I found is not from a 12-20, but a 20-30 W. Chris.
ID:	244832   Click image for larger version
ID:	244833   Click image for larger version
ID:	244834   Click image for larger version
The Following User Says Thank You to CBarth66 For This Post:
Old 01-26-2016, 09:19:46 PM
Cody Isaak Cody Isaak is offline
Default Re: Rumely Oil Pull L 15-25 Parts and Advice Wanted
That piece with the line atached is supposed to go on top of the starting tank that is mounted on the left fender and a priming pump goes in the small hole in that same piece. As far as springs there's no specified one just use one that doesn't have alot of tension on it. As its only needed to keep the ratchet arm against the cam lobe. Hope this helps
The Following 2 Users Say Thank You to Cody Isaak For This Post:
  #43
Old 01-26-2016, 09:36:27 PM
Thanks Cody. That is why it has that long line on it. Is there some kind of plug that goes in the hole on the carb where the throttle rod hooks up?
  #44
Old 01-26-2016, 10:29:12 PM
Yes it's just a small tin cover
  #45
Old 01-26-2016, 11:22:29 PM
Jon Nessel's Avatar
Jon Nessel Jon Nessel is offline
..and hard to tell from the pic, but the tit where the spring hooks on on the oiler arm looks to be bust off. It's 'sposed to come out a little farther and have a groove for the spring to hook into. Like Cody said, as long as there is some spring pressure on it, it'll work.
The Following 2 Users Say Thank You to Jon Nessel For This Post:
  #46
Old 01-27-2016, 09:08:45 AM
Bubbles Bubbles is offline
Originally Posted by CBarth66 View Post
Finally got it moved around in the shop where I need for tear down. I took off the fenders to take to man to have them worked on. I was looking at where my air intake stack brace bolts up on the engine block, and there is some short flat bar on there with a 90 bent on top just under the manifold. The brace I have is a long angle iron piece that I got from Beiwers and cannot go there because the manifold is in the way. Am I right in assuming that this is not the right manifold for the air cleaner system I have? My guess is that the manifold broke at one time and was replaced with another type, and the air cleaner and pipes were left off as it had no intake at all when I got it. Am I going to have to look for the correct manifold or change the whole air cleaner system? I did find a recast intake pipe from a 12-20 I think and can be machined to work on mine. The pics will show the manifold and block. Looking forward to hearing from you all. Chris.
You should go by the parts book, the various parts are listed by serial number production (if there were changes).
The Following 2 Users Say Thank You to Bubbles For This Post:
  #47
Old 01-27-2016, 07:40:42 PM
Yes Bubbles, I do have a Jensales parts book and will take a closer look. I do not think this tractor is supposed to have a Bennett style air cleaner as my book does not give one for it`s serial#. I have lots of time to do more research.
  #48
Old 01-28-2016, 12:19:55 AM
I just looked at the parts book and it shows a 90 curved exhaust pipe coming out of the head with a part #c5p2631. It shows no pipe like the one it has on it now, so it must be off another model. If I could find one of those correct exhaust elbows, I might be able to use all the air intake parts I have now.
Old 01-29-2016, 12:21:44 AM
Dave Shearns had some cast for a lightweigut as 20-35, but check with him.
The Following User Says Thank You to Oilpulled For This Post:
  #50
Old 01-29-2016, 06:44:06 AM
Thanks for that info. Is he the guy in New York? I think he sent me my air cleaner. do you have a phone number?
---------- Post added at 05:44:06 AM ---------- Previous post was at 05:30:21 AM ----------
I looked through my papers and found it. Wonder if those 20-35 castings are the same as the 15-25?
Old 01-29-2016, 11:10:05 PM
Probably not. 20-35M & 25-40X are the same and what I saw he had.
15-25L & 20-30W are smaller and the same as each other I Think.
  #52
Old 01-30-2016, 10:04:18 AM
Talked to Dave Shearns and informed me those are bigger and would not fit. He and a couple others I talked to are going to look for me. I also talked to a very nice fellow who has been following this post and gave me lots of good info. The governor is not the right one for this tractor or is the expansion tank. Has anyone else seen that tank up by the exhaust like mine? I have seen a couple others in pictures that have but were they factory built like this? Anyhow, I have a intake elbow and a stack with a cap on the way, so things are moving along. What a great bunch of people you all are. Thanks. Chris.
Old 01-30-2016, 10:52:21 AM
KevinR's Avatar
KevinR KevinR is offline
Here's a picture of our 1925 15-25, it has the incorrect air cleaner and the expansion tank by the exhaust. Good luck on your project.
KevinRoback
The Following User Says Thank You to KevinR For This Post:
  #54
Old 01-30-2016, 11:57:03 AM
Looks like you have one of those like I have seen in other pictures. Mine is a 1926 and it looks like the tank has always been up there as it has no tank brackets back by the engine block. I think the tanks were placed up there some good reason, but not sure why. My parts book does not show the type of air cleaner you have Kevin, but the more I investigate, the more I see with parts not correct or may be placed wrong. Many of these tractors were changed over the years I am sure. I just want to be as close as I can to original. That is a nice looking L you have there.
Old 01-30-2016, 11:57:39 AM
Some tractors have been modified along the way, some even had factory updates as well.
Again if you want it to be 100% original go by the parts book. Putting the expansion tank back onto the motor requires a lot of parts.
The Following User Says Thank You to Bubbles For This Post:
  #56
Old 01-30-2016, 01:02:51 PM
From what I can see your govonor is correct for the tractor, it's definetly not a later superpowered govonor
The Following User Says Thank You to Cody Isaak For This Post:
  #57
Old 01-30-2016, 01:47:10 PM
My main concern is getting the intake and exhaust systems looking right for now. I was told that the manifold on it now is probably from a model W. As for the tank it is most likely going to stay where it is.
Old 01-30-2016, 02:32:40 PM
My book shows a tube that the throttle shaft goes through from the carb to the governor. It is a straight tube so how does it fit on such an angle? This is also a part which is missing. The governor does look like the one in the book.
Name:	rumely governor 3.jpg
ID:	245100   Click image for larger version
Name:	rumely governor 001.jpg
  #59
Old 01-30-2016, 05:23:48 PM
The carb as shown should have a tube connected to the governor, it looks as if the governor is not correct. The style with the tube connection hooks up at the bottom, there is a 2 pc casting on the bottom of the governor to accept the tube. The governor hook up you have is a later super power style.
  #60
Old 01-30-2016, 07:15:59 PM
Looks can be deceiving I guess. The main body of that governor has a casting # c5p6891. The book has #c5p6242. It Must not be the right one.
Rumely Oil Pull model M 20-35 Parts and Advice Wanted neilthewheel Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 14 03-27-2018 09:40:35 AM
Case 15-27 crossmotor parts and advice wanted! neilthewheel Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 01-01-2016 02:15:25 PM
Onan 15JC - need to pull genset any advice? Larry96 Onan Generators 4 07-21-2011 07:43:44 AM
14 -28 Rumely parts wanted fryguy Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 08-24-2009 12:09:09 AM
rumely oil pull tim w Hit & Miss Gas Engine Discussion 1 05-16-2007 10:00:25 PM
