Go Back   SmokStak > SmokStak® Shows, Swaps, Announcements > Shows and Swap Meets
Shows and Swap Meets Announcements, reviews, photos, movies and discussion about antique engine and tractor shows and swaps.
John Deere R serial #41114
this thread has 11 replies and has been viewed 1712 times
Old 06-12-2015, 10:17:32 PM
4Farmkids 4Farmkids is offline
Default John Deere R serial #41114
I recently acquired a John Deere R with serial 41114 and every thing that l look up shows that the last one was around 23000.
The person that I got it from said he thought it was a 1952.
Can anyone help with this serial number issue?
The Following User Says Thank You to 4Farmkids For This Post:
Old 06-12-2015, 10:49:50 PM
Dean Lemer Dean Lemer is offline
Default Re: John Deere R serial #41114
Per Two Cylinder Club serial number research shows that the 1954 started at 19485.
The Following User Says Thank You to Dean Lemer For This Post:
Old 06-12-2015, 10:49:52 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Hopefully one of the John Deere guys will shed some light on the thing. One thing that comes to mind if that low number is the last R, are you sure it's a R and not a 80?
Old 06-12-2015, 11:09:32 PM
It has a round flywheel cover and all the cast numbers end with R and the serial number tag says "Model R Tractor"
Old 06-13-2015, 07:20:01 AM
Weld Engineer Weld Engineer is offline
The logical answer would be you are misreading the first number as a 4 rather than a 1 making it 11114 and a 1952. The number series all began with the model number and plenty of room for lots of sales. Very first Model 80 = 8000001. I'd look closer at the tag you have to be mistaking it for a different number.
Old 06-13-2015, 11:12:41 AM
Here is a pic.Click image for larger version
Old 06-13-2015, 11:43:54 AM
Well sure looks like a 4.
Old 06-15-2015, 07:15:07 AM
DieselAddicted DieselAddicted is offline
Looks like it has been restamped to me. Look closely around the third "1" in the serial number you can see what looks to be an 8 that has been stamped over.
Old 06-15-2015, 10:16:08 AM
I looked at it closely this weekend with magnifying glass and can see the 8 and what appears to be a 1 before the 8 in a different stamp type.
I have only seen one other R serial plate and it was done with approximately 3/16 letters.
I thought about taking the plate off and seeing if I could identify the original numbers from the back side.
Has anyone had any success with doing that?
Old 06-15-2015, 03:18:35 PM
FWurth's Avatar
One Millionth Post
That's real interesting! It definitely looks to be restamped as you can see the original Deere type under the heavy over stamp. Brings a whole bunch of questions as to the why of it. If someone wanted to change for reasons of it's origins you would think they would have chosen a number revellent to the R series, if it was for a company inventory number why cover the original?
Old 06-15-2015, 03:45:02 PM
Apparently they only had the numbers 4 & 1 in their tool box.
Old 06-15-2015, 07:43:49 PM
After looking closer at the numbers, I agree that is a restamp.
John Deere Hit and Miss Serial #s Deere-haven Hit & Miss Gas Engine Discussion 12 06-19-2014 09:48:43 AM
John Deere A Serial Number C. Lambert Antique Farm Tractors 4 02-19-2011 11:24:50 AM
John deere serial # 1 Dan Moore Antique Farm Tractors 2 01-03-2009 07:11:24 PM
John Deere serial #s Stevewold Hit & Miss Gas Engine Discussion 1 09-12-2008 08:17:09 PM
John Deere 'R' Serial Help Pentode Antique Farm Tractors 6 10-01-2005 12:42:59 PM
