Atlas lathe
this thread has 4 replies and has been viewed 1215 times
Old 08-18-2015, 05:07:48 PM
Jerry B Jerry B is offline
Default Atlas lathe
I got a 12 x 36'' lathe I put a 1 hp motor on it, But when I cut 4th it sure pulls the motor down , am I doing something worng
Old 08-18-2015, 05:11:01 PM
Default Re: Atlas lathe
Please explain "cut 4th" ? Are you feeding by hand or using the lead screw?
How sharp is your cutting tool?
Old 08-18-2015, 06:20:47 PM
John Tice's Avatar
John Tice John Tice is offline
DITTO; I'm a lathe man
JT
The Following User Says Thank You to John Tice For This Post:
Old 08-18-2015, 06:59:26 PM
I am taking about 4000 cut
Old 08-19-2015, 12:40:52 AM
No idea what 4000 is.
4 thousandths cut is expressed as .004", and the Atlas with 1hp motor and using the lead screw should cut that like butter without bogging, assuming your tool is sharp. Now if you are trying to cut .400" (four hundred thousandths) you are trying to take too big of a cut, although you might make it work with brass or nylon, but you WILL need to feed by hand. DO NOT use the lead screw for hogging cuts.
Keep in mind that if you take .200" cut, you are reducing the diameter of your work piece by .400".
So again, please clarify.
The Following 2 Users Say Thank You to dalmatiangirl61 For This Post:
Atlas lathe Jerry B Machine Shop and Tool Talk 2 05-17-2015 07:00:09 AM
Atlas Lathe Jerry B Machine Shop and Tool Talk 11 02-15-2015 03:38:44 PM
Atlas TH-42 10-12 inch lathe F. Moore Machine Shop and Tool Talk 9 02-16-2014 06:28:26 PM
Atlas Lathe Year? Jeff Smith Machine Shop and Tool Talk 4 10-16-2005 08:05:46 PM
Need Atlas Lathe Part Pat in Mississippi Antique Engine Archives 1 02-14-2003 10:24:54 AM
