McCormick T20 TracTracTor S/N Question
this thread has 5 replies and has been viewed 969 times
Old 10-24-2015, 04:02:01 AM
Norm Johnston Norm Johnston is offline
Default McCormick T20 TracTracTor S/N Question
I was lucky enough to sight an early T20 and thought I had read a thread on this sight that helped to explain the early serial numbers and production numbers, BUT I CAN'T seem to locate the thread. this tractor I believe is a very early one and has the serial number 549 only no prefix letters. any help will be appreciated. Norm
Old 10-24-2015, 08:35:19 AM
Titan1020 Titan1020 is offline
Default Re: McCormick T20 tractractor s/n question
The first 50 serial numbered tractors (501 to 551) were actually Model 15s. There are a number of differences between these and the T-20s so some pictures would be helpful to determine whether it is a 15 or 20. There are at least 2 of these first 50 still in existence with both coming from the Heidrick auction several years ago. I had heard that one left the country so maybe this is that unit?
The Following User Says Thank You to Titan1020 For This Post:
Old 10-27-2015, 12:00:34 AM
Default Re: McCormick T20 TracTracTor S/N Question
Thanks for the above info, it all helps, I seem to remember reading about the pre production numbers and the use of pre fix letters somewhere but that info eludes me at the present time. The photos do not show much detail
it is just the lack of any prefix letter that has me intrigued
ID:	237604   Click image for larger version
ID:	237605   Click image for larger version
The Following User Says Thank You to Norm Johnston For This Post:
Old 10-27-2015, 02:13:30 PM
Russ Hamm's Avatar
That is actually a 10-20 trac-tractor, and an early one judging by the fenders.
---------- Post added at 01:13 PM ---------- Previous post was at 01:11 PM ----------
And the gas tank is early, same as the wheel tractor.
Old 10-27-2015, 06:20:58 PM
The only number on this tractor is 549 it appears to be right around the time of the change from 15 to 20, It also arrived new into the country, not a later import.
Old 10-27-2015, 09:24:42 PM
Russ is correct, this is a 10-20 TracTracTor built in 1928. Amazingly enough I have serial number 548!
10-20 McCormick Question Kelly Barnett Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 10-29-2014 06:45:00 PM
Early Tractractor (McCormick) KevinGWeq Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 15 12-02-2013 10:03:30 PM
1936 TD-40 McCormick-Deering TracTracTor 20 Reeves Highwheeler Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 19 11-05-2013 10:59:55 PM
10-20 tractractor help Lyle Stomp Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 08-22-2013 05:00:51 PM
McCormick 10-20 question Arno M- Germany Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 11-14-2010 05:58:40 PM
