Spoker D Restoration
this thread has 165 replies and has been viewed 27101 times
Old 02-25-2017, 12:15:35 AM
halcon halcon is offline
Default Re: Spoker D Restoration
Does any one know for certainty what the serial number of the last spoker D was. The parts book isn't much help as the part number stayed the same on the first solid flywheel as the spoke flywheel.
Old 02-25-2017, 02:49:53 AM
LukeSte LukeSte is offline
36248 I believe.. 36249 is the first nickel.
The Following 2 Users Say Thank You to LukeSte For This Post:
  #163
Old 02-25-2017, 10:02:53 AM
Camerons's Avatar
Camerons Camerons is offline
Luke is correct. Here are a couple pictures of 36249 which now resides in a collection in southeastern South Dakota. The current owner does post on the smokstak occasionally so I will let him fill in any details if he chooses.
ID:	275864   Click image for larger version
The Following 6 Users Say Thank You to Camerons For This Post:
  #164
Old 03-12-2017, 01:35:54 PM
Mike Monnier's Avatar
Hoarder
Have a couple of questions about the front axle on our Spoker. Lots of worn stuff as it appears the tractor spent its working life pulling a plow.
1. What are the correct dimensions for the radius rod pivot bushing (28H1504 R)?
2. What size grease cups are correct? Ours have been replaced with zerk fittings at some point. I'm assuming size 00 or 000 would be correct.
I still need to make a new kingpin for the right side and a plug to fix the egg shaped hole it threads into. Lots of little details before it gets shiny new paint.
Old 05-04-2017, 09:28:36 PM
Hoarder
Does anyone have a good source for the felt washers for the front spindles? Concerned that ours seem to be impregnated with dirt.
Old 05-04-2017, 10:15:38 PM
Make your own.......
https://www.mcmaster.com/#felt/=17hjewa
JD Spoker D Jim Gordon Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 05-24-2013 09:39:21 PM
Spoker D Prices Joel Mosley Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 11-24-2012 01:29:02 PM
How rare are spoker Ds? ssimntih Antique Farm Tractors 22 10-18-2012 07:33:56 PM
Tea & Cake or Spoker D? German George Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 89 05-20-2008 09:10:22 AM
Any spoker Ds around Alltractorman Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 01-23-2006 07:17:44 PM
