Wallis Cub Jr Restoration
this thread has 35 replies and has been viewed 7211 times
Old 03-22-2016, 10:42:19 AM
Malcolm Robinson Malcolm Robinson is offline
Default Re: Wallis Cub Jr Restoration
Your project is moving along very well Tom,
I am watching and taking good note of all your posts and detailed progression, it will be all very useful for me when my project in due course.
Well done and keep the photo's coming.
Malcolm.
The Following User Says Thank You to Malcolm Robinson For This Post:
Old 03-22-2016, 11:57:05 PM
TSeaberg TSeaberg is offline
Did a little bit more work today on the Cub JR. It wasn't a huge amount of work but made a big difference in looks! Lukeste borrowed me his Milwaukee steel cutting skill saw so I could cut the top of the frame straight. This saw is quite impressive for ease of cutting and finish left when your done. It just doesn't seem right cutting steel with what seems like a wood working tool! Anyway I'm one step closer to the end, or maybe the middle of the project.
Old 03-23-2016, 12:00:50 AM
Oldtech Oldtech is offline
Looking Good Tom. Is this called restoration or building a replica?
Old 03-23-2016, 11:34:47 AM
Restoration, no doubt in my mind. Sure I had to make a new frame for it and fix a lot of other pieces but it will be mostly original Wallis stuff.
Did you figure out anything on that fuel shut off valve I was emailing you about last fall?
Old 03-23-2016, 01:03:53 PM
G Catlin G Catlin is offline
One new part and four parts from the original Cub Jr in the last picture, that makes it about 80% original.
Keep up the good work Tom.
The Following 2 Users Say Thank You to G Catlin For This Post:
  #26
Old 03-23-2016, 02:02:42 PM
It's under a snowbank yet. I haven't forgot. We got a good March snowdump.
Old 03-23-2016, 07:22:48 PM
[QUOTE=TSeaberg;1267001]Did a little bit more work today on the Cub JR. It wasn't a huge amount of work but made a big difference in looks! Lukeste borrowed me his Milwaukee steel cutting skill saw so I could cut the top of the frame straight. This saw is quite impressive for ease of cutting and finish left when your done. It just doesn't seem right cutting steel with what seems like a wood working tool! Anyway I'm one step closer to the end, or maybe the middle of the project.
[QUOTE]
Those carbide saws are awesome. I bought a chop saw two years ago and have cut many many pieces of iron both tube and solid and still going strong. Slow speed, no sparks, little heat, perfect cuts and it is always the same diameter. One downside is the cost of a new blade [$150] but about the same when you would probably consume 10 abrasive blades in the same time. Ed B
The Following User Says Thank You to Ed Bezanson For This Post:
  #28
Old 03-23-2016, 11:23:08 PM
Greg Mosley Greg Mosley is offline
What a great project! Keep up the great work! Enuf Said
Old 03-24-2016, 11:30:14 AM
I have been searching recently to get the right magneto impulse for this tractor and another one I have. They use a KW model T magneto with a flange drive type impulse. Most of the KW mags use the drive lug impulse but this application has a flange to bolt the drive gear on. So hopefully somebody out there has a part like this I can buy. The flange is part of the impulse and holds the impulse spring inside of it. Here's a couple photos if anybody has one or two I would really be interested.
The Following User Says Thank You to TSeaberg For This Post:
  #30
Old 03-24-2016, 02:59:23 PM
Tim Colwell's Avatar
Tim Colwell Tim Colwell is online now
Gary Biewer just listed one of these mags for sale on Facebook. Not sure if it has the impulse on it.
Tim Colwell
JD & IHC corn sheller and engine collector.
Old 03-24-2016, 07:22:10 PM
Originally Posted by Tim Colwell View Post
Gary Viewer just listed one of these mags for sale on Facebook. Not sure if it has the impulse on it.
Thanks for the info but it has the more common lug drive on it.
  #32
Old 01-04-2017, 06:16:44 PM
Joel Mosley's Avatar
Joel Mosley Joel Mosley is offline
Just checking in to see if there are any updates on this fantastic tractor.
Joel
The Following User Says Thank You to Joel Mosley For This Post:
  #33
Old 01-04-2017, 09:34:38 PM
Joel
I have not worked on this tractor much. Been working on a few small projects with this cub jr and some of the K's I have. Mostly progress is not moving forward with this tractor. Last spring I was working on the front wheel with new spokes and the re-machined hub. This summer I picked up another engine block to use in the tractor. This new engine block is identical to what it would have originally been set up with just with a higher serial number. At Le Sueur I found a KW magneto with the correct impulse drive I was needing, now I will have to machine another one because it was set aside for a K that is closer to running.
Here is a few photos of the front wheel, new engine block, and a couple other little projects between this tractor and the K's.
The Following 10 Users Say Thank You to TSeaberg For This Post:
  #34
Old 01-04-2017, 09:39:38 PM
I have also been busy picking up more projects this fall. A friend of mine found the three for me in western North Dakota including a K on airplane tires, OK, and K parts tractor. Last weekend I made a trip to Nebraska to pick up another K that has an actual Cub JR engine in it. So far on my project I have not had a correct serial number engine. This one ended up being a really early serial number, too old for my chassis since the early tractors had several changes. Still is correct for a Cub JR though. This spring I need to rearrange the steel wheeled area in the shed to line up all the K's if there is room
Old 02-16-2018, 02:56:29 PM
I'll give this a bump, shame the pics all broke. If you ever need a hand on something LMK I'm in Fargo.
Tim Colwell
Old 08-29-2019, 07:54:53 PM
Russ Hamm's Avatar
Any updates on this one?
1926 Wallis 20-30 restoration with pics GreasyJohn Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 139 09-09-2015 09:27:02 PM
1928 Wallis 20 30 Restoration Cody Isaak Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 13 11-19-2014 03:47:36 PM
Wallis Cub restoration German George Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 54 02-24-2013 05:50:57 PM
1918 Wallis K Restoration TSeaberg Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 27 01-27-2010 12:10:59 AM
