Another Twin City
this thread has 162 replies and has been viewed 19583 times
Old 11-16-2016, 10:34:32 PM
Default Re: Another Twin City
Russ...the front wheels shouldn't rub on the tractor frame. There are adjustable stops on the front axle that limit the travel of each spindle.
Name:	Twin City 17-28 265A.jpg
Old 11-17-2016, 09:48:17 AM
Russ Hamm's Avatar
Mark, Phil and Moline, without you guys i would probably be headed the wrong direction completely as the TC brand is COMPLETELY different in many areas than anything i have worked on so far, much appreciated.
Pulled the radiator off last night, took me two hours without a torch. That center bolt above the starting crank was a challenge as the shrouds would not come off and my bolt cutting options were at the shop 10 miles away. The steel side supports on the core fell right off, i suppose it can be used without them similarly to the McCormick Deerings i have done. Core looks good, uncle Dan must have resealed the top tank as it had later bolts in it and longer. Meanwhile the mice had gotten in it with the inlet and outlet open, not too bad, needs core cleaned.
Removing the starting crank was interesting, for anyone doing this for the first time in the future this is what i found. In the picture the pin is out but you can see the smaller pin started in the center, this went through the front and was bent over a little in the hole throough the center of the shaft forward. The Deerings have a set screw to hold these in.
Hopefully the engine will slide forward this weekend, i did hear a clunk when the pulley is turned, in gear, with the clutch engaged, maybe looking into redrilling three pilot holes like mentioned earlier.
ID:	268236   Click image for larger version
ID:	268237   Click image for larger version
The Following 4 Users Say Thank You to Russ Hamm For This Post:
  #43
Old 11-17-2016, 03:14:42 PM
Russ...before you slide the motor ahead remove the gas tank saddle and see if you can isolate the cause of the clunk. The top of the clutch housing and the primary bevel gear set can be seen once it's off. My 17-28 had a clunk also. The clutch pins were OK however the input shaft was clunking back and forth because of a bad bearing. Once the motor is slid ahead the weight of the clutch assembly hangs on the end if the input shaft and can make diagnosis difficult if your problem is in the transmission.
I hadn't really thought of it before but perhaps the reason Twin City used that diagonal drag link on the steering was to keep it out of the reach of the front wheels. I had a McDeering 15-30 and the right front wheel rubbed on the drag link also.
Old 11-21-2016, 09:54:01 AM
Russ Hamm's Avatar
The engine is out, it was as easy as said. Looks like the clutch disc has already been drilled once and worn out holes again. I found that Adolph must have been plowing in high gear all those years as the high gear pinion is worn more than the low. Uncle Dan said he told him the last years of use were only on the silage blower, Adolph said that tractor could really do a good job on that.
I need to address the governor, tried to get the pin out of the weight bracket with no success yet.
ID:	268537   Click image for larger version
ID:	268538   Click image for larger version
ID:	268539   Click image for larger version
  #45
Old 11-23-2016, 02:16:44 PM
Russ Hamm's Avatar
Any advice on removing the clutch? I was thinking about
working over the long weekend, haven't checked out the
owners manual for any info just yet, hadn't looked at it much
yet.
Old 11-23-2016, 03:47:46 PM
Phil Johnson's Avatar
There is a round snap ring on the input shaft just in front of the disc. Pry this out with a screwdriver and the whole assembly should slide off the shaft. You may have to pull out the lock pin and back off the adjusting ring a bit if it is set up fairly tight.
  #47
Old 11-24-2016, 12:36:21 AM
Hi Russ
A couple of what ifs...
If the adjusting ring is stuck the clutch can still be removed after taking out the clutch cross shaft and throw out fork.
If the clutch assembly is stuck on the input shaft the four bolts can be removed from the input shaft bearing retainer and the clutch /input shaft can be removed from the front of the transmission as an assembly. The clutch cross shaft and fork will have to be removed first. Probably a good idea to renew the felt washer oil seal/wiper in the bearing cage and check the condition of the clutch brake lining at this time.
The Following User Says Thank You to Mark Schneider For This Post:
  #48
Old 11-24-2016, 09:21:23 AM
Molinegb Molinegb is offline
Another thing to check is the pedal brake. Makes it hard to speed shift!
The Following User Says Thank You to Molinegb For This Post:
  #49
Old 11-27-2016, 10:56:55 PM
Russ Hamm's Avatar
We had a long weekend so i was able to build an engine stand, i wanted to leave it out of the frame to work over this winter as i have some front axle and input shaft work ahead. Everything except the mounting bolts i had laying around. After it was up on the stand i was able to really clean out the block well, especially the water passages which had pounds of rust and mouse nests in it.
The input shaft bearing definately needs replaced, i'm going to research all my options but may resort to Mike's repair on his TC thread.
The clutch facings are about 1/8" thick, the splice stapels are long gone and the clutch brake disc is there but a little thinner than 1/8".
ID:	268989   Click image for larger version
ID:	268990   Click image for larger version
The Following 5 Users Say Thank You to Russ Hamm For This Post:
  #50
Old 11-28-2016, 12:42:29 AM
Russ...Nice job on the engine stand. You'll be glad you took the time to put it together.
That input shaft bearing and primary bevel gear set catch a lot of grief when the tractor is used for extended belt work. They rely solely on external lube being applied by the operator in this mode through the drip oiler on the transmission cover and the grease cup that feeds the bearing cage.
Old 11-28-2016, 10:09:06 AM
Russ Hamm's Avatar
Uncle Dan said that the original owner used this tractor for belt work on the silage blower after it was retired from field work, sounded like this was its job for many years.
There are grease zerks that go to the cross shaft bearings, might have been owner installed, with long tubes that look like it could be greased while its running.
Old 12-05-2016, 11:16:18 PM
Hi Russ...hope the work on your Twin City is going smoothly. I just got my new oil strainer for the TC 20-35 from McMaster-Carr and thought you might be interested as this one fits the 17-28 as well. It has a 30 mesh pleated stainless screen for more filtering area than the original and has the correct 1 1/4 x 3/4 fitting attached for a screw-in replacement. This works out well for non-soldering types like myself.
Cost is about $20 plus shipping.
Name:	TC 20-35 Canadian 377.jpg
ID:	269593   Click image for larger version
Name:	TC 20-35 Canadian 378.jpg
The Following 4 Users Say Thank You to Mark Schneider For This Post:
  #53
Old 12-06-2016, 10:31:46 AM
Russ Hamm's Avatar
Thanks Mark, i'll check today on ordering, got two bearings coming for the fan drive shaft and input shaft thanks to you also.
Just yesterday morning i heard the news that an old local collector passed away last weekend. When my uncle bought this 17-28 he also bought a large TC/MM on steel from the same owners' auction. I always remembered it as a much larger tractor than the 17-28 with wide rear wheels.
Anyway, this fellow recently passed had bought that tractor from uncle Dan some years ago, and i heard he still had it. I remember the exhause was open back then, i'm sure the engine was very rough.
Gleaner will know this fellow as Willard H, had a lot of tractors and etc.
The Following 2 Users Say Thank You to Russ Hamm For This Post:
  #54
Old 12-06-2016, 08:56:00 PM
Russ...that sounds interesting about the potential lead on the Big Twin Cam. Keep us posted.
If another clutch center disc doesn't show up I'm pretty sure that yours can be redrilled. I'll bet someone with a Bridgeport and some kind of indexing head could figure out how to do it.
  #55
Old 12-06-2016, 09:24:47 PM
Russ, if three of those holes are not too far out of round, you might bore them out to true them up and then press brass or steel bushings in them to remove the excess play.
  #56
Old 12-07-2016, 09:49:51 AM
Russ Hamm's Avatar
I may just do that, wondered if boring and bushing took away too much material but i don't think so. Since it has been re-drilled already the second set of holes isn't real bad, may try it.
Does anyone have access to facings? These are abount an eighth inch but sure don't want to take it apart again.
---------- Post added at 09:49:51 AM ---------- Previous post was at 09:48:25 AM ----------
Whatever supplier our parts guy called said we got the last one of those screens they had.
Old 12-09-2016, 12:26:58 AM
Russ Hamm's Avatar
I was able to do some more dissasembly this evening. The rod bearings look good, i was surprised as no rings were stuck. The wrist pin bushings have a little play, nothing serious, i was surprised to find none of the rings were stuck. At some time one of the rod bolt nuts must have been misplaced and someone put two shallow nuts in place of the original deep one, possibly the Chevrolet garage that overhauled it in 1940.
The cam gears are good, but the idler gear from the crank to cam gears is worn pretty good, still, i think if i can't come up with a better one it will still work. I would feel better replacing it if possible.
The oil pump looks good, although the half moon keys need replaced. The key on the fan drive/governor shaft gave a good fight, had to be heated and cooled before it came out.
ID:	269813   Click image for larger version
ID:	269814   Click image for larger version
ID:	269815   Click image for larger version
The Following 6 Users Say Thank You to Russ Hamm For This Post:
  #58
Old 12-09-2016, 12:33:31 AM
Russ Hamm's Avatar
More pics, looks like re-assembly on the head and honing out the cylinders will be next.
ID:	269817   Click image for larger version
The Following 7 Users Say Thank You to Russ Hamm For This Post:
  #59
Old 12-09-2016, 11:38:21 AM
Nebraska Kirk Nebraska Kirk is offline
That idler gear is not too bad, Russ, I would not be afraid to continue using it. The idler gear on my 17-28 is worn so bad the teeth are sharp enough to shave with!! When I get around to rebuilding it I am going to make a new gear.
The Following User Says Thank You to Nebraska Kirk For This Post:
  #60
Old 12-09-2016, 12:28:55 PM
Russ Hamm's Avatar
What do you guys think of drilling six more holes in that driven disc? I'm just thinking of six to keep it somewhat balanced as it has six in it already.
I have a lead on one with only three that needs re-drilled if i would just wait, which i sure have time before the engine is ready.
Twin City Big Twin Cam up for Sale Mark Schneider Live Auctions of Engines, Tractors and Old Iron 29 02-28-2019 12:04:46 AM
Twin City 17-28...My Intiation into the Twin Cam Faternity! Mark Schneider Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 120 06-01-2018 09:21:55 AM
Twin City KTA ozfarm Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 12-29-2013 11:12:27 PM
Twin City 12-20 Pat Bayer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 20 06-10-2012 11:02:28 PM
MM Twin City JTS DavidRaines Antique Farm Tractors 3 05-10-2008 11:02:19 AM
