Twin City 40
this thread has 184 replies and has been viewed 30675 times
Old 03-03-2018, 07:04:39 PM
Mike Harmeling Mike Harmeling is offline
Default Re: Twin City 40
We needed a pattern to cast off of. With this we built up wood. We then put it in the lathe and turned it down to size and shape. We didn't have an easy way to design relief around each spoke hole as is seen on the originals. We decided to streamline the design a bit.
Pic 1...Bonding the wood.
Pics 2 and 3... Turning it down.
Pic 4... after sealing, attachment of tabs, and attachment of bonding letters. Ready to go to the foundry.
The Following 14 Users Say Thank You to Mike Harmeling For This Post:
Old 03-03-2018, 07:14:03 PM
Once we got received the castings back we had to drill and then tap the spoke holes. We debated how to accomplish this with accuracy but without undue work. We thought about a rotary table but didn't have one readily available that was big enough.
We decided to mount it in the lathe and mark out spacing as best we could (it is an old tractor after all!). We then set the compound on the lathe and started drilling, after many passes getting up to the required 7/8" diameter holes so we could tap to 1".
Fortunately we had taken the time when we were at it to make the spokes necessary for the extensions when we were making them for the drivers, so that part was done.
Several cleats had be be removed as they had rotted out. A pattern was made and new cleats were cast out of ductile, then riveted in place.
Pic 1...One of the hubs mounted with the first set of holes drilled.
Pic 2... My dad working on the attachment holes.
Pic 3...Checking fitting.
Pic 4... Assembled.
Old 03-03-2018, 07:18:43 PM
We were lucky on the spacing. The spokes fit well. We had to drill the holes on one rim as the holes from the driver were at a different location in relation to the sides of the rim compared to each other. Lots of mag drilling accomplished this.
The depth of our compound was a little shallow, but spacers were made along with new connecting bolts.
Connecting brackets that attach the rim to the face of the driver were made off of a drawing of an original.
Old 03-05-2018, 12:09:55 AM
A great project right to the very end!
There's not a great deal of photos to reference how the extensions on the early 40's originally looked. If this picture (which is the earliest extension style I believe) is used for reference then the original spoke hole depth you chose might have been very close. Note the concave appearance on the extension spokes. It would appear that if the spacers were removed on your wheel and the hub centers were bolted down tight your extensions would take on a similar look.
The interesting question would be how did Twin City attain that concave look? Did they just build a "straight up" extension like yours and deflect the spokes upon installation? Or was the extension built with the spoke holes in the hub drilled at angles with the hub being offset to the center line of the spokes i.e. the spokes were concave from the start?
Name:	TC40 rear extensions.jpg
The Following 4 Users Say Thank You to Mark Schneider For This Post:
  #185
Old 03-05-2018, 10:15:41 AM
Wayne Riedlinger Wayne Riedlinger is online now
I woke up very early this morning and sat down and read through this whole thread again. All I can say is Wow what a job you and your helpers have done to bring this tractor back to life. not an easy task to say the least.
The Following User Says Thank You to Wayne Riedlinger For This Post:
Twin City 17-28...My Intiation into the Twin Cam Faternity! Mark Schneider Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 120 06-01-2018 09:21:55 AM
Twin City MTA becker5759 Antique Farm Tractors 3 04-12-2015 10:13:45 AM
Twin City KTA ozfarm Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 07-24-2014 09:10:50 PM
My first Twin City Rick Schmitz Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 180 04-24-2014 03:19:16 PM
17-28 ty twin city Bear Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 01-14-2006 12:00:12 PM
