Twin City 40
this thread has 184 replies and has been viewed 30690 times
Old 05-22-2016, 10:53:45 PM
Default Re: Twin City 40
Mike...I admire your ability to make usable wheels out of mostly cast off junk. Nice job! A couple of trips around the parade route will plug the extra holes with dirt. Did you have a set of original centers for the extension rims or did you have new ones cast?
Old 05-24-2016, 05:17:54 PM
Mike Harmeling Mike Harmeling is offline
After we put the wheels together, we had to mount the bull gears. We then had to build the bracing.
Pic 1...The bull gear sitting on the hub
Pic 2...The bracing cut out
Pic 3...Moving the gears around
Pic 4...Completed
Old 05-24-2016, 09:46:48 PM
Mark... we haven't yet figured out what we are going to do for extension hubs.
Mike
Old 05-25-2016, 03:46:15 PM
Langes Machine Shop Langes Machine Shop is offline
Mike
I was wondering how you were doing on your Project. Those wheels look great.
Jason
Old 05-26-2016, 11:58:32 PM
Mike...I hadn't considered the possibility that maybe no centers for the round spoke extension rims exist to make a pattern after. You'll think of something.
From the early pictures and ads it looks like the wheels that you have put back together fall into the 1912 time frame. While not a photo this December 1912 ad clearly shows the reinforced wheel edges and steeper lug angles.
Name:	Twin City 40A.jpg
The Following 2 Users Say Thank You to Mark Schneider For This Post:
  #46
Old 05-27-2016, 09:31:25 PM
Jason...Your gears turned out great. Welding cast is a dying art from what I can find and you guys did a great job.
Mark...Thanks for the picture. I've been saying our parts are from 1912, but now we know for sure. Love SmokStak. Learn something new every day.
Mike
The Following 2 Users Say Thank You to Mike Harmeling For This Post:
  #47
Old 05-27-2016, 09:40:48 PM
These are the front wheels. One rim was good enough to use. We had a few other rims, but they were all really rough, so we had another one rolled, drilled and countersunk holes.
We had to go through the same process for the spokes as we did for the back wheels. Smaller stock, though, so an easier job.
The first is an original.
Old 05-28-2016, 02:47:44 PM
The finished wheels with my son Ben, my paint helper.
Old 05-28-2016, 03:43:27 PM
Brothers Clemens's Avatar
Thumbs up Re: Twin City 40
Mike,
Realy nice and great project.
Keep them coming the pictures and the story’s
The Following 2 Users Say Thank You to Brothers Clemens For This Post:
  #50
Old 05-28-2016, 08:02:00 PM
Caleb Carpenter Caleb Carpenter is offline
Mike- looks good! Those wheels are fun to paint. About the time you think you have them fully covered you find a bare spot on a spoke. I think I used about 1 1/2 gallons of paint on the Reeves wheels and I didn't paint the wheel faces!
Old 06-05-2016, 12:34:25 AM
Here is another early Twin City 40 that is identified as a 1912 model. The picture was taken in 1919 and was part of an interesting article that discussed the longevity of the early large gas tractors from various companies. While the photo was small to work with the 45 degree lug angle on the round spoke extensions and the full rear fenders can be seen which places this tractor as pre 1913.
Name:	Twin City 40C.jpg
ID:	255501   Click image for larger version
Name:	Twin City 40CA.jpg
Old 06-05-2016, 10:58:09 AM
Those pictures are great, Mark. I really appreciate the information.
Mike
Old 06-05-2016, 11:00:09 AM
The frame was in good shape. The only real issues were the angle irons off of the back. These form the supports for the operator's platform. They were removed prior to prep work.
These are when we picked it up
Old 06-05-2016, 11:02:41 AM
This was after blasting and priming.
Old 06-05-2016, 04:55:33 PM
Mike...It seems like an appropriate time to insert this ad which includes a really nice pen and ink illustration of an early TC 40. It looks like I was a bit premature with the pre-1913 statement on the last post as this ad is dated April 1913 and still depicts the "40" with the round spoke wheels.
Another plowing scene to enjoy. Pictures of the "40" fitted with a 12 bottom gang plow are fairly easy to come by.
Name:	Twin City 40G.jpg
ID:	255538   Click image for larger version
Name:	Twin City 40GA.jpg
ID:	255539   Click image for larger version
Name:	Twin City 40H.jpg
The Following 12 Users Say Thank You to Mark Schneider For This Post:
  #56
Old 06-10-2016, 04:51:25 PM
These pictures are of the cannon bearing.
Pic 1...The bearing still in the frame.
Pics 2 and 3...The babbit in it was very egged out from use. the axle was originally 4 15/16" dia. Vertically it was 5 1/2" from wear. We heated the babbitt out. In these pictures you can some ears in the middle of the casting. These are the pour spots.
Old 06-10-2016, 04:55:53 PM
Pic 1...We made centering collars for either end. We then turned it vertical and poured into the ears. That was a lot of babbitt.
Pics 2, 3... We had sooted the shaft, then wrapped paper around it. Even with this we had to make a press to get the shaft out.
Pic 4...Back in place. We ended up with around 0.020 clearance. Not too bad for guess work.
Old 06-15-2016, 06:54:38 PM
This is the front axle assembly.
On the later tractors, the front axle was sprung. The early style had no springs.
The axle just had to be loosened up, but was otherwise complete.
Old 06-15-2016, 06:57:47 PM
Had to machine the newly cast hubcaps.
This is how it looked after we assembled the front end for the first time.
Old 06-15-2016, 11:27:22 PM
Progress looks good!
Twin City 17-28...My Intiation into the Twin Cam Faternity! Mark Schneider Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 120 06-01-2018 09:21:55 AM
Twin City MTA becker5759 Antique Farm Tractors 3 04-12-2015 10:13:45 AM
Twin City KTA ozfarm Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 07-24-2014 09:10:50 PM
My first Twin City Rick Schmitz Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 180 04-24-2014 03:19:16 PM
17-28 ty twin city Bear Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 01-14-2006 12:00:12 PM
