Jaques Mighty Mite tire size
this thread has 5 replies and has been viewed 1763 times
Old 10-22-2013, 08:51:59 PM
Jeff LaCrone Jeff LaCrone is offline
Default Jaques Mighty Mite tire size
I'm getting new tires for my Mighty Mite garden tractor. The wheels are 4.5 inches wide and 16" wheels. They had 7.50 x 16 tires on them. The place I'm getting new rims the same size tells me I should put 6.00 or 6.50 x 16 tires on it. They were telling me the new tire sizes are different. I want to get the same psyical size that came out on it. Can anyone help me wade through this. Thanks
Old 10-23-2013, 07:03:31 AM
1938Sears 1938Sears is offline
Default Re: Jaques Mighty Mite tire size
Jeff,
Mine has the 7.50 X 16 size on it and I am pretty sure that is the standard size for the tractor. They show a slight balloon effect on the rim, but that is normal.
The Following User Says Thank You to 1938Sears For This Post:
Old 08-06-2019, 11:07:57 AM
trey1 trey1 is offline
Could you tell me where you're getting new rims? I've been looking everywhere.
Thanks,
Trey
Old 08-06-2019, 11:15:51 AM
www.ottawamuleteam.com
www.millertire.com
The Following User Says Thank You to casertractor For This Post:
Old 08-06-2019, 11:17:25 AM
Onan Dan's Avatar
Onan Dan Onan Dan is offline
Trey 1 do you ever check for things on Ebay they may be someone have a good used wheel worth a check to see just write in the search area and i am sure something will come up .i bought parts for my ole troy bilt tractor and fixed it up.
Old 08-06-2019, 11:56:21 AM
I've been looking. Wasn't sure if all used the same lug pattern. I just know it's a 7.50 x 16.
Jaques Mighty Mite 65kaiser Garden Tractors and Mowers 20 03-12-2019 09:01:56 AM
Mighty Mite on steel and later Briggs 23 maybe? Jim Martin Garden Tractors and Mowers 9 11-23-2016 10:34:43 AM
Jaques Mighty Mite Jeff LaCrone Garden Tractors and Mowers 4 08-08-2013 07:31:19 AM
Need tire size Tim Cline Antique Farm Tractors 3 07-24-2012 03:05:33 AM
Jaques Mighty Mite Kevin Stone Antique Farm Tractors 5 01-21-2007 09:39:43 PM
