1921 Pierce-Arrow X5 Two Ton Truck
this thread has 44 replies and has been viewed 7286 times
Old 02-12-2019, 04:29:47 PM
Alan D. Alan D. is offline
Default Re: 1921 Pierce-Arrow X5 Two Ton Truck
Hello Chris, How about an update?
Al
Old 06-10-2019, 05:04:11 PM
Chris Props Chris Props is offline
Making slow progress. Picked up the engine in Feb. Four new sleeves, 16 valve seats and guides, and new rod and main bearings.
What would be a good solder to use on the wrist pin oiling tubes? Two of the tubes were loose and the other two had fallen into the pan after getting chewed up.
ID:	336895   Click image for larger version
The Following 3 Users Say Thank You to Chris Props For This Post:
  #43
Old 06-11-2019, 12:25:49 AM
The "new", lead free, plumbing solder is very strong or you could use a 5% silver bearing solder which is stronger but requires more heat and is a bit more difficult to work with.
Another alternative is there >>> https://www.homedepot.com/p/SOLDER-I...SP-7/300916097
  #44
Old 06-12-2019, 03:52:11 PM
When will you get to the fun part of assembly? I assume that you have your new aluminum pistons just waiting to get married to the connecting rods! How is your cam, lifters, bearings and front gear drives?
Al
Old 06-14-2019, 09:00:15 AM
I'm reusing the original pistons. They were still in good shape. The cam, cam bearings lifters, and gears are in good shape too.
The Following User Says Thank You to Chris Props For This Post:
1930 Pierce Arrow Engine Keith Schumacher Antique Autos and Trucks 12 12-01-2011 09:31:51 PM
Pierce Arrow jack? For a truck? mschreiber Antique Autos and Trucks 8 03-19-2010 04:11:42 PM
Pierce Arrow Wheels Keith Schumacher Antique Autos and Trucks 2 04-10-2009 08:20:18 PM
Pierce Arrow truck parts wanted BlasterMike Antique Autos and Trucks 19 04-08-2009 12:31:00 AM
