1925 Buick Standard Six Four Passenger Coupe
this thread has 60 replies and has been viewed 7211 times
Old 09-13-2017, 06:59:47 PM
oldsoldster oldsoldster is offline
Default Re: 1925 Buick Standard Six Four Passenger Coupe
Originally Posted by John Hamilton View Post
You should be able to find vacuum tank instructions on the web. The first thing it will say is that the problem almost certainly isn't the tank. First make certain all the lines including the one to the carb are clear and good luck. Do you have enough gas?
Everything has been thoroughly cleaned and new gaskets installed.There is not a lot of gas in the tank,just enough to move the gauge.New fuel lines were installed.Is it possible to get an air block in the line? We primed the vacuum tank and it runs until empty but doesn't refill.
---------- Post added at 06:59:47 PM ---------- Previous post was at 06:44:45 PM ----------
Thanks Andrew and John. There is not enough fuel in the tank to completely cover the pickup screen.I will add some more.We just reinstalled the tank today after having the 25 year old fuel cleaned out and new Red Cote sealer installed.The carb appears to have been completely rebuilt with a new venturi and excellent needles and seats.The engine is also a fresh (25 years ago) rebuild and is as clean as new inside.There is great vacuum to the top of the vacuum tank.I fully expected a few glitches after it's long sleep.
Old 09-13-2017, 07:35:58 PM
Elden DuRand's Avatar
I've worked on several Stewart vacuum tanks and, unless the pot metal was broken, I've gotten them to work.
If gasoline has sat in the tank for several years, the flapper valve in the top tank may be gummed-up. Take it apart and use carb cleaner to get all the crud out. Make new gaskets and carefully reassemble it, making sure it is air tight.
These will sometimes fail to draw gasoline if the engine is run at full throttle for extended periods. If this happens, just get off the throttle for a few seconds, allowing the internal tank to refill.
If the tank is in good condition, you can idle the engine for long periods. When the internal tank gets low, you will notice that the engine runs a little rough while vacuum is being used to refill it.
[SIGPIC][/SIGPIC]
Take care - Elden
http://www.eldensengines.com
Old 09-13-2017, 09:25:13 PM
OTTO-Sawyer's Avatar
That thing is Absolutely Beautiful !
Old 09-13-2017, 11:02:24 PM
Oldtech Oldtech is offline
Not sure what, if anything you have done with the vacuum tank but as other posts have suggested, try other things first. A hole in the fuel line from the tank will stop it so the suggestion of pressurizing the tank a little with the line off the tank is a good one. I take it you had the tank off so you would have had the suck tube out. It has to be good too of course. If the vacuum tank gasket isn't sealing , that would do it too. PM me if you get stuck. Lots of 20's Buick experience here.
Old 09-14-2017, 01:58:56 PM
I added a bit more fuel to the tank and topped up the vacuum tank (full).Also retightened the top screws.This time the vacuum tank refilled itself.Haven't road tested yet but it made 2 full laps of the yard and sat idling for a while.I noticed it running a little rough at fast idle for a minute or less.I presume this was when the tank was drawing vacuum.
Jim
The Following 2 Users Say Thank You to oldsoldster For This Post:
  #26
Old 09-14-2017, 02:45:40 PM
Sounds like you have it!. The less height the vacuum pump has to lift (full tank of gas), the better it works. If the pick up in the gank gets even a whiff of air, the pump will not get enough gas. You might want to install a clear in line gas filter, to make sure the pump is operating and for keeping any loose crud out of the pumping mechanism. If possible, get one of the old glass bowl type filters that use the sintered bronze filter element (not paper). That way you can see gas and if there are any contaminants (like water or dirt) On my Kohler C, I actually had an inline sight glass from an old AC unit. it was in line with the pump inlet. You could actually see the pump cycle! If you have an AC shop nearby, you might ask if they have a used sight around. Otherwise, the glass filter assembly will work as well.
Old 09-14-2017, 09:35:18 PM
I have a glass bowl on the bottom of the vacuum tank.It apparently was standard equipment on the 1926 Buick models.
Old 09-15-2017, 04:47:08 PM
The glass on the bottom of the tank -called a sediment bowl- was to take out any water and sediment that came through the tank. I think Andrews idea was to install one in the line to the tank so you could see what is happening, but it sounds like it is working. If the tank is clean you should be away. Happy touring.They are a great old car.
Old 09-15-2017, 08:27:16 PM
Tried my first road test today.The vacuum tank ran dry and I coasted to a stop.I brought along the necessary tools and fuel to refill it.It came home without incident and the tank refilled itself while idling in the driveway.Go figure.
Other than that it runs and drives very nicely.
The Following User Says Thank You to oldsoldster For This Post:
  #30
Old 09-15-2017, 10:47:59 PM
hmmm. Have you had the tank apart? is it clean and properly sealed?
Old 09-16-2017, 06:38:06 AM
All fuel components have been disassembled and cleaned in carb cleaner.New gaskets and seals have been installed and screws tightened.My only guess at this point is that I still haven't put quite enough fuel in the tank and when driving down the road the suction tube entrance is exposed to air occasionally.
  #32
Old 09-16-2017, 10:17:27 PM
Well put mote than $3 worth of gas in the thing and drive it. $7 should get you 2 miles farther before it quits.
Old 09-16-2017, 10:22:00 PM
Well. ... sounds like tank might be next to check. Is the pickip tube in good shape and going to within 1/2 " of bottom of the tank? I have seen them corrode off.
Old 09-17-2017, 08:55:26 AM
I really appreciate all the advice you guys are giving me. Oldtech,the fuel tank was removed,cleaned out and sealed at a rad shop. The pick up tube and screen are original and in perfect condition.The fuel lines are new.I will put more gas into it on Monday.
Right now we are going touring with the old car club in the '40 Packard coupe.
Jim
Old 09-18-2017, 01:55:08 PM
Just had the '25 for a 4 mile run and it didn't miss a beat.Had more gas in the tank (!) and tightened the 1 inch nut at the pickup tube.
The 2 front tires went soft on that run.It appears the fellow that restored it bought "NOS" red rubber inner tubes for it.Some NOS components aren't recommended !
  #36
Old 09-18-2017, 02:41:03 PM
Sounds like you are in business. A couple of inner tubes is minor. I wonded if he saved the original air too:
Old 10-04-2017, 11:30:51 AM
Had new tubes installed all around .Rollie Guertin came down and detailed the wheels as per original Pulled her out in the barnyard for a couple of new portrait shots.
Name:	1925 Buick ready to show ! 001.jpg
ID:	292821   Click image for larger version
Name:	1925 Buick ready to show ! 004.jpg
The Following 6 Users Say Thank You to oldsoldster For This Post:
  #38
Old 10-04-2017, 02:00:43 PM
Thumbs up Re: 1925 Buick Standard Six Four Passenger Coupe
What a beautiful looking car! nice find!
Old 10-28-2017, 01:31:59 PM
Now for the first time in 92 years the '25 Buick has it's right front seat back ! The original doctor owner removed it to keep his bag handy.A friend had a jump seat from an unknown 7 Passenger touring car,from which we used the hinges and back rest.A seat base was fabricated to fit into the floor when folded forward.A local upholstery shop closely matched the fabric.It definitely wasn't designed for large people !
Name:	1925 Buick seat 002.jpg
ID:	294572   Click image for larger version
Name:	1925 Buick RF seat frame.jpg
ID:	294573   Click image for larger version
Name:	1925 Buick RF seat.jpg
The Following 4 Users Say Thank You to oldsoldster For This Post:
  #40
Old 12-09-2017, 03:08:27 PM
Anyone driving an early car these days knows that retro turn signals are a must.The '25 Buick had only one central tail lamp.I had a pair of NOS trailer tail lights that match the Buick tail light and mounted them on the spare tire bracket with the existing lamp.The green (!) stop light was a period accessory.
For the front,I purchased a pair of '25-'26 Buick cowl lamps and mounted them on the front spring bushing bolts,replacing the standard nut with a long nut so that a short 9/16 bolt could hold the especially made brackets in place.This way no holes had to be drilled.They show up nicely.
Name:	1925  Buick rear lamps 001.jpg
ID:	297971   Click image for larger version
Name:	1925 Buick front turn signals 001.jpg
ID:	297972   Click image for larger version
Name:	1925 Buick front turn signals 002.jpg
The Following 7 Users Say Thank You to oldsoldster For This Post:
1940 Packard 110 coupe oldsoldster Antique Autos and Trucks 6 07-01-2017 09:53:02 AM
1920 Model T Coupe Craig A Antique Autos and Trucks 270 05-14-2014 05:38:58 PM
1940 Ford Coupe CLips221 Antique Autos and Trucks 6 12-23-2013 09:20:57 AM
