Rumely E Mechanical Restoration
this thread has 90 replies and has been viewed 20982 times
Old 01-08-2018, 09:26:56 AM
LukeSte LukeSte is offline
Default Re: Rumely E Mechanical Restoration
This tractor had been replumbed at some point with galvanized pipe. All of the old plumbing has been removed . New steel pipe has been used for fuel and water lines. After the wood deck is replaced the gas starting tank will be hooked in as well.
ID:	300021   Click image for larger version
ID:	300022   Click image for larger version
ID:	300023   Click image for larger version
Old 01-09-2018, 05:50:12 PM
H&J machine has been working on upper valve cage. reamed out original guides for oversize stem valves, and henry is machine out the seat area for a replacement seat with a 2 tiered step.. the reason for this was to minimize the material removed from the seat area.
ID:	300140   Click image for larger version
Old 01-12-2018, 11:32:41 AM
H&J has been making very good progress. 1 valve is finished, and the seats are in. a few pics of the multi step process, and a final report card.
ID:	300275   Click image for larger version
Name:	new valve.jpg
ID:	300276   Click image for larger version
Name:	valve cage underside finished.jpg
ID:	300277   Click image for larger version
Name:	valve in seat.jpg
Old 01-16-2018, 11:19:03 AM
we worked on furniture over the weekend. brother n law is a great wood worker and was eager to help. we got full dimension white oak that we ripped strait, and planed just enough to clean up. toolbox will also be white oak. oil pump is getting new packing and gasket.
ID:	300632   Click image for larger version
ID:	300633   Click image for larger version
ID:	300634   Click image for larger version
The Following 11 Users Say Thank You to LukeSte For This Post:
  #45
Old 01-16-2018, 03:08:07 PM
Dean Lemer Dean Lemer is offline
Keep up the pace and let’s make it smoke!😀
Old 01-16-2018, 09:09:58 PM
halcon halcon is offline
[QUOTE=lukeste; oil pump is getting new packing and gasket.[/QUOTE] Luke, if that pump impeller is brass, check to make sure it is not loose on the shaft. Some times the key or pin is nearly worn away.
The Following User Says Thank You to halcon For This Post:
  #47
Old 01-18-2018, 09:17:45 PM
Tim Colwell's Avatar
Tim Colwell Tim Colwell is offline
Looks like some really nice wood. I can't stand when people use construction grade lumber for a project like this.
Tim Colwell
JD & IHC corn sheller and engine collector.
The Following User Says Thank You to Tim Colwell For This Post:
  #48
Old 01-29-2018, 11:59:51 PM
After a week of r and r it was time to get back into the shop. The loose underside of what will be the platform got a linseed treatment. Also set up a circuit to clean and test ignitors. Have a very good bright spark so ignitors are now in. Also got the heads put on. Getting closer now. Hope to get furniture bolted in soon.
ID:	301775   Click image for larger version
ID:	301776   Click image for larger version
ID:	301777   Click image for larger version
Old 02-03-2018, 11:31:47 PM
Evenings this week were focused toward power washing. 15 gallons of diesel was burned in hot power washer. Close to a 30 gallon can of old oil grease and grime was washed off, looks much brtter. Today was a general finish wash and onto the wood. A lot of time was taken to get holes drilled, counter sinks for rivet heads, and everything squared up. The main runners were done first and fastened down so as to not move. Then basically one plank after another, with the exception of one longer board for the fender gas tank to rest on, and the typical notches needed for fuel fill, steer wheel bracket, etc. Right runner gets busy with a few off sets.
ID:	302198   Click image for larger version
ID:	302199   Click image for larger version
Old 02-03-2018, 11:35:31 PM
More pics. All the wood is white oak
ID:	302201   Click image for larger version
ID:	302202   Click image for larger version
Old 02-14-2018, 06:54:05 PM
the upper valve cage is ready for install. h and j in Carrington did a dandy job. the platform is all done as is the tool box. going to get cage on next and carb so I can finish the plumbing. spring is coming....
ID:	303175   Click image for larger version
ID:	303176   Click image for larger version
Old 02-19-2018, 09:40:53 AM
Since we have been on wood working and saw dust everywhere, it was decided to finish off the furniture and do the canopy. We continued with the white oak theme. And will be covered in galvanized tin
ID:	303521   Click image for larger version
Old 02-24-2018, 09:45:27 AM
Progress continues on the canopy. It got a linseed oil treatment and let dry. Last night I started on the roof, using galvanized tin. Hoping today that we get it mounted. I will feel better after canopy is mounted with rambunctious kids in the shop.
ID:	303947   Click image for larger version
ID:	303948   Click image for larger version
The Following 9 Users Say Thank You to LukeSte For This Post:
  #54
Old 02-24-2018, 09:51:53 AM
Larsons machine shop went to work on the good set of wheels and gears, i think there were 19 new rivets put into place, and 1 lug reattached. They also dropped on the gears. The wheels do no require maching and bushings for the axle so that was a good time and money saver. Our 2 younger kids view the rumely more like an indoor jungle gym. With gears on the wheels my forklift wasn't feeling up to the task so the big loader got the duty of moving wheels. Won't be too long before they go on tractor
ID:	303950   Click image for larger version
ID:	303951   Click image for larger version
ID:	303952   Click image for larger version
Old 02-24-2018, 11:10:29 AM
I notice that there are both 8 spoke and 5 spoke gears shown. I need an 8 spoke, 4 lug gear.
Ed
Old 02-24-2018, 11:33:44 AM
Yes, the originals are 4 pad gears, the good wheels and gears are 5 pad.
Old 02-24-2018, 11:02:01 PM
We put the upper valve cage on first before canopy. My 2 younger boys are doing management today in the shop. It is a bit of a job to get 2 nuts started on rear side of cage toward the middle as they are tucked in pretty tight and has to be drawn down evenly in every way as the valves and guide areas go down into the jugs a ways. Nice to have that piece on, and thanks again to h and j machine for the fine craftsmanship
ID:	304018   Click image for larger version
ID:	304019   Click image for larger version
Old 02-24-2018, 11:28:26 PM
The canopy went on next and after what felt like an hour of measuring, holes were drilled. Need to get some correct bolts so for now there is just some in to hold it square. It feels real good to get it off the ground.
ID:	304025   Click image for larger version
ID:	304026   Click image for larger version
ID:	304027   Click image for larger version
Old 02-26-2018, 07:10:43 AM
Thumbs up Re: Rumely E Mechanical Restoration
Good looking work right there, and especially great to see the two little helpers you have there! I've recently been enjoying sharing shop time with my oldest son, makes me feel good to have one that is interested to see what daddy's doing.
What's the little steam engine in the background? Early Nichols-Shepard?
Thanks,
Mike
Old 02-27-2018, 08:55:12 AM
Because this was converted to spark plugs at some point, much of the advance retard for ignitors was gone. Dean lemer took a couple pieces off of john tysse,s to cast pieces. Dean measured up shaft and went from there. Waiting for parts for this may be the holdup for a spring start, but won't be much left to do. Got .75 cold rolled for shaft and made the attaching lever, that has set screw to anchor it to the shaft. Although not casted it did turn out really well. I am a bit confused as to why rumely switch their carb from left air intake and right advance lever to the opposite orientation.
ID:	304204   Click image for larger version
ID:	304205   Click image for larger version
The Following 7 Users Say Thank You to LukeSte For This Post:
Mechanical Lubricator Restoration SteamfanMN Oilers, Lubricators and Grease Cups 3 10-19-2016 02:05:10 PM
Rumely 12-20 Restoration LukeSte Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 140 10-11-2015 10:58:44 PM
FMZ 6hp mechanical restoration. Tilinghast Hit & Miss Gas Engine Discussion 3 02-20-2010 06:35:27 PM
Mechanical Engine Restoration Chronicle Wayne Grenning Hit & Miss Gas Engine Discussion 10 09-26-2009 07:19:11 PM
4 HP Brown Cochran Mechanical Restoration Chris Epping Hit & Miss Gas Engine Discussion 27 02-09-2008 10:28:44 PM
