Case 18-32 K Project
this thread has 116 replies and has been viewed 12291 times
Old 01-02-2019, 04:25:04 PM
Russ Hamm's Avatar
Default Re: Case 18-32 K Project
Can anyone give me measurements on the Kingston float for the 18-32? Mine has shrunk a little bit and I just bought one of those slugs to make one. Also, any bearing numbers on the tapered roller bearings for the governor shaft? I have F0709HM I think, haven't been able to find such yet but next comes measurements and a catalogue.
Old 01-03-2019, 11:16:49 AM
Russ Hamm's Avatar
Took apart both governor drive shafts, the parts tractor had rusty bearings and on my tractor the bearings were completely shot. For reference, Timken #07098 and #07204 bearing and cup numbers and they are on order, looks like they can be had no problem. I imagine with the water pump, fan and magneto driven off this assembly these bearings are very important.
Also a pic of the governor gear tooth damage from the governor weights coming apart some time in its life.
ID:	325695   Click image for larger version
The Following 5 Users Say Thank You to Russ Hamm For This Post:
  #23
Old 01-03-2019, 09:55:58 PM
Bryan Storey Bryan Storey is offline
Those are the same number bearings from the governor on my 12-20 case. It had the same bearings in the fan drive gear box also. I also had a ball thrust bearing on the governor shaft that was shot. If you need that one I was able to find new ones exactly the same on eBay. Even though my bearings in the governor were shot all the rollers were still in the cages. I found a couple loose rollers when I was cleaning things up so it must have had another set of bearings that had went bad. After I got it running I found out there was no oil getting to the bearings. I removed the oil line coming from by the oil pressure gauge to the governor and still no oil. Where the line attached by the pressure guage there was a flare fitting with just a very small hole in it. Must be to reduce the flow to the governor. It was plugged there. I'm not familiar with the 18-32 but if it has the same set up make sure your getting oil.
The Following User Says Thank You to Bryan Storey For This Post:
  #24
Old 01-04-2019, 10:12:46 AM
Russ Hamm's Avatar
Ill have to check that fan drive, thanks. Looks like the fan driven shaft has those same bearings and the drive shaft has hyatt roller bearings on the drive cross shaft of the 18-32.
I also need to see what the heck is wrong with the focus on my camera.
Old 01-05-2019, 01:13:48 AM
NDmeterman NDmeterman is offline
Some cameras have a dedicated 'closeup' mode that you have to select.
The Following User Says Thank You to NDmeterman For This Post:
  #26
Old 01-05-2019, 10:59:16 PM
P. Kelly P. Kelly is offline
I just replaced those bearings in my 12-20. Same bearing. My local supplier had them on the shelf. How was the ball bearing in the flyball assembly?
Old 01-06-2019, 10:36:20 AM
Russ Hamm's Avatar
Something I found on the cam gears. Now I have three cam gears, all of them have some fault but two are very useable. Al three have the timing mark in a different location.
Near as I can tell the teeth were not cut exactly the same on the castings, but one gear is VERY far off of the other two and the other two are about half a tooth off from each other. The two crank gears I have to look at are a tooth different and where they are drilled and tapped for a lock screw is wayyyy off. I wonder if when they replaced a crank gear if maybe they just drilled and tapped a new hole in a different location? I have a really good crank gear that I could replace my worn one with, but it would have to be drilled in another spot as you cant re-drill at the original with half of it drilled and tapped in the crank.
By the way, the far left gear is actually marked in two places.
ID:	325821   Click image for larger version
ID:	325822   Click image for larger version
ID:	325823   Click image for larger version
Old 01-06-2019, 10:44:07 AM
Russ Hamm's Avatar
Got the drive gear for the first reduction shaft off the parts tractor, it actually went pretty good, had an old Grebb puller from a Mcormick-Deering tool board to use, these were actually an antique posi-lock puller.
The gib key end broke off so I drilled and tapped it to slide hammer it out, broke the darn tap off and tried to remove enough of it without success.
In the end, I think drilling the key deep relieved enough of it to make it come off with the key.
  #29
Old 01-06-2019, 08:42:32 PM
Duey C Duey C is offline
Interesting timing gears.
Does that mean each cam has a different location for the keyseat too?
Unique timing marks for every engine? Bizarre.
Old 01-07-2019, 10:33:06 AM
Russ Hamm's Avatar
The two crank gears I have are one tooth apart which could sure explain the cam gear difference. One of the cam gears has unusual marks compared to the other two which are center punched. I sense a degree wheel in my future, I think I remember seeing one in my dreams last night, or was it a nightmare?
Never ran across this before, but I sure did notice that when the teeth were cut in the machined casting they all three ended up in different spots to some degree, one pair is really close and the third one is half a tooth off. BUT the keyways I have not lined up yet, therein could be the answer.
  #31
Old 01-07-2019, 11:05:48 PM
Moline Moline is offline
cant wait to see and hear this one all done. but do you know what would make this tractor better?
The Following User Says Thank You to Moline For This Post:
  #32
Old 01-08-2019, 12:12:07 PM
Russ Hamm's Avatar
I know what yer getting at Moline, I sure would like to have one of those also but im lucky I had a good friend to sell me this one.
I haven't researched the cross motor Minnies much, looked at a few, there is one here right handy on loan at the museum that is the same year as my 17-28. All of these old tractors have their good and bad points, but the fact that there are many of these Cases still in exhistance has to show that they were just darn good tractors. Some of the wear on them looks like just plain neglect, some due to them loosing their shine over the years I suppose, especially when the neighbors all had their new inline models, those C and L Cases are some good lookin tractors.
  #33
Old 01-08-2019, 01:23:34 PM
thats not exactly what i was getting at but i have to agree lol. I was saying that some new cleats would look great on that beauty. keep up good work.
  #34
Old 01-08-2019, 07:46:29 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
I always felt that those Case cross motors were rugged and reliable, The issues I see with the one here is that it's as clumsy as all get out. Takes a monumental effort to steer ,and isn't bashful at the fuel pump! It would take one tough a&&'d farmer to wear one out!
The Following 2 Users Say Thank You to FWurth For This Post:
  #35
Old 01-09-2019, 07:17:02 AM
Happy Birthday Russ!
  #36
Old 01-09-2019, 12:08:16 PM
FWurth's Avatar
One Millionth Post
I'll drink to that!
  #37
Old 01-14-2019, 08:12:34 PM
Russ Hamm's Avatar
On another thread the subject of cork float replacement was discussed. I took advise and bought a 'plug', made a guess on the float size and cut it out with two hole saws. I had to cut to width on the band saw, then filled the center hole with 1/4"X 1 1/4" flat washers for a pilot hole, then cut the rough size out with two hole saws, larger first then smaller for the ID. Looks like in the bargain I was left with a slug that should work for a McCormick- Deering ensign carburetor float. Plus plenty of material left for other projects.
I forgot to add, when working with this material it makes fine dust and smells really bad, so wear breathing protection.
The Following 4 Users Say Thank You to Russ Hamm For This Post:
  #38
Old 01-14-2019, 09:52:01 PM
Russ?
Will you coat that cork with anything?
Thanx.
Old 01-15-2019, 12:00:49 AM
Russ...Where did you secure the cork stock from?
Old 01-15-2019, 09:40:38 AM
Russ Hamm's Avatar
Mentioned in another thread they call this "model T float slug". You can google that and find it for 28 dollars or so online.
T-6201-B
Model T Float Slug
Modern material that is resistant to the ethanols in today's fuels. We have had a lot of requests from customers with other applications wanting this material for making their own floats. Hole in the middle is 1.250", diameter is 3.850", 3" high.
The Following 2 Users Say Thank You to Russ Hamm For This Post:
18-32 Case New Project Camerons Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 20 07-06-2019 01:25:12 PM
22-40 Case Project Craig A Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 31 12-16-2015 08:14:40 PM
Case 15-27 crossmotor new project. neilthewheel Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 03-10-2012 11:46:01 PM
Case 12-20 New Project Camerons Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 21 12-28-2011 07:47:52 PM
New project, Case 500 Turbo Antique Farm Tractors 10 11-20-2007 12:07:12 PM
