Atlas Lathe
this thread has 7 replies and has been viewed 1590 times
Old 01-02-2018, 07:22:06 PM
Jerry B Jerry B is offline
Default Atlas Lathe
I have a 12x36'' lathe & on the lathe the cross slide lever it will not stay up when using the lathe it falls and trays go into gear are there a detent ball & spring
Old 01-02-2018, 09:28:43 PM
b7100 b7100 is offline
Default Re: atlas lathe
Try the hmem or home shop machinist forums.
The Following User Says Thank You to b7100 For This Post:
Old 01-02-2018, 09:46:25 PM
Yes, there should be a ball and spring that falls into a detent. It should click when going from one position to the other.
The Following User Says Thank You to Pat Barrett For This Post:
Old 01-04-2018, 09:51:40 PM
old iron shops old iron shops is offline
Default Re: Atlas Lathe
Are you talking about the half nut lever? There is a spring and detent iv got a video that showshe the hole half nut setup https://youtu.be/73qaysLIAng hope this helps
The Following User Says Thank You to old iron shops For This Post:
Old 01-07-2018, 12:13:27 AM
dkamp dkamp is offline
eMail NOT Working
Not an unusual antic for Atlas lathes... happens on the leadscrew direction control box, too... and when it drops into gear while the machine is running, it tends to break parts...
Old 01-07-2018, 02:59:48 AM
Should be able to download a diagram from here: http://www.lathes.co.uk
Doc
Old 01-19-2018, 08:45:51 AM
I have a atlas lathe I think you are talking about the half nut lever I happen to have a video about just this https://youtu.be/MpAI_rw8rHo this should help you out.
Old 01-19-2018, 09:44:28 AM
Tom17 Tom17 is offline
Doesn't the cross slide have a screw with dial?
Do you have some sort of production turret lathe or something else?
Atlas 12'' 36'' lathe Jerry B Machine Shop and Tool Talk 10 10-15-2015 05:05:50 PM
Atlas lathe Jerry B Machine Shop and Tool Talk 4 08-19-2015 12:40:52 AM
Atlas lathe Jerry B Machine Shop and Tool Talk 2 05-17-2015 07:00:09 AM
Atlas Lathe Jerry B Machine Shop and Tool Talk 11 02-15-2015 03:38:44 PM
Atlas lathe parts-thanks. lester bowman Antique Engine Archives 2 10-24-2004 12:07:22 PM
