1954 John Deere 60 throttle adjuster
this thread has 2 replies and has been viewed 615 times
Old 11-04-2018, 01:47:31 PM
J Ware J Ware is offline
Default 1954 John Deere 60 throttle adjuster
I recently bought a John Deere 60, it hadn't run in about10 yrs. Ihad done a valve job and replaced the manifold on it that that time for my neighbor and it has just sat since.
I got it and cleaned the carb, put in new points and condensor, and plugs. When reinstalling the carb, following the JD manual I was going to adjust engine speed when I found the speed adjusters ball joint worn out and held together with wire. Does anyone know if this part is still available thru deere. This is the piece that goes on the threaded rod from the governor arm and hooks to the throttle lever. Jim
The Following User Says Thank You to J Ware For This Post:
Old 11-04-2018, 08:22:27 PM
Arrow Re: 1954 John Deere 60 throttle adjuster
It isn't difficult to make if you have a friend with a lathe but the place at the link has 3 on hand in Iowa.
https://www.worthingtonagparts.com/J...USED-WU-A4948R
Old 11-06-2018, 10:12:52 PM
Default Re: 1954 John Deere 60 throttle adjuster
Thanks Craig, I went to my local JD dealer and found out the part is obsolete, but gave me 3 dealer's that showed them in their inventory. Have one coming from Texas for4.65 plus shipping. They had 2 in stock. Jim
John Deere Restored 1954 Model 40 Crawler w/Blade Mike Paul Live Auctions of Engines, Tractors and Old Iron 3 09-26-2016 11:56:09 AM
John Deere 40C. Adjusting throttle control link from governor to cab. crawfish Farm Antiques and Collectibles 1 06-17-2013 08:38:40 PM
John Deere 317 Throttle Cable Routing ? KenS999 Garden Tractors and Mowers 4 08-27-2012 09:21:14 PM
1913 IHC runs again throttle governing used John Deere H to start no bump start RobGill2008 Hit & Miss Gas Engine Discussion 1 08-17-2010 08:24:46 PM
1929 John Deere D throttle setup Mike Inglis Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 14 07-26-2006 04:54:15 PM
