Sawyer Massey Tractors
this thread has 75 replies and has been viewed 20655 times
Old 07-10-2017, 03:36:04 AM
Gary Biewer Gary Biewer is offline
Default Re: Sawyer Massey Tractors
We have a 20-40. The 20-45 is in Crosby,ND.
The Following User Says Thank You to Gary Biewer For This Post:
Old 04-26-2018, 09:07:47 PM
Some interesting history on a local Ontario well drilling company from the Seaforth Ontario area that were long time customers of Sawyer Massey.They started off using a Sawyer Massey Steam engine for their bussiness and then switched over to Sawyer gas tractors later on in particular a Sawyer Massey 11-22 tractor
http://www.wdhopperwaterwells.com/historical.php
The Following 3 Users Say Thank You to casertractor For This Post:
  #63
Old 04-27-2018, 08:16:27 AM
I’m still thinking about the 30-60 Sawyer question. I’m wondering if Mr Allan Byers was told by Mr Ewart Dearing about the high compression pistons in his tractor. It’s in the Diebold collection now maybe they know? I’m also wondering if that engine sounds different compared to a regular compression Sawyer?
The Following User Says Thank You to David Hoover For This Post:
  #64
Old 04-27-2018, 11:33:57 AM
Speaking of Allan Byers 30-60 Sawyer tractor here is a picture of Mr Byers and Sherwood Hume with both Mr Hume's 40-80 Minneapolis tractor and Allan's 30-60 Sawyer Massey tractor at Milton Steam Era back in the 1960's or 1970's
Name:	Sherwood Hume and Allan Byers.jpg
The Following 7 Users Say Thank You to casertractor For This Post:
  #65
Old 04-27-2018, 10:50:59 PM
David, I doubt it sounds any different.
Compressions ratios then were peanuts to what they are now.
  #66
Old 04-30-2018, 10:53:48 AM
Four stack 20-40 Sawyer Massey Gas Tractor on the sawmill at NTA
https://www.youtube.com/watch?v=KkAbDZ7Gp98
The Following 4 Users Say Thank You to casertractor For This Post:
  #67
Old 05-02-2018, 01:35:01 PM
I belive this was the 20-40 tractor of the late Lorne Harris of the Woodstock Ontario area.One of only two four stack or four banger exhaust 20-40's still known to exist
  #68
Old 05-02-2018, 04:35:38 PM
At what time did SM change the fenders on the model 11-22 ? as i have seen two or three different style's on the 11-22 tractors also when did they start or stop using the cast iron tanks on the fenders to oil the drive gear behind the rear wheels on the 11-22?
Old 05-02-2018, 05:31:23 PM
Straight sides at the start on 11-22 same as bigger tractors, 1917-1918. Straight side with small fenders after that, then no sides but a nice fender for the rest.
The Following 2 Users Say Thank You to G Willikers For This Post:
  #70
Old 09-03-2019, 09:31:22 PM
Anybody know were this tractor ended up?
https://www.youtube.com/watch?v=59Dv-BupbNw
  #71
Old 09-04-2019, 09:16:29 AM
Russ Hamm's Avatar
I see the cooling fan doesn't turn when the clutch is disengaged.
  #72
Old 09-04-2019, 09:32:12 AM
Russ,
... and it goes backwards when you reverse the tractor! Bevel gear drive.
Old 09-04-2019, 12:44:42 PM
When did SM switch from the round wheel spokes to the flat spokes on the front wheels on the 11-22?
Old 09-05-2019, 01:20:55 AM
George Best George Best is offline
There are two 11-22's being auctioned off on the 16th of this month.
Aumann vintage power website, look at the Schurman Iron Ranch auction.
Lot 55 and lot 56 are two 11-22's project tractors.
http://www.irontrader.com/
The Following User Says Thank You to George Best For This Post:
  #75
Old 09-05-2019, 09:26:36 AM
https://bid.aumannauctions.com/m/lot...Fid%2F21905%2F
Old 09-20-2019, 09:18:08 AM
https://www.manitobacooperator.ca/co...5-gas-tractor/
The Following 2 Users Say Thank You to casertractor For This Post:
Sawyer Massey MD4302 Steam Stationary Engines, Traction Engines 12 04-07-2013 06:57:37 AM
Sawyer Massey 18-36 Molinegb Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 03-12-2013 11:53:52 AM
Sawyer and Massey Ben Snider Steam Stationary Engines, Traction Engines 0 03-22-2011 08:07:22 AM
Sawyer Massey 11-22 Jim Tremble Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 05-05-2007 08:09:57 PM
Sawyer-Massey Glenn Gieszler Steam Stationary Engines, Traction Engines 3 05-14-2006 10:32:29 PM
